Is there a way to add a standardized document to the end of an SSRS report? When I created a sub-report with the document basically copied/pasted into the RDL, it errors with an object reference not found? Is there some trick to setting up a sub-report that I am not aware of? There’s no data in it so I didn’t setup a parameter for the Guid. Do I need to do that maybe?
Also, is there a better way? Like attach a PDF to the end of the generated SSRS report PDF?
@dr_dan - Our workaround was to create a big ‘text’ box and copy the text of the document into the text box. A little fiddling with the placement and properties allowed for the “page break” to appear correctly. Sorry - I don’t think I have (but I’ll look) a current example of that since we moved to APR and just add documents to the output email by taking them from ECM/Docstar now.
I know I have an example in Crystal Reports still lying about…
Thanks for the suggestion. This particular document is several pages long - it’s a terms and conditions of sale type document. I don’t think an image would split properly between pages… even if I could figure out how to make the image…
Have to agree with Mike and Nate, trying to set up a subreport for this is going to cause you a lot of frustration. I wish epicor made it easier to use subreports, but I haven’t found any documentation on how to do it.
With APR, you should be able to do a Take Document and copy it in.
I have worked at quite a few places where the customer altered the T&C’s so standard text didn’t work - especially if it was signed. I knew one company who always changed the T&Cs because they had a lawyer on staff.
If it truly is unchanging, we just included a link to the company’s external web site with the T&Cs to download.
Our old-fashioned lawyer advised our CFO against this. I tried and tried…
The APR ‘take’ works well if you need to substitute T&C - we are doing it that way because some lines on the order are services that have a different T&C form our MFG stuff.
If you want to try a subreport, you will have to set it up exactly like the other subreports. I forget if you need an RDD, but you at least need to point the Guid to the subreport.
