Adding checkbox to issue material
It updated the material record yes.
To: "vantage@yahoogroups.com" <vantage@yahoogroups.com>
Sent: Tuesday, June 19, 2012 11:55 AM
Subject: RE: [Vantage] Adding checkbox to issue material
Ted,
I can't say just by glancing at it. I can almost always work through most VB code but it takes wading through it in an actual environment. Unlike some very smart folks on here (you know who you are lol) for me a lot of times its not readily apparent what the best way is. First thing I noticed is you might consider doing a getrows instead of a getbyid, it will reduce the size of your dataset greatly and improve performance (you won't need most of the data dragged over from a getbyid). But since I'm not a programmer by trade I'm never sure if I'm always doing things in the most efficient manner lol! Usually when I get a record using another adapter and subsequently update it ive done a beginedit and endedit with the changed row in between.. But there are many ways to accomplish the same thing in VB and I'm always picking up new ones. Does your code update the material record?
Rob Bucek
Production Control Manager
PH: (715) 284-5376 ext 311
Mobile: (715)896-0590
FAX: (715)284-4084
[Description: cid:1.234354861@...]<http://www.dsmfg.com/>
(Click the logo to view our site)<http://www.dsmfg.com/>
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Ted Koch
Sent: Tuesday, June 19, 2012 10:19 AM
Subject: Re: [Vantage] Adding checkbox to issue material
Rob, is this how you would do it? I really didn't know what I was doing but came up with this and it appears to work. Thanks.
  Private Sub CallUpdateJobMtl()
    Try
      ' Declare and Initialize EpiDataView Variables
      Dim edvIM As EpiDataView = CType(Me.oTrans.EpiDataViews("IM"),EpiDataView)
      ' Check if valid EpiDataView Row(s) are selected
      If (edvIM.Row < 0) Then
        Return
      End If
      ' Declare and create an instance of the Adapter.
      Dim adapterJobEntry As JobEntryAdapter = New JobEntryAdapter(Me.oTrans)
      adapterJobEntry.BOConnect
      ' Declare and Initialize Variables
      Dim jobNum As String = CType(edvIM.dataView(edvIM.Row)("ToJobNum"),String)
      Dim asm As String = CType(edvIM.dataView(edvIM.Row)("ToAssemblySeq"),String)
      Dim mtlSeq As String = CType(edvIM.dataView(edvIM.Row)("ToJobSeq"),String)
      ' Call Adapter method
      Dim result As Boolean = adapterJobEntry.GetByID(jobNum)
      Dim jobDS As JobEntryDataSet = adapterJobEntry.JobEntryData
      Dim dt as new DataTable
      dt = jobDS.Tables("JobMtl")
      For i as integer = 0 To dt.rows.count - 1
        If dt.Rows(i)("JobNum") = jobNum AND dt.Rows(i)("AssemblySeq") = asm AND dt.Rows(i)("MtlSeq") = mtlSeq Then
          dt.Rows(i)("IssuedComplete") = true
        End If
      Next
      'dt.Rows(0)("IssuedComplete") = true
      Dim res As Boolean = adapterJobEntry.Update()
      ' Cleanup Adapter Reference
      adapterJobEntry.Dispose
    Catch ex As System.Exception
      ExceptionBox.Show(ex)
    End Try
  End Sub
From: Rob Bucek <rbucek@...<mailto:rbucek%40dsmfg.com>>
To: "vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>" <vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>>
Sent: Tuesday, June 19, 2012 10:26 AM
Jobentry would work..
Rob Bucek
FAX: (715)284-4084
[Description: cid:1.234354861@...<mailto:1.234354861%40web65412.mail.ac4.yahoo.com>]<http://www.dsmfg.com/>
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of Ted Koch
Sent: Tuesday, June 19, 2012 9:18 AM
How would you bring in the dataview if the object explorer says it's not available? Or would you use the JobEntryAdapter?
From: John Driggers <waffqle@...<mailto:waffqle%40gmail.com><mailto:waffqle%40gmail.com>>
To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>
Sent: Tuesday, June 19, 2012 9:51 AM
You can either bring in the dataview, or just create a little function to
lookup the jobmtl record and toggle the bit when someone ticks the box.
*John Driggers*
*High End Dev, System Design, Profit Drinking*
**:: 904.404.9233*
*:: waffqle@...<mailto:waffqle%40gmail.com><mailto:waffqle%40gmail.com>*
*:: NO FAXES*
On Tue, Jun 19, 2012 at 9:49 AM, Ted Koch <tkoch77@...<mailto:tkoch77%40yahoo.com><mailto:tkoch77%40yahoo.com>> wrote:
> Is there a way to directly update a job material record if the dataview
> isn't available?
> Sent: Tuesday, June 19, 2012 9:29 AM
> There isn't an 'issue material' table to store this on. I'd suggest you put
> some logic in your UI to go back and find the JobMtl record and mark it
> there. BPM probably isn't what you want here.
> *John Driggers*
> **:: 904.404.9233*
> *:: NO FAXES*
> On Mon, Jun 18, 2012 at 5:25 PM, Ted Koch <tkoch77@...<mailto:tkoch77%40yahoo.com><mailto:tkoch77%40yahoo.com>> wrote:
> > What the BPM does is mark that material as being issued, but since they
> > used scrap we dont want it to mess with inventory.
> > From: Rob Bucek <rbucek@...<mailto:rbucek%40dsmfg.com><mailto:rbucek%40dsmfg.com>>
> > To: "vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>" <vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>>
> > Sent: Monday, June 18, 2012 5:19 PM
> > Ultimately what are you attempting to do? Could you do a UI
> customization
> > on an unbound checkbox and perform your logic within there?
> > Rob Bucek
> > FAX: (715)284-4084
> > [Description: cid:1.234354861@...<mailto:1.234354861%40web65412.mail.ac4.yahoo.com><mailto:1.234354861%40web65412.mail.ac4.yahoo.com>]<
> > From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>] On Behalf
> > Of tkoch77
> > Sent: Monday, June 18, 2012 3:21 PM
> > Subject: [Vantage] Adding checkbox to issue material
> > I have added a checkbox to the Issue Material form, the user is to check
> > this checkbox if they used scrap for the issued material. I want to
> trigger
> > a bpm based off this checkbox. However the issue I am running into is
> there
> > is no UD field available for use. I tried using
> > CallContextBpmData.Checkbox01 and this doesnt seem to work.
> > I also tried updating the field with some code on the checkedchanged
> event
> > for the checkbox. I know its not assigning it because in a pre-processing
> > directive and set it up to show informational message and it is saying
> the
> > value is NO for CallContextBpmData.checkbox01.
> > Attempting this on the IssueReturn.PerformMaterialMovement method.
> > Thanks for any help,
> > Ted
> > Useful links for the Yahoo!Groups Vantage Board are: ( Note:Â You must
> > have already linked your email address to a yahoo id to enable access. )
> > (1) To access the Files Section of our Yahoo!Group for Report Builder and
> > Crystal Reports and other 'goodies', please goto:
> > http://groups.yahoo.com/group/vantage/files/.<http://groups.yahoo.com/group/vantage/files/><http://groups.yahoo.com/group/vantage/files/>
> > http://groups.yahoo.com/group/vantage/messages
> > (3) To view links to Vendors that provide Vantage services goto:
> > http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
Useful links for the Yahoo!Groups Vantage Board are: ( Note:Â You must have already linked your email address to a yahoo id to enable access. )
(1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups.yahoo.com/group/vantage/files/.<http://groups.yahoo.com/group/vantage/files/><http://groups.yahoo.com/group/vantage/files/>
(1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups.yahoo.com/group/vantage/files/.%c2%a0
I have added a checkbox to the Issue Material form, the user is to check this checkbox if they used scrap for the issued material. I want to trigger a bpm based off this checkbox. However the issue I am running into is there is no UD field available for use. I tried using CallContextBpmData.Checkbox01 and this doesnt seem to work.
I also tried updating the field with some code on the checkedchanged event for the checkbox. I know its not assigning it because in a pre-processing directive and set it up to show informational message and it is saying the value is NO for CallContextBpmData.checkbox01.
Ted
Ultimately what are you attempting to do? Could you do a UI customization on an unbound checkbox and perform your logic within there?
Rob Bucek
FAX: (715)284-4084
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of tkoch77
Ted
What the BPM does is mark that material as being issued, but since they used scrap we dont want it to mess with inventory.
Rob Bucek
FAX: (715)284-4084
Ted
*John Driggers*
**:: 904.404.9233*
*:: waffqle@...*
*:: NO FAXES*
> From: Rob Bucek <rbucek@...>
> Rob Bucek
> FAX: (715)284-4084
> Of tkoch77
> Ted
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
Is there a way to directly update a job material record if the dataview isn't available?
*John Driggers*
**:: 904.404.9233*
*:: waffqle@...*
*:: NO FAXES*
> Rob Bucek
> FAX: (715)284-4084
> Of tkoch77
> Ted
*John Driggers*
**:: 904.404.9233*
*:: waffqle@...*
*:: NO FAXES*
> isn't available?
> From: John Driggers <waffqle@...>
> *John Driggers*
> **:: 904.404.9233*
> *:: waffqle@...*
> *:: NO FAXES*
> customization
> > Rob Bucek
> > FAX: (715)284-4084
> > Of tkoch77
> trigger
> there
> event
> the
> > Ted
*John Driggers*
**:: 904.404.9233*
*:: waffqle@...*
*:: NO FAXES*
> isn't available?
> *John Driggers*
> **:: 904.404.9233*
> *:: waffqle@...*
> *:: NO FAXES*
> customization
> > Rob Bucek
> > FAX: (715)284-4084
> > Of tkoch77
> trigger
> there
> event
> the
> > Ted
Rob Bucek
FAX: (715)284-4084
From: John Driggers <waffqle@...<mailto:waffqle%40gmail.com>>
*John Driggers*
**:: 904.404.9233*
*:: waffqle@...<mailto:waffqle%40gmail.com>*
*:: NO FAXES*
On Tue, Jun 19, 2012 at 9:49 AM, Ted Koch <tkoch77@...<mailto:tkoch77%40yahoo.com>> wrote:
> isn't available?
> *John Driggers*
> **:: 904.404.9233*
> *:: NO FAXES*
> On Mon, Jun 18, 2012 at 5:25 PM, Ted Koch <tkoch77@...<mailto:tkoch77%40yahoo.com>> wrote:
> customization
> > Rob Bucek
> > FAX: (715)284-4084
> > Of tkoch77
> trigger
> there
> event
> the
> > Ted
      Try
            Return
         End If
                 Â
            End If
         Next  Â
  Â
      End Try
   End Sub
Rob Bucek
FAX: (715)284-4084
*John Driggers*
**:: 904.404.9233*
*:: NO FAXES*
> isn't available?
> *John Driggers*
> **:: 904.404.9233*
> *:: NO FAXES*
> customization
> > Rob Bucek
> > FAX: (715)284-4084
> > Of tkoch77
> trigger
> there
> event
> the
> > Ted
Ted,
Rob Bucek
FAX: (715)284-4084
Try
Return
End If
End If
Next
End Try
End Sub
Rob Bucek
FAX: (715)284-4084
*John Driggers*
**:: 904.404.9233*
*:: NO FAXES*
> isn't available?
> *John Driggers*
> **:: 904.404.9233*
> *:: NO FAXES*
> customization
> > Rob Bucek
> > FAX: (715)284-4084
> > Of tkoch77
> trigger
> there
> event
> the
> > Ted
