Add a column in Part Search button
Thanks for the advice Lynn and Rob's!! I appreciate that!
--- In vantage@yahoogroups.com, "Lynn" <lynn.khalife@...> wrote:
> Sal:
> All of this is in the Epicor Tools User Guide ($70 from your Epicor CAM).
> Or if you have support, you can download these 3 AnswerBooks from MyEpicWeb which are how-tos for BAQ's & BAQ Searches & QuickSearches:
> AnswerBook 5148ESC
> AnswerBook 4164ESC
> AnswerBook 4201ESC
> Lynn
> --- In vantage@yahoogroups.com, Robert Brown <robertb_versa@> wrote:
> > You can't modify a system BAQ. You an only copy from them & save a a new unique search after setting up all fields for use in searches (and then that can become the basis of your app search).
> > If you then make a Named Search from the BAQ, it can be set as the default search for the app. (This is personalization based though if I remember correctly.... You'd have to set up every user individually.)
> > Rob
> > --- On Tue, 4/7/09, idiabos <idiabos@> wrote:
> > From: idiabos <idiabos@>
> > Subject: [Vantage] Re: Add a column in Part Search button
> > Date: Tuesday, April 7, 2009, 3:23 PM
> > How do you know what BAQ is used? And where do you go to modify the BAQ? The one I want to do in particular is the "Part..." button in the Part Master. I want to add a column in the Search Results screen there. Thanks again!!
> > --- In vantage@yahoogroups .com, "Rob Bucek" <rbucek@> wrote:
> > > Ive done it with BAQ searches...
> > > Rob Bucek
> > > Manufacturing Engineer
> > > PH: 715-284-5376 ext 311
> > > FAX: 715-284-4084
> > > <http://www.dsmfg com/>
> > > (Click the logo to view our site)
> > > ____________ _________ _________ __
> > > From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf
> > > Of idiabos
> > > Sent: Tuesday, April 07, 2009 12:13 PM
> > > To: vantage@yahoogroups .com
> > > Subject: [Vantage] Add a column in Part Search button
> > > Hello!
> > > Does anyone know how to add a new column to the Search Results screen
> > > when you click the Part search button? Thanks in advance!
> > > -Sal
Hello!
Does anyone know how to add a new column to the Search Results screen when you click the Part search button? Thanks in advance!
-Sal
Rob Bucek
FAX: 715-284-4084
<http://www.dsmfg.com/>
Of idiabos
Hello!
-Sal
> Rob Bucek
> FAX: 715-284-4084
> Of idiabos
> Hello!
> -Sal
Most likely it would be easier to just create a new BAQ. Since you're
just looking at the part table it'll be pretty straight forward. Create
a new BAQ, grab the part table and add the columns that were in the
original search grid (assuming you want them all) and add whatever
columns you deem are missing. On the BAQ search tab select the
available 'like' columns that are relevant to your search criteria. In
this case PartNum. Now when you search just grab the BAQ you created
under the BAQ tab in the search form. I'm pretty certain you can also
create a default named search to save some time.
Rob Bucek
FAX: 715-284-4084
Of idiabos
Sent: Tuesday, April 07, 2009 2:23 PM
Thanks again!!
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , "Rob
> Rob Bucek
> FAX: 715-284-4084
> <http://www.dsmfg.com/ <http://www.dsmfg.com/> >
Behalf
> Of idiabos
> Hello!
> -Sal
Rob
> Rob Bucek
> FAX: 715-284-4084
> Of idiabos
> Hello!
> -Sal
Sal:
AnswerBook 5148ESC
AnswerBook 4164ESC
AnswerBook 4201ESC
Lynn
> Rob
> From: idiabos <idiabos@...>
> > Rob Bucek
> > FAX: 715-284-4084
> > Of idiabos
> > Hello!
> > -Sal
