I am curious if this is possible. I have failed at attempting this so far. I am wondering if others may have a solution.
I am trying to save the round trips to Epicor. I have a problem where I am adding let’s say 60 releases for an order. To save time, I was thinking I could call ‘GetNewOrderRel’ 60 times and then call Update just once at the end. To me, it seems like the GetNewOrderRel row only lets you have one record with a RowMod of ‘A’. The first call adds the new record, but every subsequent call doesn’t seem to do anything.
Does anyone have a different idea on how to add all these releases in a more performant way?
I’ll try it at least and see what happens. Question – UpdateExt has you pass in the DataSet. My issue is that the DataSet is not getting multiple records added to it. How else would I add in the new added rows to the Table?
So the UpdateExt takes a different dataset then the standard method, you’ll need to make it (are you doing this via a customization? integratino? wcf, ? rest?)
