We have added a formula column into the dropship grid and a field that totals this new column to the form.
This code is run under a Grid_InitializeRow handle.
The issue we are facing is that when a drop ship line is added, it does not seem to hit this handle so our fields are blank. If a row is deleted, or the user exits and re-enters the form then the fields are populated correctly. Does anyone know why when either adding a mass shipment/ get all or adding a single line this code is not firing? Following is the code we currently have
' Custom code for DropShipForm
' Created: 6/13/2013 9:21:31 AM
' Author: Daniel Milano
' Receipt/ship date clears out before update
' Saves DropShipHead.ReceiptDate date and inserts before update
' Zero cost error message done by Bob G.
' Daniel Milano - Aug 19 2013:
' Add Tracking number
' UD field for weight
' UD field for unit of measure
' Button to view URL for tracking
' DEV 179 - August 28 2013
' Drop Ship Lines
' DEV221 - October 14 2013
' Future ship date warning -- asks user if current ship date should be used if ship date is in future.
Imports System
Imports System.Collections
Imports System.ComponentModel
Imports System.Data
Imports System.Diagnostics
Imports System.Windows.Forms
Imports Microsoft.VisualBasic
Imports Epicor.Mfg.BO
Imports Epicor.Mfg.UI
Imports Epicor.Mfg.UI.Adapters
Imports Epicor.Mfg.UI.Customization
Imports Epicor.Mfg.UI.ExtendedProps
Imports Epicor.Mfg.UI.FormFunctions
Imports Epicor.Mfg.UI.FrameWork
Imports Epicor.Mfg.UI.Searches
Imports Infragistics.Win.UltraWinGrid '//DEV179 Daniel Milano
Public Class Script
' ** Wizard Insert Location - Do Not Remove 'Begin/End Wizard Added Module Level Variables' Comments! **
' Begin Wizard Added Module Level Variables **
private tempDate as Date
private totalvendorcost as double
private totalourcost as double
private i as integer
private ponumber as integer
Private WithEvents oTrans_adapter As EpiBaseAdapter
private uomclass as UOMClassAdapter
dim WithEvents ReceiptsGrid As EpiUltraGrid
Private WithEvents edvMultiKeySearch As EpiDataView
Private WithEvents MultiKeySearch_DataView As DataView
Private WithEvents DropShipDtl_DataView As DataView
' End Wizard Added Module Level Variables **
' Add Custom Module Level Variables Here **
Public Sub InitializeCustomCode()
' ** Wizard Insert Location - Do not delete 'Begin/End Wizard Added Variable Initialization' lines **
' Begin Wizard Added Variable Initialization
AddHandler Me.DropShipHead_Column.ColumnChanged, AddressOf Me.DropShipHead_AfterFieldChange
tempDate = now()
totalvendorcost = 0
totalourcost = 0
i = 0
ponumber = 0
Me.oTrans_adapter = CType(Me.csm.TransAdaptersHT("oTrans_adapter"),EpiBaseAdapter)
AddHandler Me.oTrans_adapter.AfterAdapterMethod, AddressOf Me.oTrans_adapter_AfterAdapterMethod
AddHandler Me.oTrans_adapter.BeforeAdapterMethod, AddressOf Me.oTrans_adapter_BeforeAdapterMethod
AddHandler Me.DropShipHead_Column.ColumnChanging, AddressOf Me.DropShipHead_BeforeFieldChange
Me.edvMultiKeySearch = CType(Me.oTrans.EpiDataViews("MultiKeySearch"),EpiDataView)
Me.MultiKeySearch_DataView = Me.MultiKeySearch_Row.dataView
AddHandler Me.MultiKeySearch_DataView.ListChanged, AddressOf Me.MultiKeySearch_DataView_ListChanged
Me.DropShipDtl_DataView = Me.DropShipDtl_Row.dataView
AddHandler Me.DropShipDtl_Row.EpiRowChanged, AddressOf Me.DropShipDtl_AfterRowChange
' End Wizard Added Variable Initialization
' Begin Wizard Added Custom Method Calls
AddHandler Me.UOMList.Click, AddressOf Me.UOMList_Click
AddHandler Me.btnURL.Click, AddressOf Me.btnURL_Click
' End Wizard Added Custom Method Calls
ReceiptsGrid = ctype(csm.GetNativeControlReference("87f88dc8-1b94-4324-ba83-583a2af5cbb9"), Epicor.Mfg.UI.FrameWork.EpiUltraGrid)
ReceiptsGrid.DisplayLayout.Bands(0).Columns.Add("SupplierExtCost", "Supplier Cost")
ReceiptsGrid.DisplayLayout.Bands(0).Columns.Add("OurExtCost", "Our Cost")
ReceiptsGrid.DisplayLayout.Bands(0).Columns("SupplierExtCost").Header.VisiblePosition = 24
ReceiptsGrid.DisplayLayout.Bands(0).Columns("SupplierExtCost").CellAppearance.TextHAlign = Infragistics.Win.HAlign.Right
ReceiptsGrid.DisplayLayout.Bands(0).Columns("OurExtCost").CellAppearance.TextHAlign = Infragistics.Win.HAlign.Right
' AddHandler ReceiptsGrid.AfterRowUpdate , AddressOf ReceiptsGrid_AfterRowUpdate
AddHandler ReceiptsGrid.InitializeRow , AddressOf ReceiptsGrid_InitializeRow
End Sub
Public Sub DestroyCustomCode()
' ** Wizard Insert Location - Do not delete 'Begin/End Wizard Added Object Disposal' lines **
' Begin Wizard Added Object Disposal
RemoveHandler Me.DropShipHead_Column.ColumnChanged, AddressOf Me.DropShipHead_AfterFieldChange
RemoveHandler Me.oTrans_adapter.AfterAdapterMethod, AddressOf Me.oTrans_adapter_AfterAdapterMethod
Me.oTrans_adapter = Nothing
RemoveHandler Me.oTrans_adapter.BeforeAdapterMethod, AddressOf Me.oTrans_adapter_BeforeAdapterMethod
RemoveHandler Me.UOMList.Click, AddressOf Me.UOMList_Click
RemoveHandler Me.btnURL.Click, AddressOf Me.btnURL_Click
RemoveHandler Me.DropShipHead_Column.ColumnChanging, AddressOf Me.DropShipHead_BeforeFieldChange
RemoveHandler ReceiptsGrid.InitializeRow , AddressOf ReceiptsGrid_InitializeRow
' RemoveHandler ReceiptsGrid.AfterRowUpdate , AddressOf ReceiptsGrid_AfterRowUpdate
Me.edvMultiKeySearch = Nothing
RemoveHandler Me.MultiKeySearch_DataView.ListChanged, AddressOf Me.MultiKeySearch_DataView_ListChanged
Me.MultiKeySearch_DataView = Nothing
Me.DropShipDtl_DataView = Nothing
RemoveHandler Me.DropShipDtl_Row.EpiRowChanged, AddressOf Me.DropShipDtl_AfterRowChange
' End Wizard Added Object Disposal
' Begin Custom Code Disposal
tempDate = nothing
' End Custom Code Disposal
End Sub
Private Sub DropShipHead_AfterFieldChange(ByVal sender As Object, ByVal args As DataColumnChangeEventArgs)
' ** Argument Properties and Uses **
' args.Row("FieldName")
' args.Column, args.ProposedValue, args.Row
' Add Event Handler Code
Select Case args.Column.ColumnName
Case "ReceiptDate"
Dim HeaderView As EpiDataView = CType(oTrans.EpiDataViews("DropShipHead"), EpiDataView)
if(not isdbnull(HeaderView.dataView(HeaderView.Row)("ReceiptDate")) and not isdbnull(tempDate))then
tempDate = HeaderView.dataView(HeaderView.Row)("ReceiptDate")
end if
HeaderView = nothing
End Select
End Sub
private sub ReceiptsGrid_InitializeRow(ByVal sender as object, ByVal e As Infragistics.Win.UltraWinGrid.InitializeRowEventArgs)Handles ReceiptsGrid.InitializeRow
try
if(i = 0 or e.Row.Index = i)then
if(e.Row.Index = 0)then
curTotalSupplierExtCost.Value = 0
totalvendorcost = 0
totalourcost = 0
end if
Dim suppliercost As Decimal = 0
Dim ourcost As Decimal = 0
suppliercost = double.parse(e.Row.Cells("VendorQty").Value) * double.parse(e.Row.Cells("VendorUnitCost").Value)
ourcost = double.parse(e.Row.Cells("OurQty").Value) * double.parse(e.Row.Cells("OurUnitCost").Value)
e.Row.Cells("SupplierExtCost").Value = suppliercost.ToString("F")
e.Row.Cells("OurExtCost").Value = ourcost.ToString("F")
totalvendorcost += suppliercost
totalourcost += ourcost
curTotalSupplierExtCost.Value = totalvendorcost
i += 1
end if
catch ex as exception
messagebox.show(ex.message)
end try
end sub
Private Sub oTrans_adapter_AfterAdapterMethod(ByVal sender As Object, ByVal args As AfterAdapterMethodArgs)
' ** args.MethodName **
' ** Add Event Handler Code **
' ** Use MessageBox to find adapter method name
' EpiMessageBox.Show(args.MethodName)
Select Case args.MethodName
Case "Update"
HeaderView.dataView(HeaderView.Row)("ReceiptDate") = tempDate
Dim e As Infragistics.Win.UltraWinGrid.InitializeRowEventArgs
End Select
End Sub
Private Sub oTrans_adapter_BeforeAdapterMethod(ByVal sender As Object, ByVal args As BeforeAdapterMethodArgs)
'Added by Bob G.
Case "Update"
Dim DetailView As EpiDataView = CType(oTrans.EpiDataViews("DropShipDtl"), EpiDataView)
Dim ErrMsg as string
for each row as datarow in DetailView.dataView.Table.Rows
if row("OurUnitCost") = 0 then
ErrMsg = ErrMsg & Environment.NewLine & row("PartNum")& " has Zero cost"
End if
next
If ErrMsg <> "" then
Dim dialogResult As DialogResult = EpiMessageBox.Show(ErrMsg, "Cancel", MessageBoxButtons.YesNo)
If (dialogResult = DialogResult.Yes) Then
args.Cancel = true
End If
End If
End Select
End Sub
Private Sub UOMList_Click(ByVal sender As Object, ByVal args As System.EventArgs)
' ** Place Event Handling Code Here **
uomclass = new UOMClassAdapter(oTrans)
uomclass.BOConnect()
Dim dsUOMClassAdapter As System.Data.DataSet = uomclass.Getdata("weight")
dim table as datatable
dim row as datarow
dim column as datacolumn
dim uomlists as new ArrayList()
for each row in dsUOMClassAdapter.tables(1).rows
uomlists.add(row(2))
next row
'Set EpiUltraCombo Properties
Me.UOMList.datasource = uomlists
End Sub
Private Sub btnURL_Click(ByVal sender As Object, ByVal args As System.EventArgs)
Dim tracking As EpiDataView = CType(oTrans.EpiDataViews("DropShipHead"), EpiDataView)
dim shipviacode = ""
shipviacode = tracking.dataView(tracking.Row)("ShipViaCode")
dim trackingURL as string
dim placeURL as string
dim trackingnumber as string
trackingURL = ""
placeURL = ""
trackingnumber = ""
Dim recSelected As Boolean
Dim whereClause As String = "shipviacode = '" & shipviacode & "'"
Dim ds As System.Data.DataSet = Epicor.Mfg.UI.FormFunctions.SearchFunctions.listLookup(Me.oTrans, "ShipViaAdapter", recSelected, false, whereClause)
If recSelected Then
trackingURL = ds.tables(0).rows(0)(5)
placeURL = ds.tables(0).rows(0)(6)
End If
recSelected = nothing
whereClause = nothing
ds = nothing
'//tracking number provided by carrier
trackingnumber = tracking.dataView(tracking.Row)("TrackingNumber")
'//error checking
if(shipviacode = "")then
messagebox.show("Ship Via is Blank.", "Error", MessageboxButtons.OK, MessageBoxIcon.Exclamation)
tracking = nothing
exit sub
end if
if(trackingURL = "")then
messagebox.show("No Tracking URL found on the ShipVia setup.", "Error", MessageboxButtons.OK, MessageBoxIcon.Exclamation)
tracking = nothing
exit sub
elseif(trackingnumber = "")then
messagebox.show("Tracking number has not been provided.", "Error", MessageboxButtons.OK, MessageBoxIcon.Exclamation)
tracking = nothing
exit sub
else
'//creates actual tracking url by replaceing the place holder
trackingURL = trackingURL.replace(placeURL, trackingnumber)
process.start("iexplore.exe", trackingurl)
end if
tracking = nothing
end sub
Private Sub DropShipHead_BeforeFieldChange(ByVal sender As Object, ByVal args As DataColumnChangeEventArgs)
Case "ReceiptDate"
Try
If Convert.ToDateTime(args.ProposedValue) < DateTime.Today Then
Dim result As DialogResult = MessageBox.Show("Ship date occurs prior to today's date. Do you want to change the ship date to today's date?", "Future Ship Date", MessageBoxButtons.YesNo, MessageBoxIcon.Exclamation)
If result = DialogResult.Yes Then
args.ProposedValue = DateTime.Today
End If
End If
Catch e As Exception
End Try
End Select
End Sub
Private Sub MultiKeySearch_DataView_ListChanged(ByVal sender As Object, ByVal args As ListChangedEventArgs)
' MultiKeySearch_DataView(0)("FieldName")
' args.ListChangedType, args.NewIndex, args.OldIndex
' ListChangedType.ItemAdded, ListChangedType.ItemChanged, ListChangedType.ItemDeleted, ListChangedType.ItemMoved, ListChangedType.Reset
if(integer.parse(MultiKeySearch_DataView(0)("ponum")) = 0 or integer.parse(MultiKeySearch_DataView(0)("ponum")) <> ponumber)then
ponumber = integer.parse(MultiKeySearch_DataView(0)("ponum"))
i = 0
end if
End Sub
Private Sub DropShipDtl_AfterRowChange(ByVal args As EpiRowChangedArgs)
' args.CurrentView.dataView(args.CurrentRow)("FieldName")
' args.LastRow, args.CurrentRow, args.CurrentView
End Sub
End Class
