Hi all,
I was trying to get a button to open with information loaded from the calling form and when I started getting into it I realized it was way above my head and I should start by figuring out how to just call the form from a button. Using the event wizard I created the code below but nothing happens when I click on the button. The menu for the report is correct and I can open it with the context menu. I have no idea where I’m going wrong. Thanks
private void epiButtonC1_MouseClick(object sender, system.Windows.Forms.MouseEventArgs args)
Don’t have my code handy but look at launch form options on this forum. I think that’s how you would pass the parameters into the form you’re launching. If you’re trying to invoke the report it’s a different call, which I think I’ve also seen on this forum
I got it to work in my Test system and am trying to do it in the live system. I added the same line via the wizard and clicked on Update. It shows the new code in the Script Editor so I am assuming it updated. Nothing happens when I click on the button. Any ideas?
Does that form you’re trying to launch exist in your new environment?
Also, your quotations around “I Work” look off. Re-write that with your keyboard instead of cut/paste…
