Another option if you really want to use the internal reports from Epicor would be to put the report on a menu and then program a button to call that menu item. As for passing it a parameter (case # for example), I don't know what the simplest way to do that is but I'm sure someone here knows how. I have seen a demo by Brian Hattrup (I think that's his name) at Epicor where he was calling menu items and passing parameters so I know it can be done somehow!
To add a button to do this you need to add code in the load section to join the button to the GUI
UDbtnWhatsInABin =CType(csm.GetNativeControlReference("e2bd6cf5-6e63-4c72-8675-83379adc90c6"), EpiButton)
UDbtnWhatsInABin.Enabled = True
Then you will need to have a button click event all the menu item
Private Sub UDbtnWhatsInABin_Click(ByVal Sender As Object, ByVal args As EventArgs ) Handles UDbtnWhatsInABin.Click
ProcessCaller.LaunchForm(MESMenu, "AGMWHATS") '<==== enter your menu Id here
End Sub
Replace the MESMenu with whatever form you are modifiying. You can see the name of the form in the top left of the customization screen, just above the tree. Something like Epicor.Mfg.Menu.Mes.MESMenu.
Anyway, hope that helps!
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Tom J. Christie
Sent: Tuesday, October 23, 2012 1:49 PM
Subject: RE: [Vantage] Re: add a report to Case Entry menu
A relatively easy solution if you are on SQL is to create an SSRS report using the MS Report Builder (it's free) and then code a button on the Case Entry screen that calls the URL with the parameter to pull your report.
Say you write a SSRS report that shows you all the details on a Case if you enter the Case #, then you make a button on the case entry form and add code to the button click event to call the URL with something like Process.Start(Iexplorer.exe,"//epicordb/reportserver/yourreport¶meter=case#")
I have done what you are doing, building a full report inside Epicor and then adding a menu to call it. It can be done on some forms but it's tricky and a bit involved.
If you need it, Report Builder can be found at this link. You need to use the version compatible with your SQL server.
http://technet.microsoft.com/en-us/bi/ff657833.aspx
Good luck,
Tom
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of Adrian Lauchlan
Sent: Tuesday, October 23, 2012 7:36 AM
Thanks for the response - however what I want to do is embed the report into
the existing Case Entry Menu so that someone can enter a Case and then click
on the print icon to print it - similar to the ability to print an Order
directly from the Sales Order Entry Screen - I'm expecting that some sort of
customisation is required
Adrian
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>] On Behalf Of
howco22
Sent: 23 October 2012 15:08
To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>
Subject: [Vantage] Re: add a report to Case Entry menu
Go to System Management, Utilities, Menu Maintenance.
then select the menu you want to add it to and click on new menu to add it.
you will need to log out & back in for it to show up on the menu.
Note: It will not show up for any user until the next time they log in.
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> ,
"adrian.lauchlan" <adrianlauchlan@...<mailto:adrianlauchlan@...<mailto:adrianlauchlan@...%3cmailto:adrianlauchlan@...>>> wrote:
I now add that to the menu?
End Sub
Good luck,
Tom
Adrian
howco22
>be printed out. I have created my report using BAQ Report Designer - how do
> I want to add a report to the case entry menu so that the viewed case can
> Adrian
