Add fields to Time Phased grid
Excellent....this example worked really slick...thank you!!! Now I just need to see if I can use the fields that we need. It's a big step in the right direction. Many thanks to all!!
Kurt
--- In vantage@yahoogroups.com, "bw2868bond" <bwalker@...> wrote:
> Well, I could have swore I posted an example of how to do this before, but I searched back 2 yrs and could not find :-(
> must be an age related thing.....
> Here is some code we are using to add the parent part number field to time phase grid for jobs
> This might give you some ideas or point you in the right direction:
> Module Script
> '// ** Wizard Insert Location - Do Not Remove 'Begin/End Wizard Added Module Level Variables' Comments! **
> '// Begin Wizard Added Module Level Variables **
> Private WithEvents edvTimePhas As EpiDataView
> '// End Wizard Added Module Level Variables **
> '// Add Custom Module Level Variables Here **
> Sub InitializeCustomCode()
> '// ** Wizard Insert Location - Do not delete 'Begin/End Wizard Added Variable Intialization' lines **
> '// Begin Wizard Added Variable Intialization
> edvTimePhas = CType(oTrans.EpiDataViews("TimePhas"), EpiDataView)
> '// End Wizard Added Variable Intialization
> '// Begin Custom Method Calls
> If Not (edvTimePhas.dataView.Table.Columns.Contains("ParentPart")) Then
> edvTimePhas.dataView.Table.Columns.Add(new DataColumn("ParentPart"))
> End If
> '// End Custom Method Calls
> End Sub
> Sub DestroyCustomCode()
> '// ** Wizard Insert Location - Do not delete 'Begin/End Wizard Added Object Disposal' lines **
> '// Begin Wizard Added Object Disposal
> '// End Wizard Added Object Disposal
> '// Begin Custom Code Disposal
> '// End Custom Code Disposal
> End Sub
> Private Sub edvTimePhas_EpiViewNotification(view As EpiDataView, args As EpiNotifyArgs) Handles edvTimePhas.EpiViewNotification
> '// ** Argument Properties and Uses **
> '// view.dataView(args.Row)("[FieldName]")
> '// args.Row, args.Column, args.Sender, args.NotifyType
> '// NotifyType.Initialize, NotifyType.AddRow, NotifyType.DeleteRow, NotifyType.InitLastView, NotifyType.InitAndResetTreeNodes
> If (args.NotifyType = EpiTransaction.NotifyType.Initialize) Then
> If (args.Row > -1) Then
> AddParentPart()
> End If
> End If
> End Sub
> Private Sub AddParentPart()
> For Each dr As DataRow In edvTimePhas.dataView.Table.Rows
> If Not IsDBNull(dr("JobNum")) Then
> dr("ParentPart") = getParentPart(dr("JobNum"))
> End If
> Next
> End Sub
> Private Function getParentPart(ByVal job As String) As String
> Dim parentPart As String
> Dim recordSelected As Boolean
> Dim showSearch As Boolean = False
> Dim whereClause As String = "JobNum = '" + job + "'"
> Dim dsJobInfo As DataSet = SearchFunctions.listLookup(TimePhasForm, "JobAsmSearchAdapter", recordSelected, showSearch, whereClause)
> If recordSelected Then
> parentPart = dsJobInfo.Tables(0).Rows(0)("PartNum").ToString()
> Else
> parentPart = ""
> End If
> Return parentPart
> End Function
> End Module
> --- In vantage@yahoogroups.com, "Rob Bucek" <rbucek@> wrote:
> > And if you do find a way to do that Ill pay dearly to know as well... In
> > so far as I've investigated and experimented I don't think there is a
> > way to 'append' columns to existing views. In the end what I did was
> > add an embedded dashboard to another sheet which was driven by the main
> > grid to show what I needed. Not as convenient as adding a column or two
> > but it had the distinction of getting the job done...
> > Rob Bucek
> > Manufacturing Engineer
> > PH: 715-284-5376 ext 311
> > FAX: 715-284-4084
> > <http://www.dsmfg.com/>
> > (Click the logo to view our site)
> > ________________________________
> > From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf
> > Of iusevantage
> > Sent: Thursday, May 21, 2009 8:22 AM
> > Subject: [Vantage] Add fields to Time Phased grid
> > Hi,
> > I'm in the Time Phased form and I need to add a couple fields to to the
> > grid. It uses TimePhas as the datasource. I need to get a field from the
> > Part table included in ('included in' is key here) the TimePhas fields,
> > plus I'd like to also get a Customer field from another table (I'll use
> > any table that would work).
> > I have tried several, well many, attempts using FKV and STV's and I have
> > gotten new views with the Searchword field from the Part table, but it
> > looks like I lose the initial TimePhas fields. Basically I just want to
> > keep the grid as is, but add the Searchword field from the Part table
> > and a Customer field from another table.
> > I have looked at posts from here and from the Vantage site and it all
> > looks the same....just making a FKV where I lose my initial fields. Can
> > this be done? I'm not that adept at Vantage yet and maybe I'm missing
> > something. Any help is much appreciated!!
> > Regards,
> > Kurt
Hi,
I'm in the Time Phased form and I need to add a couple fields to to the grid. It uses TimePhas as the datasource. I need to get a field from the Part table included in ('included in' is key here) the TimePhas fields, plus I'd like to also get a Customer field from another table (I'll use any table that would work).
I have tried several, well many, attempts using FKV and STV's and I have gotten new views with the Searchword field from the Part table, but it looks like I lose the initial TimePhas fields. Basically I just want to keep the grid as is, but add the Searchword field from the Part table and a Customer field from another table.
I have looked at posts from here and from the Vantage site and it all looks the same....just making a FKV where I lose my initial fields. Can this be done? I'm not that adept at Vantage yet and maybe I'm missing something. Any help is much appreciated!!
Regards,
Kurt
I have been trying to get out Scheduled Shipment report to only show
Shipments for the days that I put in. When I copied the SchedShip Report
Definition with a new name and added a new Table Criteria for the OMR50
Table, there were no fields to use for my Criteria. So I copied the
Scheduled Shipment crystal report and put in a Parameter field. Now the
Crystal report asks me for a date, but it still shows all of the Shipments,
regardless of the Required by date. I went into Table Definitions and
entered OMR50 (the Table used in the Report Definitions) and I get a message
telling me that the Table does not exist.
Has anyone been able to set a Criteria in the Scheduled Shipment report?
Thank you
Jeff
Rob Bucek
FAX: 715-284-4084
Of iusevantage
Hi,
Regards,
Kurt
Module Script
End If
End Sub
End Sub
AddParentPart()
End If
End If
End Sub
End If
Next
End Sub
Else
parentPart = ""
End If
Return parentPart
End Function
End Module
> Rob Bucek
> FAX: 715-284-4084
> Of iusevantage
> Hi,
> Regards,
> Kurt
Time Phase is a Progress 4GL compiled report that displays on screen (with a .Net Form wrapper around it) You can't change/add FKV table fields to the (temp) dataview displayed in the grid. There are no ud fields in this temp table you can hijack to add additional info to the grid displayed table.
You CAN play some VB code games that can overwrite existing data column/field values - but they clear on refresh.
The bulk of the temp table data comes from the PartDtl table (supply/demand info) and the tables that hold PO & MRP suggestions.
The 1st row (starting O/H for the plant) comes from summing the available O/H from each whse for the part.
With ODBC you can create your own version of time phase and display it as an html page (or an excel app). Our VERY talented IT folks went the HTML route.
I think a number of people (including myself) have tried creating dashboards to come up with their own time phase - but the BAQ editor doesn't support the full progress 4GL language set needed to populate a calculated display row number that is necessary to keep the data in proper sort sequence for a good time phase view.
Rob
Â
Sent: Thursday, May 21, 2009 9:21:37 AM
Hi,
I have looked at posts from here and from the Vantage site and it all looks the same....just making a FKV where I lose my initial fields. Can this be done? I'm not that adept at Vantage yet and maybe I'm missing something. Any help is much appreciated! !
Regards,
Kurt
Rob (Bucek),
I think my buddy Nick Taylor (in the UK) came up with something using Service Connect (dumping Time phase results into another db he uses on his legacy system - where he then can append additional data and control filtering to his heart's content).
They decided NOT to go forward with imlementing Vantage company wide (much to Epicor's chagrin I'm sure) - so I'm not sure how often he checks in on the Yahoo user group any more.
If he sees this though, perhaps he might contact you directly (??) and give some guidance to a friend of a friend?
Rob (Brown)
Â
Sent: Thursday, May 21, 2009 9:39:00 AM
Subject: RE: [Vantage] Add fields to Time Phased grid
Rob Bucek
FAX: 715-284-4084
<http://www.dsmfg com/>
____________ _________ _________ __
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf
Of iusevantage
To: vantage@yahoogroups .com
Hi,
Regards,
Kurt
Absolutely Rob~ We use the forecasting form and our purchasing people
needed to see what suggestions were coming from strictly the forecast
side and since they already spend a lot of time in the time phase side
it made sense for us to put it there. Essentially with some creative
linking in a BAQ (and subsequently embedding it in the time phase form)
I was able to show when a purchase suggestion was coming from an
unfirmed job created by MRP from forecast demand.
Rob Bucek
FAX: 715-284-4084
Of Robert Brown
Sent: Thursday, May 21, 2009 11:39 AM
Subject: Re: [Vantage] Add fields to Time Phased grid
Rob (Bucek),
Rob (Brown)
From: Rob Bucek <rbucek@... <mailto:rbucek%40dsmfg.com> >
Rob Bucek
FAX: 715-284-4084
Behalf
Of iusevantage
Hi,
Regards,
Kurt
