Added Subreport to PO Form
So I came across an old posting online with a weird crystal issue. The subreport we were using had a parameter field that was not actually being used. I had to delete this from the subreport before it would run in Epicor.
Thanks for the help
Tyler Tisdale l IT Systems Administrator
ULTRAX Aerospace l 4200 NE Sun Court, Lee's Summit, MO 64064
Sent: Monday, March 02, 2015 10:01 AM
Subject: RE: [Vantage] Added Subreport to PO Form
Ah, no it does not. I had only established the connection inside of Crystal. I will give this a try. Thanks
Sent: Monday, March 02, 2015 9:44 AM
To: 'vantage@yahoogroups.com'
Does the client station that you’re attempting to run the report from have an ODBC connection to that outside database on it (system DSN)?
Rob Bucek
Production Control Manager
PH: (715) 284-5376 ext 311
Mobile: (715)896-3119
FAX: (715)284-4084
[cid:1.234354861@...]<http://www.dsmfg.com/>
(Click the logo to view our site)<http://www.dsmfg.com/>
Sent: Monday, March 02, 2015 9:27 AM
Subject: [Vantage] Added Subreport to PO Form
We had a consultant make a customization for us. Basically he made his own SQL database and populates data from Epicor to it. I took the PO Form and added a subreport to pull data from this outside database. When I run the report from Epicor I get an error about an invalid field. The reports works fine outside of Epicor, so I assume I need to do something to allow Epicor access to this outside database. Anyone have any ideas to point me in the right direction?
Tyler
Tyler
Rob Bucek
FAX: (715)284-4084
Tyler
Rob Bucek
FAX: (715)284-4084
Tyler
