What;s the error./
*Jose C Gomez*
*Software Engineer*
*T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
<http://www.usdoingstuff.com>
*Jose C Gomez*
*Software Engineer*
E: jose@...
On Thu, Aug 2, 2012 at 4:42 PM, mmcwilliams22 <mmcwilliams22@...>wrote:
> I am trying to add a dropdown to a column on a native ultragrid.
> I have used the following before on grids that I bind the dataset after
> the form has loaded(Initializelayout). However on a native grid it is not
> working. Any tips
> Dim v1 As ValueList
> v1 = e.Layout.ValueLists.Add("MyValueList")
> v1.ValueListItems.Add(1, "Bowed")
> v1.ValueListItems.Add(2, "OD Out of Tolerance")
> v1.ValueListItems.Add(3, "Wall Thickness Out of Tolerance ")
> v1.ValueListItems.Add(4, "Length Out of Tolerance")
> v1.ValueListItems.Add(5, "Poor OD Scarfic Cut,tool cut")
> v1.ValueListItems.Add(6, "Coil Defects")
> v1.ValueListItems.Add(7, "ID Bead Height Defects")
> v1.ValueListItems.Add(8, "Tube Weld Seam Defects")
> v1.ValueListItems.Add(9, "Mill Tooling Set-Up")
> v1.ValueListItems.Add(10, "Tube Surface Condition")
> v1.ValueListItems.Add(11, "End Condition")
> v1.ValueListItems.Add(12, "Tolerances Tighter than ASTM A513")
> e.Layout.Bands(0).Columns(9).ValueList = e.Layout.ValueLists("MyValueList")
