Just noticed that the ad blocking notification is showing even though I have ad blocking turned off for all of epiusers.help. No biggie, just thought you’d like to know.
If it helps, I’m running Firefox v52.0 with AdBlock Plus.
Thanks for making this great resource and community possible.
Here’s a screensnip with the notification and an ad below it:
I just tested with firefox and ad-block. If Ad-Block is enabled for the site it shows the alert, but if I add an exception for E10help then it goes away after I refresh
As above, had it on Chrome with AdBlock extension. Added the rule a while ago, and it worked - then got this the other day. Clearing the cache (F12 [developer] and doing an Empty Cache and Hard Reload) fixed it for me (this was about a week ago).
Do you see the ads and the message saying you are blocking them? Your screenshot shows only the message, so if the ad is now showing … then you’ll get the message. Something else is perhaps blocking ?
There’s a little script that looks at the DOM to determine if the ad was loaded. If it wasn’t it displays the banner.
So for some reason, something in your browser is blocking the ad so my script is promoting you to enable it.
Don’t worry about it if you can’t figure it out, I completely understand that ads are annoying.
Ublock origin works fine with filtering specific sites and it works with e10help.
Someone else had problems with adblock plus not allowing e10help even thought it was directly an exception.
