Mike
You can do this but it starts becoming complex the deeper your
BOM is. Patrick has posted a report using the technique and I think I might
have posted a version a while ago too. You have to reconnect the
appropriate tables using an alias name. For example: level 1 would be
"Part1", level 2 would be "Part2", level 3 would be Part3, and so on. At
each level you would need to connect the appropriate tables to pull the
information you need also using alias'. If you can't locate the right file
in the files section I'll dig out my copy and send it to you.
Shirley
Sent: Monday, September 20, 2004 6:59 PM
Cc: socalvantage@yahoogroups.com
Subject: [Vantage] ABOM Report question
Greetings All,
I think I'm overcomplicating what I am trying to accomplish so thought I
would throw this out to the group as a sanity check.
I'm trying to analyze the percentage of time a part should spend in a
specific department (based on the ABOM not jobs). For a single level
assembly this isn't difficult but I'm having difficulty when trying to
compile the same data for indented manufactured parts (3-4 deep).
Here is what I would like to see:
Part PARENT PART Mfg Lot size = 10000
10 Assembly 25 Hrs
20 Paint 20 Hrs
.MFG ASM1
10 Punch Press 22 Hrs
20 Secondary 10 Hrs
.MFG ASM2
10 FourSlide 25 Hrs
20 Secondary 5 Hrs
.MFG ASM3
10 Assembly 10 Hrs
20 Paint 7 Hrs
Total Departmental Time
Assembly = 35 Hrs 28%
Punch Press = 22 Hrs 18%
Four Slide = 25 Hrs 20%
Secondary = 15 Hrs 12%
Paint = 27 Hrs 22%
124 Hrs
The breakout in hours per dept. and percentage of total is what I'm trying
to obtain. I run into problems with my reports as I go after the
subassemblies. Has anyone done anything like this before for subassembly
parts? Any suggestions?
Thanks!
Mike Lowe
Corporate I.S. Manager
Connor Manufacturing Services
MLowe@...
Ph: (949) 713-3328
Fx: (949) 666-5268
Yahoo! Groups Sponsor
ADVERTISEMENT
<http://us.ard.yahoo.com/SIG=1298p407i/M=298184.5285298.6392945.3001176/D=gr
oups/S=1705007183:HM/EXP=1095807802/A=2352667/R=0/SIG=11t4iivpf/*http:/www.n
etflix.com/Default?mqso=60185359&partid=5285298> click here
<http://us.adserver.yahoo.com/l?M=298184.5285298.6392945.3001176/D=groups/S=
:HM/A=2352667/rand=583564076>
_____
Yahoo! Groups Links
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of
<http://docs.yahoo.com/info/terms/> Service.
Tracking #: CE8858ABF300FC4098858A024A756DDF30258D27
Shirley
Greetings All,
10 Assembly 25 Hrs
20 Paint 20 Hrs
.MFG ASM1
20 Secondary 10 Hrs
.MFG ASM2
10 FourSlide 25 Hrs
20 Secondary 5 Hrs
.MFG ASM3
10 Assembly 10 Hrs
20 Paint 7 Hrs
Paint = 27 Hrs 22%
124 Hrs
Thanks!
Mike Lowe
MLowe@...
Ph: (949) 713-3328
Fx: (949) 666-5268
ADVERTISEMENT
_____
Yahoo! Groups Links
