Hello,
is it possible to add an item in the dropdown menu list.
thanks,
Eddy
Hello,
thanks,
Eddy
Select the top level card to edit.
Click the header label, go to its properties and add a tool.
Configure as needed.
thanks so much,
when the tool click, i need call a report, how to do that.
thanks,
Eddy
Hello hmwille,
I tried. but i got error message and said my view doesn’t exist. but I can create menu in the menu maintenance and it can open the BAQ report.
regards,
Eddy
Is this case sensitive? Are you sure you type it in correctly?
sKid ?
Hello,
i figured it out. it is ok.
thanks,
Eddy
