Adding OrderHed and OrderDtl tables to RMA Form
They should be outer joins and the same as they are in Epicor (Assuming the relationships in Epicor are correct)
One quick way to test this is to write a BAQ using the same tables and joins you have in the RDD. Analyze the results to see if you are getting the records you expected and if it works duplicate those relationships in the RDD and make sure they are the same in Crystal
On Monday, October 13, 2014 5:11 PM, "Patricia Hall phall@... [vantage]" <vantage@yahoogroups.com> wrote:
<div id="ygrps-yiv-1602130674yiv7829503314ygrp-text">
  <div>Yes, that was partly my question, what were the joins supposed to be? Should they be the same in Crystal as they are in Epicor? Or vice versa?
I have (Inner joins)
[cid:image001.jpg@01CFE700.64726AB0]
Patricia Hall
Systems Analyst
[cid:image002.png@...7982E0]
3137 East 6th Street
Muscle Shoals, Al 35661
T: 256.978.6294
C: 256.366.8697
F: 256.383.8224
E: phall@...<mailto:phall@...>
www.cbcings.com
Sent: Monday, October 13, 2014 3:40 PM
Subject: Re: [Vantage] RE: Adding OrderHed and OrderDtl tables to RMA Form
Under the database go to datasource relationships in Crystal Reports. Check the joins between OrderHed and Order Detail and also which tables they are linked to. Sounds like you may need to fix your joins in Crystal itself. Also set the joins to outer join on the table relationships
Its not unusual that the joins in RDD do not come across correctly in Crystal Even if there is xml data you need to make sure the joins in Crystal are correct
On Monday, October 13, 2014 4:22 PM, "Patricia Hall phall@...<mailto:phall@...> [vantage]" <vantage@yahoogroups.com<mailto:vantage@yahoogroups.com>> wrote:
Yes sir I did. I even went back and created everything again on the off chance I missed something.
Patricia Hall
Systems Analyst
T: 256.978.6294
www.cbcings.com
From: vantage@yahoogroups.com<mailto:vantage@yahoogroups.com> [mailto:vantage@yahoogroups.com]
Sent: Monday, October 13, 2014 3:19 PM
To: vantage@yahoogroups.com<mailto:vantage@yahoogroups.com>
Subject: [Vantage] RE: Adding OrderHed and OrderDtl tables to RMA Form
After adding did you re-verify the database? Not sure if that applies for RDD situations (I use ODBC) but it usually fixes a lot of things.
-Todd
Sent: Monday, October 13, 2014 3:04 PM
Subject: [Vantage] Adding OrderHed and OrderDtl tables to RMA Form
Hi all,
I need to add some fields from the OrderHed and OrderDtl tables to the RMAForm. I’m running Epicor 905.702A and Crystal Reports. I’ve got the tables added to my new RDD just fine and my xml shows that the data is present. However, the data won’t show up on my report. I can browse data within Crystal and the data I need in the fields I added is present. What fields do I need to link in Crystal or what relationships do I need to make in my RDD? Any help would be greatly appreciated.
Thank you,
Patricia Hall
Systems Analyst
CBC INGS AMERICA
www.cbcings.com
</div>
<div style="color:#fff;height:0;"></div></div>
#ygrps-yiv-1602130674 #ygrps-yiv-1602130674yiv7829503314 #ygrps-yiv-1602130674yiv7829503314 -- #ygrps-yiv-1602130674yiv7829503314ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;}
#ygrps-yiv-1602130674 #ygrps-yiv-1602130674yiv7829503314 #ygrps-yiv-1602130674yiv7829503314ygrp-mkp hr {
border:1px solid #d8d8d8;}
#ygrps-yiv-1602130674 #ygrps-yiv-1602130674yiv7829503314 #ygrps-yiv-1602130674yiv7829503314ygrp-mkp #ygrps-yiv-1602130674yiv7829503314hd {
color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;}
#ygrps-yiv-1602130674 #ygrps-yiv-1602130674yiv7829503314 #ygrps-yiv-1602130674yiv7829503314ygrp-mkp #ygrps-yiv-1602130674yiv7829503314ads {
margin-bottom:10px;}
#ygrps-yiv-1602130674 #ygrps-yiv-1602130674yiv7829503314 #ygrps-yiv-1602130674yiv7829503314ygrp-mkp .ygrps-yiv-1602130674yiv7829503314ad {
padding:0 0;}
#ygrps-yiv-1602130674 #ygrps-yiv-1602130674yiv7829503314 #ygrps-yiv-1602130674yiv7829503314ygrp-mkp .ygrps-yiv-1602130674yiv7829503314ad p {
margin:0;}
#ygrps-yiv-1602130674 #ygrps-yiv-1602130674yiv7829503314 #ygrps-yiv-1602130674yiv7829503314ygrp-mkp .ygrps-yiv-1602130674yiv7829503314ad a {
color:#0000ff;text-decoration:none;}
#ygrps-yiv-1602130674 #ygrps-yiv-1602130674yiv7829503314 #ygrps-yiv-1602130674yiv7829503314ygrp-sponsor #ygrps-yiv-1602130674yiv7829503314ygrp-lc {
font-family:Arial;}
#ygrps-yiv-1602130674 #ygrps-yiv-1602130674yiv7829503314 #ygrps-yiv-1602130674yiv7829503314ygrp-sponsor #ygrps-yiv-1602130674yiv7829503314ygrp-lc #ygrps-yiv-1602130674yiv7829503314hd {
margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;}
#ygrps-yiv-1602130674 #ygrps-yiv-1602130674yiv7829503314 #ygrps-yiv-1602130674yiv7829503314ygrp-sponsor #ygrps-yiv-1602130674yiv7829503314ygrp-lc .ygrps-yiv-1602130674yiv7829503314ad {
margin-bottom:10px;padding:0 0;}
#ygrps-yiv-1602130674 #ygrps-yiv-1602130674yiv7829503314 #ygrps-yiv-1602130674yiv7829503314actions {
font-family:Verdana;font-size:11px;padding:10px 0;}
#ygrps-yiv-1602130674 #ygrps-yiv-1602130674yiv7829503314 #ygrps-yiv-1602130674yiv7829503314activity {
background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}
#ygrps-yiv-1602130674 #ygrps-yiv-1602130674yiv7829503314 #ygrps-yiv-1602130674yiv7829503314activity span {
font-weight:700;}
#ygrps-yiv-1602130674 #ygrps-yiv-1602130674yiv7829503314 #ygrps-yiv-1602130674yiv7829503314activity span:first-child {
text-transform:uppercase;}
#ygrps-yiv-1602130674 #ygrps-yiv-1602130674yiv7829503314 #ygrps-yiv-1602130674yiv7829503314activity span a {
color:#5085b6;text-decoration:none;}
#ygrps-yiv-1602130674 #ygrps-yiv-1602130674yiv7829503314 #ygrps-yiv-1602130674yiv7829503314activity span span {
color:#ff7900;}
#ygrps-yiv-1602130674 #ygrps-yiv-1602130674yiv7829503314 #ygrps-yiv-1602130674yiv7829503314activity span .ygrps-yiv-1602130674yiv7829503314underline {
text-decoration:underline;}
#ygrps-yiv-1602130674 #ygrps-yiv-1602130674yiv7829503314 .ygrps-yiv-1602130674yiv7829503314attach {
clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;}
#ygrps-yiv-1602130674 #ygrps-yiv-1602130674yiv7829503314 .ygrps-yiv-1602130674yiv7829503314attach div a {
#ygrps-yiv-1602130674 #ygrps-yiv-1602130674yiv7829503314 .ygrps-yiv-1602130674yiv7829503314attach img {
border:none;padding-right:5px;}
#ygrps-yiv-1602130674 #ygrps-yiv-1602130674yiv7829503314 .ygrps-yiv-1602130674yiv7829503314attach label {
display:block;margin-bottom:5px;}
#ygrps-yiv-1602130674 #ygrps-yiv-1602130674yiv7829503314 .ygrps-yiv-1602130674yiv7829503314attach label a {
#ygrps-yiv-1602130674 #ygrps-yiv-1602130674yiv7829503314 blockquote {
margin:0 0 0 4px;}
#ygrps-yiv-1602130674 #ygrps-yiv-1602130674yiv7829503314 .ygrps-yiv-1602130674yiv7829503314bold {
font-family:Arial;font-size:13px;font-weight:700;}
#ygrps-yiv-1602130674 #ygrps-yiv-1602130674yiv7829503314 .ygrps-yiv-1602130674yiv7829503314bold a {
#ygrps-yiv-1602130674 #ygrps-yiv-1602130674yiv7829503314 dd.ygrps-yiv-1602130674yiv7829503314last p a {
font-family:Verdana;font-weight:700;}
#ygrps-yiv-1602130674 #ygrps-yiv-1602130674yiv7829503314 dd.ygrps-yiv-1602130674yiv7829503314last p span {
margin-right:10px;font-family:Verdana;font-weight:700;}
#ygrps-yiv-1602130674 #ygrps-yiv-1602130674yiv7829503314 dd.ygrps-yiv-1602130674yiv7829503314last p span.ygrps-yiv-1602130674yiv7829503314yshortcuts {
margin-right:0;}
#ygrps-yiv-1602130674 #ygrps-yiv-1602130674yiv7829503314 div.ygrps-yiv-1602130674yiv7829503314attach-table div div a {
#ygrps-yiv-1602130674 #ygrps-yiv-1602130674yiv7829503314 div.ygrps-yiv-1602130674yiv7829503314attach-table {
width:400px;}
#ygrps-yiv-1602130674 #ygrps-yiv-1602130674yiv7829503314 div.ygrps-yiv-1602130674yiv7829503314file-title a, #ygrps-yiv-1602130674 #ygrps-yiv-1602130674yiv7829503314 div.ygrps-yiv-1602130674yiv7829503314file-title a:active, #ygrps-yiv-1602130674 #ygrps-yiv-1602130674yiv7829503314 div.ygrps-yiv-1602130674yiv7829503314file-title a:hover, #ygrps-yiv-1602130674 #ygrps-yiv-1602130674yiv7829503314 div.ygrps-yiv-1602130674yiv7829503314file-title a:visited {
#ygrps-yiv-1602130674 #ygrps-yiv-1602130674yiv7829503314 div.ygrps-yiv-1602130674yiv7829503314photo-title a, #ygrps-yiv-1602130674 #ygrps-yiv-1602130674yiv7829503314 div.ygrps-yiv-1602130674yiv7829503314photo-title a:active, #ygrps-yiv-1602130674 #ygrps-yiv-1602130674yiv7829503314 div.ygrps-yiv-1602130674yiv7829503314photo-title a:hover, #ygrps-yiv-1602130674 #ygrps-yiv-1602130674yiv7829503314 div.ygrps-yiv-1602130674yiv7829503314photo-title a:visited {
#ygrps-yiv-1602130674 #ygrps-yiv-1602130674yiv7829503314 div#ygrps-yiv-1602130674yiv7829503314ygrp-mlmsg #ygrps-yiv-1602130674yiv7829503314ygrp-msg p a span.ygrps-yiv-1602130674yiv7829503314yshortcuts {
font-family:Verdana;font-size:10px;font-weight:normal;}
#ygrps-yiv-1602130674 #ygrps-yiv-1602130674yiv7829503314 .ygrps-yiv-1602130674yiv7829503314green {
color:#628c2a;}
#ygrps-yiv-1602130674 #ygrps-yiv-1602130674yiv7829503314 .ygrps-yiv-1602130674yiv7829503314MsoNormal {
margin:0 0 0 0;}
#ygrps-yiv-1602130674 #ygrps-yiv-1602130674yiv7829503314 o {
font-size:0;}
#ygrps-yiv-1602130674 #ygrps-yiv-1602130674yiv7829503314 #ygrps-yiv-1602130674yiv7829503314photos div {
float:left;width:72px;}
#ygrps-yiv-1602130674 #ygrps-yiv-1602130674yiv7829503314 #ygrps-yiv-1602130674yiv7829503314photos div div {
border:1px solid #666666;height:62px;overflow:hidden;width:62px;}
#ygrps-yiv-1602130674 #ygrps-yiv-1602130674yiv7829503314 #ygrps-yiv-1602130674yiv7829503314photos div label {
color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}
#ygrps-yiv-1602130674 #ygrps-yiv-1602130674yiv7829503314 #ygrps-yiv-1602130674yiv7829503314reco-category {
font-size:77%;}
#ygrps-yiv-1602130674 #ygrps-yiv-1602130674yiv7829503314 #ygrps-yiv-1602130674yiv7829503314reco-desc {
font-size:77%;}
#ygrps-yiv-1602130674 #ygrps-yiv-1602130674yiv7829503314 .ygrps-yiv-1602130674yiv7829503314replbq {
margin:4px;}
#ygrps-yiv-1602130674 #ygrps-yiv-1602130674yiv7829503314 #ygrps-yiv-1602130674yiv7829503314ygrp-actbar div a:first-child {
margin-right:2px;padding-right:5px;}
#ygrps-yiv-1602130674 #ygrps-yiv-1602130674yiv7829503314 #ygrps-yiv-1602130674yiv7829503314ygrp-mlmsg {
font-size:13px;font-family:Arial, helvetica, clean, sans-serif;}
#ygrps-yiv-1602130674 #ygrps-yiv-1602130674yiv7829503314 #ygrps-yiv-1602130674yiv7829503314ygrp-mlmsg table {
font-size:inherit;font:100%;}
#ygrps-yiv-1602130674 #ygrps-yiv-1602130674yiv7829503314 #ygrps-yiv-1602130674yiv7829503314ygrp-mlmsg select, #ygrps-yiv-1602130674 #ygrps-yiv-1602130674yiv7829503314 input, #ygrps-yiv-1602130674 #ygrps-yiv-1602130674yiv7829503314 textarea {
font:99% Arial, Helvetica, clean, sans-serif;}
#ygrps-yiv-1602130674 #ygrps-yiv-1602130674yiv7829503314 #ygrps-yiv-1602130674yiv7829503314ygrp-mlmsg pre, #ygrps-yiv-1602130674 #ygrps-yiv-1602130674yiv7829503314 code {
font:115% monospace;}
#ygrps-yiv-1602130674 #ygrps-yiv-1602130674yiv7829503314 #ygrps-yiv-1602130674yiv7829503314ygrp-mlmsg * {
line-height:1.22em;}
#ygrps-yiv-1602130674 #ygrps-yiv-1602130674yiv7829503314 #ygrps-yiv-1602130674yiv7829503314ygrp-mlmsg #ygrps-yiv-1602130674yiv7829503314logo {
padding-bottom:10px;}
#ygrps-yiv-1602130674 #ygrps-yiv-1602130674yiv7829503314 #ygrps-yiv-1602130674yiv7829503314ygrp-msg p a {
font-family:Verdana;}
#ygrps-yiv-1602130674 #ygrps-yiv-1602130674yiv7829503314 #ygrps-yiv-1602130674yiv7829503314ygrp-msg p#ygrps-yiv-1602130674yiv7829503314attach-count span {
color:#1E66AE;font-weight:700;}
#ygrps-yiv-1602130674 #ygrps-yiv-1602130674yiv7829503314 #ygrps-yiv-1602130674yiv7829503314ygrp-reco #ygrps-yiv-1602130674yiv7829503314reco-head {
color:#ff7900;font-weight:700;}
#ygrps-yiv-1602130674 #ygrps-yiv-1602130674yiv7829503314 #ygrps-yiv-1602130674yiv7829503314ygrp-reco {
margin-bottom:20px;padding:0px;}
#ygrps-yiv-1602130674 #ygrps-yiv-1602130674yiv7829503314 #ygrps-yiv-1602130674yiv7829503314ygrp-sponsor #ygrps-yiv-1602130674yiv7829503314ov li a {
font-size:130%;text-decoration:none;}
#ygrps-yiv-1602130674 #ygrps-yiv-1602130674yiv7829503314 #ygrps-yiv-1602130674yiv7829503314ygrp-sponsor #ygrps-yiv-1602130674yiv7829503314ov li {
font-size:77%;list-style-type:square;padding:6px 0;}
#ygrps-yiv-1602130674 #ygrps-yiv-1602130674yiv7829503314 #ygrps-yiv-1602130674yiv7829503314ygrp-sponsor #ygrps-yiv-1602130674yiv7829503314ov ul {
margin:0;padding:0 0 0 8px;}
#ygrps-yiv-1602130674 #ygrps-yiv-1602130674yiv7829503314 #ygrps-yiv-1602130674yiv7829503314ygrp-text {
font-family:Georgia;}
#ygrps-yiv-1602130674 #ygrps-yiv-1602130674yiv7829503314 #ygrps-yiv-1602130674yiv7829503314ygrp-text p {
margin:0 0 1em 0;}
#ygrps-yiv-1602130674 #ygrps-yiv-1602130674yiv7829503314 #ygrps-yiv-1602130674yiv7829503314ygrp-text tt {
font-size:120%;}
#ygrps-yiv-1602130674 #ygrps-yiv-1602130674yiv7829503314 #ygrps-yiv-1602130674yiv7829503314ygrp-vital ul li:last-child {
border-right:none !important;}
Hi all,
Thank you,
Patricia Hall
Systems Analyst
CBC INGS AMERICA
www.cbcings.com
-Todd
Hi all,
Thank you,
Patricia Hall
Systems Analyst
CBC INGS AMERICA
www.cbcings.com
Patricia Hall
Systems Analyst
T: 256.978.6294
E: phall@...
www.cbcings.com
-Todd
Hi all,
Thank you,
Patricia Hall
Systems Analyst
CBC INGS AMERICA
www.cbcings.com
On Monday, October 13, 2014 4:22 PM, "Patricia Hall phall@... [vantage]" <vantage@yahoogroups.com> wrote:
<div id="ygrps-yiv-1629836606yiv4900545579ygrp-text">
  <div>
Patricia Hall
Systems Analyst
T: 256.978.6294
-Todd
Hi all,
Thank you,
Patricia Hall
Systems Analyst
CBC INGS AMERICA
</div>
<div class="ygrps-yiv-1629836606yiv4900545579yqt4878553176" id="ygrps-yiv-1629836606yiv4900545579yqt98602"><div style="color:#fff;height:0;"></div></div>
#ygrps-yiv-1629836606 #ygrps-yiv-1629836606yiv4900545579 #ygrps-yiv-1629836606yiv4900545579 -- #ygrps-yiv-1629836606yiv4900545579ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;}
#ygrps-yiv-1629836606 #ygrps-yiv-1629836606yiv4900545579 #ygrps-yiv-1629836606yiv4900545579ygrp-mkp hr {
#ygrps-yiv-1629836606 #ygrps-yiv-1629836606yiv4900545579 #ygrps-yiv-1629836606yiv4900545579ygrp-mkp #ygrps-yiv-1629836606yiv4900545579hd {
#ygrps-yiv-1629836606 #ygrps-yiv-1629836606yiv4900545579 #ygrps-yiv-1629836606yiv4900545579ygrp-mkp #ygrps-yiv-1629836606yiv4900545579ads {
#ygrps-yiv-1629836606 #ygrps-yiv-1629836606yiv4900545579 #ygrps-yiv-1629836606yiv4900545579ygrp-mkp .ygrps-yiv-1629836606yiv4900545579ad {
padding:0 0;}
#ygrps-yiv-1629836606 #ygrps-yiv-1629836606yiv4900545579 #ygrps-yiv-1629836606yiv4900545579ygrp-mkp .ygrps-yiv-1629836606yiv4900545579ad p {
margin:0;}
#ygrps-yiv-1629836606 #ygrps-yiv-1629836606yiv4900545579 #ygrps-yiv-1629836606yiv4900545579ygrp-mkp .ygrps-yiv-1629836606yiv4900545579ad a {
#ygrps-yiv-1629836606 #ygrps-yiv-1629836606yiv4900545579 #ygrps-yiv-1629836606yiv4900545579ygrp-sponsor #ygrps-yiv-1629836606yiv4900545579ygrp-lc {
font-family:Arial;}
#ygrps-yiv-1629836606 #ygrps-yiv-1629836606yiv4900545579 #ygrps-yiv-1629836606yiv4900545579ygrp-sponsor #ygrps-yiv-1629836606yiv4900545579ygrp-lc #ygrps-yiv-1629836606yiv4900545579hd {
#ygrps-yiv-1629836606 #ygrps-yiv-1629836606yiv4900545579 #ygrps-yiv-1629836606yiv4900545579ygrp-sponsor #ygrps-yiv-1629836606yiv4900545579ygrp-lc .ygrps-yiv-1629836606yiv4900545579ad {
#ygrps-yiv-1629836606 #ygrps-yiv-1629836606yiv4900545579 #ygrps-yiv-1629836606yiv4900545579actions {
#ygrps-yiv-1629836606 #ygrps-yiv-1629836606yiv4900545579 #ygrps-yiv-1629836606yiv4900545579activity {
#ygrps-yiv-1629836606 #ygrps-yiv-1629836606yiv4900545579 #ygrps-yiv-1629836606yiv4900545579activity span {
font-weight:700;}
#ygrps-yiv-1629836606 #ygrps-yiv-1629836606yiv4900545579 #ygrps-yiv-1629836606yiv4900545579activity span:first-child {
#ygrps-yiv-1629836606 #ygrps-yiv-1629836606yiv4900545579 #ygrps-yiv-1629836606yiv4900545579activity span a {
#ygrps-yiv-1629836606 #ygrps-yiv-1629836606yiv4900545579 #ygrps-yiv-1629836606yiv4900545579activity span span {
color:#ff7900;}
#ygrps-yiv-1629836606 #ygrps-yiv-1629836606yiv4900545579 #ygrps-yiv-1629836606yiv4900545579activity span .ygrps-yiv-1629836606yiv4900545579underline {
#ygrps-yiv-1629836606 #ygrps-yiv-1629836606yiv4900545579 .ygrps-yiv-1629836606yiv4900545579attach {
#ygrps-yiv-1629836606 #ygrps-yiv-1629836606yiv4900545579 .ygrps-yiv-1629836606yiv4900545579attach div a {
#ygrps-yiv-1629836606 #ygrps-yiv-1629836606yiv4900545579 .ygrps-yiv-1629836606yiv4900545579attach img {
#ygrps-yiv-1629836606 #ygrps-yiv-1629836606yiv4900545579 .ygrps-yiv-1629836606yiv4900545579attach label {
#ygrps-yiv-1629836606 #ygrps-yiv-1629836606yiv4900545579 .ygrps-yiv-1629836606yiv4900545579attach label a {
#ygrps-yiv-1629836606 #ygrps-yiv-1629836606yiv4900545579 blockquote {
margin:0 0 0 4px;}
#ygrps-yiv-1629836606 #ygrps-yiv-1629836606yiv4900545579 .ygrps-yiv-1629836606yiv4900545579bold {
#ygrps-yiv-1629836606 #ygrps-yiv-1629836606yiv4900545579 .ygrps-yiv-1629836606yiv4900545579bold a {
#ygrps-yiv-1629836606 #ygrps-yiv-1629836606yiv4900545579 dd.ygrps-yiv-1629836606yiv4900545579last p a {
#ygrps-yiv-1629836606 #ygrps-yiv-1629836606yiv4900545579 dd.ygrps-yiv-1629836606yiv4900545579last p span {
#ygrps-yiv-1629836606 #ygrps-yiv-1629836606yiv4900545579 dd.ygrps-yiv-1629836606yiv4900545579last p span.ygrps-yiv-1629836606yiv4900545579yshortcuts {
margin-right:0;}
#ygrps-yiv-1629836606 #ygrps-yiv-1629836606yiv4900545579 div.ygrps-yiv-1629836606yiv4900545579attach-table div div a {
#ygrps-yiv-1629836606 #ygrps-yiv-1629836606yiv4900545579 div.ygrps-yiv-1629836606yiv4900545579attach-table {
width:400px;}
#ygrps-yiv-1629836606 #ygrps-yiv-1629836606yiv4900545579 div.ygrps-yiv-1629836606yiv4900545579file-title a, #ygrps-yiv-1629836606 #ygrps-yiv-1629836606yiv4900545579 div.ygrps-yiv-1629836606yiv4900545579file-title a:active, #ygrps-yiv-1629836606 #ygrps-yiv-1629836606yiv4900545579 div.ygrps-yiv-1629836606yiv4900545579file-title a:hover, #ygrps-yiv-1629836606 #ygrps-yiv-1629836606yiv4900545579 div.ygrps-yiv-1629836606yiv4900545579file-title a:visited {
#ygrps-yiv-1629836606 #ygrps-yiv-1629836606yiv4900545579 div.ygrps-yiv-1629836606yiv4900545579photo-title a, #ygrps-yiv-1629836606 #ygrps-yiv-1629836606yiv4900545579 div.ygrps-yiv-1629836606yiv4900545579photo-title a:active, #ygrps-yiv-1629836606 #ygrps-yiv-1629836606yiv4900545579 div.ygrps-yiv-1629836606yiv4900545579photo-title a:hover, #ygrps-yiv-1629836606 #ygrps-yiv-1629836606yiv4900545579 div.ygrps-yiv-1629836606yiv4900545579photo-title a:visited {
#ygrps-yiv-1629836606 #ygrps-yiv-1629836606yiv4900545579 div#ygrps-yiv-1629836606yiv4900545579ygrp-mlmsg #ygrps-yiv-1629836606yiv4900545579ygrp-msg p a span.ygrps-yiv-1629836606yiv4900545579yshortcuts {
#ygrps-yiv-1629836606 #ygrps-yiv-1629836606yiv4900545579 .ygrps-yiv-1629836606yiv4900545579green {
color:#628c2a;}
#ygrps-yiv-1629836606 #ygrps-yiv-1629836606yiv4900545579 .ygrps-yiv-1629836606yiv4900545579MsoNormal {
margin:0 0 0 0;}
#ygrps-yiv-1629836606 #ygrps-yiv-1629836606yiv4900545579 o {
font-size:0;}
#ygrps-yiv-1629836606 #ygrps-yiv-1629836606yiv4900545579 #ygrps-yiv-1629836606yiv4900545579photos div {
#ygrps-yiv-1629836606 #ygrps-yiv-1629836606yiv4900545579 #ygrps-yiv-1629836606yiv4900545579photos div div {
#ygrps-yiv-1629836606 #ygrps-yiv-1629836606yiv4900545579 #ygrps-yiv-1629836606yiv4900545579photos div label {
#ygrps-yiv-1629836606 #ygrps-yiv-1629836606yiv4900545579 #ygrps-yiv-1629836606yiv4900545579reco-category {
font-size:77%;}
#ygrps-yiv-1629836606 #ygrps-yiv-1629836606yiv4900545579 #ygrps-yiv-1629836606yiv4900545579reco-desc {
font-size:77%;}
#ygrps-yiv-1629836606 #ygrps-yiv-1629836606yiv4900545579 .ygrps-yiv-1629836606yiv4900545579replbq {
margin:4px;}
#ygrps-yiv-1629836606 #ygrps-yiv-1629836606yiv4900545579 #ygrps-yiv-1629836606yiv4900545579ygrp-actbar div a:first-child {
#ygrps-yiv-1629836606 #ygrps-yiv-1629836606yiv4900545579 #ygrps-yiv-1629836606yiv4900545579ygrp-mlmsg {
#ygrps-yiv-1629836606 #ygrps-yiv-1629836606yiv4900545579 #ygrps-yiv-1629836606yiv4900545579ygrp-mlmsg table {
#ygrps-yiv-1629836606 #ygrps-yiv-1629836606yiv4900545579 #ygrps-yiv-1629836606yiv4900545579ygrp-mlmsg select, #ygrps-yiv-1629836606 #ygrps-yiv-1629836606yiv4900545579 input, #ygrps-yiv-1629836606 #ygrps-yiv-1629836606yiv4900545579 textarea {
#ygrps-yiv-1629836606 #ygrps-yiv-1629836606yiv4900545579 #ygrps-yiv-1629836606yiv4900545579ygrp-mlmsg pre, #ygrps-yiv-1629836606 #ygrps-yiv-1629836606yiv4900545579 code {
#ygrps-yiv-1629836606 #ygrps-yiv-1629836606yiv4900545579 #ygrps-yiv-1629836606yiv4900545579ygrp-mlmsg * {
#ygrps-yiv-1629836606 #ygrps-yiv-1629836606yiv4900545579 #ygrps-yiv-1629836606yiv4900545579ygrp-mlmsg #ygrps-yiv-1629836606yiv4900545579logo {
#ygrps-yiv-1629836606 #ygrps-yiv-1629836606yiv4900545579 #ygrps-yiv-1629836606yiv4900545579ygrp-msg p a {
#ygrps-yiv-1629836606 #ygrps-yiv-1629836606yiv4900545579 #ygrps-yiv-1629836606yiv4900545579ygrp-msg p#ygrps-yiv-1629836606yiv4900545579attach-count span {
#ygrps-yiv-1629836606 #ygrps-yiv-1629836606yiv4900545579 #ygrps-yiv-1629836606yiv4900545579ygrp-reco #ygrps-yiv-1629836606yiv4900545579reco-head {
#ygrps-yiv-1629836606 #ygrps-yiv-1629836606yiv4900545579 #ygrps-yiv-1629836606yiv4900545579ygrp-reco {
#ygrps-yiv-1629836606 #ygrps-yiv-1629836606yiv4900545579 #ygrps-yiv-1629836606yiv4900545579ygrp-sponsor #ygrps-yiv-1629836606yiv4900545579ov li a {
#ygrps-yiv-1629836606 #ygrps-yiv-1629836606yiv4900545579 #ygrps-yiv-1629836606yiv4900545579ygrp-sponsor #ygrps-yiv-1629836606yiv4900545579ov li {
#ygrps-yiv-1629836606 #ygrps-yiv-1629836606yiv4900545579 #ygrps-yiv-1629836606yiv4900545579ygrp-sponsor #ygrps-yiv-1629836606yiv4900545579ov ul {
#ygrps-yiv-1629836606 #ygrps-yiv-1629836606yiv4900545579 #ygrps-yiv-1629836606yiv4900545579ygrp-text {
#ygrps-yiv-1629836606 #ygrps-yiv-1629836606yiv4900545579 #ygrps-yiv-1629836606yiv4900545579ygrp-text p {
margin:0 0 1em 0;}
#ygrps-yiv-1629836606 #ygrps-yiv-1629836606yiv4900545579 #ygrps-yiv-1629836606yiv4900545579ygrp-text tt {
font-size:120%;}
#ygrps-yiv-1629836606 #ygrps-yiv-1629836606yiv4900545579 #ygrps-yiv-1629836606yiv4900545579ygrp-vital ul li:last-child {
Patricia Hall
Systems Analyst
T: 256.978.6294
C: 256.366.8697
F: 256.383.8224
www.cbcings.com
Patricia Hall
Systems Analyst
T: 256.978.6294
www.cbcings.com
-Todd
Hi all,
Thank you,
Patricia Hall
Systems Analyst
CBC INGS AMERICA
www.cbcings.com
