I am adding a few columns to the Out-of-the-Box grids on PO Suggestions Entry form and populating cells with data from a BAQ. For some reason, populating the cells takes a painfully long time. 3min 20sec for ~450 rows.The BAQ executes on form load, no performance issue there. Data is stored in a List, then applied to custom cells in the grid’s InitializeRow event.
See code below. Is there a better way?
Initialize (Add grid columns)
drawingInfoQueryAdapter = new DynamicQueryAdapter(oTrans);
drawingInfoQueryAdapter.BOConnect();
this.MtlSug_Row.EpiRowChanged += new EpiRowChanged(this.MtlSug_AfterRowChange);
this.SubSug_Row.EpiRowChanged += new EpiRowChanged(this.SubSug_AfterRowChange);
materialGrid = (Ice.Lib.Framework.EpiUltraGrid)csm.GetNativeControlReference("4d59326f-7a76-4c5c-8e2c-54e630db64da");
SetupGrid(materialGrid);
subcontractGrid = (Ice.Lib.Framework.EpiUltraGrid)csm.GetNativeControlReference("fcef0a0c-90f6-48b5-8133-f892a2515b84");
SetupGrid(subcontractGrid);
/// Add PhaseID, DrawingInfo columns to specified grid.
private void SetupGrid(EpiUltraGrid grid)
// Add columns
grid.DisplayLayout.Bands[0].Columns.Add("PhaseID", "Section");
grid.DisplayLayout.Bands[0].Columns.Add("DrawingInfo", "Drawing");
// Get columns
var colPhaseID = grid.DisplayLayout.Bands[0].Columns["PhaseID"];
var colDrawingInfo = grid.DisplayLayout.Bands[0].Columns["DrawingInfo"];
// Set Header Position
colPhaseID.Header.VisiblePosition = 4;
colDrawingInfo.Header.VisiblePosition = 5;
// Set Cell Activation
colPhaseID.CellActivation = Activation.ActivateOnly;
colDrawingInfo.CellActivation = Activation.ActivateOnly;
// Register InitializeRow event
materialGrid.InitializeRow += new InitializeRowEventHandler(poSuggestionsGrid_InitializeRow);
Form Load (Get BAQ Results)
private void POSuggEntryForm_Load(object sender, EventArgs args)
InitializeDrawingInfo();
private void InitializeDrawingInfo()
var drawingInfoBaqID = "NewPOSugg_DrawingInfo";
var queryExecutionDataSet = drawingInfoQueryAdapter.GetQueryExecutionParametersByID(drawingInfoBaqID);
drawingInfoQueryAdapter.ExecuteByID(drawingInfoBaqID, queryExecutionDataSet);
var drawingInfoTable = drawingInfoQueryAdapter.QueryResults.Tables["Results"];
drawingInfoRows = drawingInfoTable.Rows.Cast<DataRow>().ToList();
InitializeRow (Update custom cells)
public void poSuggestionsGrid_InitializeRow(object sender,Infragistics.Win.UltraWinGrid.InitializeRowEventArgs e)
UpdateGridRow(e.Row);
private void UpdateGridRow(UltraGridRow row)
var jobNum = row.Cells["JobNum"].Value.ToString();
var partNum = row.Cells["PartNum"].Value.ToString();
var revisionNum = row.Cells["RevisionNum"].Value.ToString();
if(!string.IsNullOrEmpty(jobNum))
var drawingDetailsRow = drawingInfoRows.FirstOrDefault(drawingInfoRow => drawingInfoRow["JobMtl_JobNum"].ToString() == jobNum &&
drawingInfoRow["JobMtl_PartNum"].ToString() == partNum &&
drawingInfoRow["JobMtl_RevisionNum"].ToString() == revisionNum);
if (drawingDetailsRow != null)
SetRowDrawingDetails(row, drawingDetailsRow);
private void SetRowDrawingDetails(UltraGridRow gridRow, DataRow drawingDetailsRow)
var phaseID = drawingDetailsRow["JobHead_PhaseID"].ToString();
var section = string.Empty;
if(phaseID.Length >= 6)
section = phaseID.Substring(3, 3);
gridRow.Cells["PhaseID"].Value = section;
var drawingNumber = drawingDetailsRow["JobMtl_MtlDrawingNumber_c"].ToString();
var drawingRevision = drawingDetailsRow["JobMtl_MtlDrawingRevision_c"].ToString();
var drawingInfoString = (!string.IsNullOrWhiteSpace(drawingNumber) ? drawingNumber : "-") +
(!string.IsNullOrWhiteSpace(drawingRevision) ? string.Format(" [{0}]", drawingRevision) : string.Empty);
gridRow.Cells["DrawingInfo"].Value = drawingInfoString;
