Is there a way to add another datasource to a BAQ Report?
If for example I would like to create a custom SOPick list using a BAQ Report, would like to add a separate datasource that would have the Warehouses and OnHandQty.
It looks like there is a mechanism to do it - I can see the “New BAQ” option in the RDD.
Mr. Jason: Yes - I can do that - it makes it MUCH harder to do summaries (because of the extra records).
There are a number of other scenarios also where subreports would be nice, i.e. create your own Job Traveler - or AR Invoice - If you get either of those done with a single dataset - then you are a magician.
