Access Variable set in Data Directive Custom Code
I have a custom code block in a Data Directive BPM Workflow. I have Variables that I set after true Conditions and need to access these variable in a Custom Code Block that I send emails in to format the Email body text.
Any help would be greatly appreciated!
Mike
You can directly access any variables you have already defined outside the code block (in a “set argument/variable” for example) in any code block. If you right click inside the custom code window, you’ll see a “Variables” drop-down menu that lists the variables you already have defined in the BPM. You can also just type them in by name.
If there were just a Manual!
The customization / ICE tools manuals are decent…but they definitely don’t cover everything. At least the holes can be filled with this site! :grinning:
