I am working on adding some new revisions to parts. However, I can not get it to work. WE have the part entered, but no revisions, and that’s what Ia m trying to add. I know for deleting info I had to use the ECOOpDtl#RowMod column and then a D for delete. I tried this and using an A for Add and that did nothing. Using Bill of Operations:
Company
Part Num
Revision Num
OprSeq
opCode
Prod Standard
QtyPer
OpDesc
Plant
EcoGroupID
Ecoopdtl#RowMod
Got it working. I remembered I was in test. So I tried @lgraham and it worked great! But when I went into live mode, the way I had it worked as well. So, my test is not the same as my live. For some reason my predecessor noted that it updated every month to keep up with what we are actually doing. But apparently it does not do so.
