Adding a Crystal report to Vantage 8.0.403C
Follow up: PROBLEM RESOLVED
After applying all the 3.0 .Net patches to no avail, shortening the
path to the file, searching Crystal's & Microsoft's knowledge bases I
discovered that by removing the spaces from the file name it worked as
expected................... It's been a learning experience
Thanks to all who help!
Dan Shallbetter
Of Dan Shallbetter
Sent: Friday, December 07, 2007 1:31 PM
Subject: RE: [Vantage] Adding a Crystal report to Vantage 8.0.403C
Steve,
I am testing report distribution methods using both the BAQ and ODBC
method. It is the BAQ method that I was seeing in system monitor . The
BAQ method report displays but some formulas need to be refined based on
filed conversions. It appears that the BAQ takes a date field i.e.
PayrollDate and converts it to date/time field type. The same report
using ODBC retains it as a date field type. My problem is trying to run
the ODBC report from a menu, nothing seems to happen. Do I need to
configure ODBC user access at the client level, or is this at the server
level? (see below a little fuzzy about what Epicor is talking about)
How to get a Custom Crystal Report onto the Vantage 8.03 Menu
Set-Up User Access for ODBC:
Ensure you have created the user 'sysprogress' with password
'sysprogress' using the Data Admin utility. You can access the Open Edge
Data Administration tool by taking your existing "Admin Tools" shortcut,
right click on it and enter properties:
On the end of the target line - replace "DataAdminMenu.w" with "_admin.r
-rx" so it reads (at the end) "-p _admin.r -rx".
Your AppServers for that DB should be stopped, but the DB itself should
be running. Rename the shortcut appropriately.
Dan
Behalf
Of vantage
Sent: Friday, December 07, 2007 10:55 AM
Dan,
If you select the report in the system monitor and then select preview
from
above do you get any errors or does the report show up?
Steve
<mailto:dans%40stateselectric.com>
<mailto:dans%40stateselectric.com> ]
Sent: December 07, 2007 8:37 AM
Steve,
I tried that it. When I tried to run the report from a menu, the custom
report maintenance screen appears, I select print preview and nothing
happens. Looking at the system monitor the report shows up under the
reports tab with the last action as being auto-preview. As this is my
first attempt at this what might I being doing wrong?
Dan
From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
[mailto:vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com] On
Behalf
Of vantage
Sent: Thursday, December 06, 2007 3:54 PM
To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
Sorry, should say without any data in the report!
This is a bug in the new .net release for the viewer. You need to save
your
report with any data in it from the report builder to get the prompted
to
show up.
Steve
<mailto:dans%40stateselectric.com> .com
Sent: December 06, 2007 2:53 PM
Subject: [Vantage] Adding a Crystal report to Vantage 8.0.403C
Hello,
I have added a test ODBC report though menu maintenance (verifying ODBC
setup). I am trying to add a report that uses parameter fields for
record selection. It flashes retrieving data but never returns anything
else. I would have expected to be prompted for the parameter values? Any
help would be appreciated.
Dan Shallbetter
States Electric Mfg.
Hello,
Dan Shallbetter
This is a bug in the new .net release for the viewer. You need to save your
report with any data in it from the report builder to get the prompted to
show up.
Steve
Hello,
Dan Shallbetter
show up.
Steve
Hello,
Dan Shallbetter
Dan,
Have you ever used the BAQ Report Designer? Much cleaner solution to
custom reports than ODBC. Building the query can sometimes be a little
tricky as the tool used to do so is a little weak, but the integration
of the report into the Vantage interface is seamless and works
identically to all 'canned' reports. Indistinguishable to the end user.
Todd
Of Dan Shallbetter
Sent: Thursday, December 06, 2007 3:53 PM
Hello,
Dan Shallbetter
This e-mail and any attachments may contain confidential and privileged
information. If you are not the intended recipient, please notify the
sender immediately by return e-mail, delete this e-mail and destroy any
copies. Any dissemination or use of this information by a person other
than the intended recipient is unauthorized and may be illegal.
Hello Todd,
I started down that path to begin with (my first attempt with BAQ). When
I created the following criteria in the BAQ
for each EmpBasic where ( EmpBasic.EmpStatus = 'A') no-lock , each
LaborHed where (AND LaborHed.PayrollDate >= 02/19/2007) and
(EmpBasic.EmpID = LaborHed.EmployeeNum) no-lock .
And then analyze the statement it returns the following error:
** Unable to understand after -- "no-lock where". (247)
I removed the payroll date criteria and it tested fine.
I have the following questions:
I added the payroll date filter as an option in the BAQ report designer.
It appears that this eliminates the need for doing the same record
filtering in Crystal using parameter fields?
Can I create criteria for multiple tables in the BAQ and how does one
edit the syntax errors that creates?
When I tested the BAQ it returns a lot of data, generating data in the
report designer appears to create a very small sample set of data and
only after deploying the BAQ do I see the expected results ( spent a
long time trying to understand why my Crystal report was not returning
more data before I figured that one out) is there a way to expand the
amount of data it generates?
Thanks for the help and advice!
Dan Shallbetter
Of Todd Hofert
Sent: Thursday, December 06, 2007 4:03 PM
Dan,
Todd
Behalf
Of Dan Shallbetter
Hello,
Dan Shallbetter
Steve,
Dan
Of vantage
your
to
show up.
Steve
Hello,
Dan Shallbetter
Dan,
If you select the report in the system monitor and then select preview from
Steve
Steve,
Dan
Behalf
Of vantage
your
to
show up.
Steve
Hello,
Dan Shallbetter
Make sure your menu item report path is a UNC destination to a share and
not too long
Gary Parfrey
Dot Net IT Limited, Reg No 4412519
Of Dan Shallbetter
Sent: 07 December 2007 14:37
Steve,
Dan
Behalf
Of vantage
your
to
show up.
Steve
Hello,
Dan Shallbetter
Steve,
Dan
Of vantage
Dan,
from
Steve
Steve,
Dan
Behalf
Of vantage
your
to
show up.
Steve
Hello,
Dan Shallbetter
