Adding a table to a report data definition report
Thank you Karen! I added the part table to the RDD ARForm! I just created the relationship and made sure the linked fields from the relationship fields were included in the table. I am working on the other tables and will put it here for future reference. I am on vantage 8.03.409C as well.
Hello all,
i copy a system report (EDIARFrm) and need to add tables to it (BOLHead,BOLdetail,orderhed,part, etc) so i went to the report table tab and add the tables above. Then i included the fields i needed from each table. Is there anything else i am missing i need to do to add the table to the report?
Anyways when i print the report the tables do not show up in the reports schema? What am i missing? thank you in advance!
Jose
Thanks Karen. My first time adding a table to RDD. i will try adding the relationship and follow up. The relation will be different depending on each table. i will experiment with one table at a time. thanks for pointing me in the right direction!!
Jose
Now my report is blank? i tried adding the part table and did a relationship with invdtl.
Thanks Karen. Yes i am working in my Test environment. I did a new relationship. Parent table invdtl key inline and child table is part.
i added relationship fields company, and part num. Missing something?
