QuoteForm_Load(object sender, EventArgs args)
Add Event Handler Code
myGrid =
(EpiUltraGrid)csm.GetNativeControlReference("73bddcdc-c164-4d92-804b-7309ce973d36");
= epiComboC6;
<div id="ygrps-yiv-315487809yiv1808552570ygrp-text">
<div>Hi everyone,</div>
Dim whereClause As String = String.empty
Dim dsSales As DataSet = Epicor.Mfg.UI.FormFunctions.SearchFunctions.listLookup(oTrans,"SalesCatAdapter", recSelected, False,whereClause)
Dim Fields As String() = New String(){"Description"}
If (recSelected) Then
ucbDescrip.ValueMember = "SalesCatID"
ucbDescrip.DataSource = dsSales
ucbDescrip.DisplayMember = "Description"
ucbDescrip.SetColumnFilter(Fields)
Dim grdSummaryOrderLines AS EpiUltragrid = Ctype(csm.GetNativeControlReference("bec51417-b286-4d61-a471-3912bc098905"),EpiUltraGrid)
grdSummaryOrderLines.DisplayLayout.Bands(0).Columns("SalesCatID").Style = Infragistics.Win.UltraWinGrid.ColumnStyle.DropDownList
grdSummaryOrderLines.DisplayLayout.Override.AllowUpdate = Infragistics.Win .DefaultableBoolean .True
End sub
</div>
<div style="height:0px;color:rgb(255, 255, 255);"></div></div>
#ygrps-yiv-315487809 #ygrps-yiv-315487809yiv1808552570 #ygrps-yiv-315487809yiv1808552570ygrp-mkp hr {
border:1px solid #d8d8d8;}
#ygrps-yiv-315487809 #ygrps-yiv-315487809yiv1808552570 #ygrps-yiv-315487809yiv1808552570ygrp-mkp #ygrps-yiv-315487809yiv1808552570hd {
color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;}
#ygrps-yiv-315487809 #ygrps-yiv-315487809yiv1808552570 #ygrps-yiv-315487809yiv1808552570ygrp-mkp #ygrps-yiv-315487809yiv1808552570ads {
margin-bottom:10px;}
#ygrps-yiv-315487809 #ygrps-yiv-315487809yiv1808552570 #ygrps-yiv-315487809yiv1808552570ygrp-mkp .ygrps-yiv-315487809yiv1808552570ad {
padding:0 0;}
#ygrps-yiv-315487809 #ygrps-yiv-315487809yiv1808552570 #ygrps-yiv-315487809yiv1808552570ygrp-mkp .ygrps-yiv-315487809yiv1808552570ad p {
margin:0;}
#ygrps-yiv-315487809 #ygrps-yiv-315487809yiv1808552570 #ygrps-yiv-315487809yiv1808552570ygrp-mkp .ygrps-yiv-315487809yiv1808552570ad a {
color:#0000ff;text-decoration:none;}
#ygrps-yiv-315487809 #ygrps-yiv-315487809yiv1808552570 #ygrps-yiv-315487809yiv1808552570ygrp-sponsor #ygrps-yiv-315487809yiv1808552570ygrp-lc {
font-family:Arial;}
#ygrps-yiv-315487809 #ygrps-yiv-315487809yiv1808552570 #ygrps-yiv-315487809yiv1808552570ygrp-sponsor #ygrps-yiv-315487809yiv1808552570ygrp-lc #ygrps-yiv-315487809yiv1808552570hd {
margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;}
#ygrps-yiv-315487809 #ygrps-yiv-315487809yiv1808552570 #ygrps-yiv-315487809yiv1808552570ygrp-sponsor #ygrps-yiv-315487809yiv1808552570ygrp-lc .ygrps-yiv-315487809yiv1808552570ad {
margin-bottom:10px;padding:0 0;}
#ygrps-yiv-315487809 #ygrps-yiv-315487809yiv1808552570 #ygrps-yiv-315487809yiv1808552570actions {
font-family:Verdana;font-size:11px;padding:10px 0;}
#ygrps-yiv-315487809 #ygrps-yiv-315487809yiv1808552570 #ygrps-yiv-315487809yiv1808552570activity {
background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}
#ygrps-yiv-315487809 #ygrps-yiv-315487809yiv1808552570 #ygrps-yiv-315487809yiv1808552570activity span {
font-weight:700;}
#ygrps-yiv-315487809 #ygrps-yiv-315487809yiv1808552570 #ygrps-yiv-315487809yiv1808552570activity span:first-child {
text-transform:uppercase;}
#ygrps-yiv-315487809 #ygrps-yiv-315487809yiv1808552570 #ygrps-yiv-315487809yiv1808552570activity span a {
color:#5085b6;text-decoration:none;}
#ygrps-yiv-315487809 #ygrps-yiv-315487809yiv1808552570 #ygrps-yiv-315487809yiv1808552570activity span span {
color:#ff7900;}
#ygrps-yiv-315487809 #ygrps-yiv-315487809yiv1808552570 #ygrps-yiv-315487809yiv1808552570activity span .ygrps-yiv-315487809yiv1808552570underline {
text-decoration:underline;}
#ygrps-yiv-315487809 #ygrps-yiv-315487809yiv1808552570 .ygrps-yiv-315487809yiv1808552570attach {
clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;}
#ygrps-yiv-315487809 #ygrps-yiv-315487809yiv1808552570 .ygrps-yiv-315487809yiv1808552570attach div a {
#ygrps-yiv-315487809 #ygrps-yiv-315487809yiv1808552570 .ygrps-yiv-315487809yiv1808552570attach img {
border:none;padding-right:5px;}
#ygrps-yiv-315487809 #ygrps-yiv-315487809yiv1808552570 .ygrps-yiv-315487809yiv1808552570attach label {
display:block;margin-bottom:5px;}
#ygrps-yiv-315487809 #ygrps-yiv-315487809yiv1808552570 .ygrps-yiv-315487809yiv1808552570attach label a {
#ygrps-yiv-315487809 #ygrps-yiv-315487809yiv1808552570 blockquote {
margin:0 0 0 4px;}
#ygrps-yiv-315487809 #ygrps-yiv-315487809yiv1808552570 .ygrps-yiv-315487809yiv1808552570bold {
font-family:Arial;font-size:13px;font-weight:700;}
#ygrps-yiv-315487809 #ygrps-yiv-315487809yiv1808552570 .ygrps-yiv-315487809yiv1808552570bold a {
#ygrps-yiv-315487809 #ygrps-yiv-315487809yiv1808552570 dd.ygrps-yiv-315487809yiv1808552570last p a {
font-family:Verdana;font-weight:700;}
#ygrps-yiv-315487809 #ygrps-yiv-315487809yiv1808552570 dd.ygrps-yiv-315487809yiv1808552570last p span {
margin-right:10px;font-family:Verdana;font-weight:700;}
#ygrps-yiv-315487809 #ygrps-yiv-315487809yiv1808552570 dd.ygrps-yiv-315487809yiv1808552570last p span.ygrps-yiv-315487809yiv1808552570yshortcuts {
margin-right:0;}
#ygrps-yiv-315487809 #ygrps-yiv-315487809yiv1808552570 div.ygrps-yiv-315487809yiv1808552570attach-table div div a {
#ygrps-yiv-315487809 #ygrps-yiv-315487809yiv1808552570 div.ygrps-yiv-315487809yiv1808552570attach-table {
width:400px;}
#ygrps-yiv-315487809 #ygrps-yiv-315487809yiv1808552570 div.ygrps-yiv-315487809yiv1808552570file-title a, #ygrps-yiv-315487809 #ygrps-yiv-315487809yiv1808552570 div.ygrps-yiv-315487809yiv1808552570file-title a:active, #ygrps-yiv-315487809 #ygrps-yiv-315487809yiv1808552570 div.ygrps-yiv-315487809yiv1808552570file-title a:hover, #ygrps-yiv-315487809 #ygrps-yiv-315487809yiv1808552570 div.ygrps-yiv-315487809yiv1808552570file-title a:visited {
#ygrps-yiv-315487809 #ygrps-yiv-315487809yiv1808552570 div.ygrps-yiv-315487809yiv1808552570photo-title a, #ygrps-yiv-315487809 #ygrps-yiv-315487809yiv1808552570 div.ygrps-yiv-315487809yiv1808552570photo-title a:active, #ygrps-yiv-315487809 #ygrps-yiv-315487809yiv1808552570 div.ygrps-yiv-315487809yiv1808552570photo-title a:hover, #ygrps-yiv-315487809 #ygrps-yiv-315487809yiv1808552570 div.ygrps-yiv-315487809yiv1808552570photo-title a:visited {
#ygrps-yiv-315487809 #ygrps-yiv-315487809yiv1808552570 div#ygrps-yiv-315487809yiv1808552570ygrp-mlmsg #ygrps-yiv-315487809yiv1808552570ygrp-msg p a span.ygrps-yiv-315487809yiv1808552570yshortcuts {
font-family:Verdana;font-size:10px;font-weight:normal;}
#ygrps-yiv-315487809 #ygrps-yiv-315487809yiv1808552570 .ygrps-yiv-315487809yiv1808552570green {
color:#628c2a;}
#ygrps-yiv-315487809 #ygrps-yiv-315487809yiv1808552570 .ygrps-yiv-315487809yiv1808552570MsoNormal {
margin:0 0 0 0;}
#ygrps-yiv-315487809 #ygrps-yiv-315487809yiv1808552570 o {
font-size:0;}
#ygrps-yiv-315487809 #ygrps-yiv-315487809yiv1808552570 #ygrps-yiv-315487809yiv1808552570photos div {
float:left;width:72px;}
#ygrps-yiv-315487809 #ygrps-yiv-315487809yiv1808552570 #ygrps-yiv-315487809yiv1808552570photos div div {
border:1px solid #666666;height:62px;overflow:hidden;width:62px;}
#ygrps-yiv-315487809 #ygrps-yiv-315487809yiv1808552570 #ygrps-yiv-315487809yiv1808552570photos div label {
color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}
#ygrps-yiv-315487809 #ygrps-yiv-315487809yiv1808552570 #ygrps-yiv-315487809yiv1808552570reco-category {
font-size:77%;}
#ygrps-yiv-315487809 #ygrps-yiv-315487809yiv1808552570 #ygrps-yiv-315487809yiv1808552570reco-desc {
font-size:77%;}
#ygrps-yiv-315487809 #ygrps-yiv-315487809yiv1808552570 .ygrps-yiv-315487809yiv1808552570replbq {
margin:4px;}
#ygrps-yiv-315487809 #ygrps-yiv-315487809yiv1808552570 #ygrps-yiv-315487809yiv1808552570ygrp-actbar div a:first-child {
margin-right:2px;padding-right:5px;}
#ygrps-yiv-315487809 #ygrps-yiv-315487809yiv1808552570 #ygrps-yiv-315487809yiv1808552570ygrp-mlmsg {
font-size:13px;font-family:Arial, helvetica, clean, sans-serif;}
#ygrps-yiv-315487809 #ygrps-yiv-315487809yiv1808552570 #ygrps-yiv-315487809yiv1808552570ygrp-mlmsg table {
font-size:inherit;font:100%;}
#ygrps-yiv-315487809 #ygrps-yiv-315487809yiv1808552570 #ygrps-yiv-315487809yiv1808552570ygrp-mlmsg select, #ygrps-yiv-315487809 #ygrps-yiv-315487809yiv1808552570 input, #ygrps-yiv-315487809 #ygrps-yiv-315487809yiv1808552570 textarea {
font:99% Arial, Helvetica, clean, sans-serif;}
#ygrps-yiv-315487809 #ygrps-yiv-315487809yiv1808552570 #ygrps-yiv-315487809yiv1808552570ygrp-mlmsg pre, #ygrps-yiv-315487809 #ygrps-yiv-315487809yiv1808552570 code {
font:115% monospace;}
#ygrps-yiv-315487809 #ygrps-yiv-315487809yiv1808552570 #ygrps-yiv-315487809yiv1808552570ygrp-mlmsg * {
line-height:1.22em;}
#ygrps-yiv-315487809 #ygrps-yiv-315487809yiv1808552570 #ygrps-yiv-315487809yiv1808552570ygrp-mlmsg #ygrps-yiv-315487809yiv1808552570logo {
padding-bottom:10px;}
#ygrps-yiv-315487809 #ygrps-yiv-315487809yiv1808552570 #ygrps-yiv-315487809yiv1808552570ygrp-msg p a {
font-family:Verdana;}
#ygrps-yiv-315487809 #ygrps-yiv-315487809yiv1808552570 #ygrps-yiv-315487809yiv1808552570ygrp-msg p#ygrps-yiv-315487809yiv1808552570attach-count span {
color:#1E66AE;font-weight:700;}
#ygrps-yiv-315487809 #ygrps-yiv-315487809yiv1808552570 #ygrps-yiv-315487809yiv1808552570ygrp-reco #ygrps-yiv-315487809yiv1808552570reco-head {
color:#ff7900;font-weight:700;}
#ygrps-yiv-315487809 #ygrps-yiv-315487809yiv1808552570 #ygrps-yiv-315487809yiv1808552570ygrp-reco {
margin-bottom:20px;padding:0px;}
#ygrps-yiv-315487809 #ygrps-yiv-315487809yiv1808552570 #ygrps-yiv-315487809yiv1808552570ygrp-sponsor #ygrps-yiv-315487809yiv1808552570ov li a {
font-size:130%;text-decoration:none;}
#ygrps-yiv-315487809 #ygrps-yiv-315487809yiv1808552570 #ygrps-yiv-315487809yiv1808552570ygrp-sponsor #ygrps-yiv-315487809yiv1808552570ov li {
font-size:77%;list-style-type:square;padding:6px 0;}
#ygrps-yiv-315487809 #ygrps-yiv-315487809yiv1808552570 #ygrps-yiv-315487809yiv1808552570ygrp-sponsor #ygrps-yiv-315487809yiv1808552570ov ul {
margin:0;padding:0 0 0 8px;}
#ygrps-yiv-315487809 #ygrps-yiv-315487809yiv1808552570 #ygrps-yiv-315487809yiv1808552570ygrp-text {
font-family:Georgia;}
#ygrps-yiv-315487809 #ygrps-yiv-315487809yiv1808552570 #ygrps-yiv-315487809yiv1808552570ygrp-text p {
margin:0 0 1em 0;}
#ygrps-yiv-315487809 #ygrps-yiv-315487809yiv1808552570 #ygrps-yiv-315487809yiv1808552570ygrp-text tt {
font-size:120%;}
#ygrps-yiv-315487809 #ygrps-yiv-315487809yiv1808552570 #ygrps-yiv-315487809yiv1808552570ygrp-vital ul li:last-child {
border-right:none !important;}
