Adding/defining a new ReportParam value?
Hi team
I want to modify an existing report, One I didn’t create.
I need to add an additional option using the ReportParam using a check box. I have added the option to the BAQ Report Designer but now how to I define the value which must be matched to? I can’t find the ReportParam table or an option to add to it.
Any help would be appreciated
The report XML data will carry the parameter.
Depending if this is a crystal or SSRS report.
In Crystal open the report in the crystal report designer an pull I. The
data source.
The report parameter section of the data will be available.
Brad
