No...sorry.
Mike
To: vantage@egroups.com <vantage@egroups.com>
Date: Monday, November 13, 2000 8:32 AM
Subject: Re: [Vantage] Access 2000 and Vantage Exports
Mike
>Mike -utility.
>Have you applied SP1 for A2000?
>Calvin
>----- Original Message -----
>From: <MLowe@...>
>To: <vantage@egroups.com>; <Socalvantage@egroups.com>
>Sent: Sunday, November 12, 2000 11:31 AM
>Subject: [Vantage] Access 2000 and Vantage Exports
>> Hi Everyone!
>> This is for all the Access gurus out there...
>> I created an Access 97 database that I use for multiple Vantage db
>consolidation
>> by linking dbase tables generated by utilizing the Vantage Export
>>please go to the following link: http://www.egroups.com/files/vantage/
>> After upgrading to Access 2000 I can no longer LINK these dbf files in
>this
>> consolidation database. When I try to link (or to import) these tables I
>get
>> the following message:
>> '' is not a valid name. Make sure that it does not include invalid
>characters
>> or punctuation and that it is not too long.
>> All my Vantage Exports conform to the 8.3 naming convention (e.g.
>LABook.dbf,
>> TXBook.dbf).
>> This worked like a charm in Access 97 but not in Access 2000 for some
>reason.
>> Any insights would be GREATLY appreciated!
>> Thanks!
>> Mike Lowe
>> Corporate I.S. Manager
>> Connor Manufacturing Services
>> MLowe@...
>> (909) 273-1282
>> We no longer allow attachments to files. To access/share Report Files,
>> (Note: If this link does not work for you the first time you try it, go
>to www.egroups.com, login and be sure to save your password, choose My
>Groups, choose Vantage, then choose Files. If you save the password, the
>link above will work the next time you try it.)
>(Note: If this link does not work for you the first time you try it, go towww.egroups.com, login and be sure to save your password, choose My Groups,
