The only time our A/R clearing has a balance is when there is a packing
slip left un invoiced.
Stephanie Geary
Controller
Triumph Fabrications - Shelbyville
sgeary@...
Office: 317/398-6684
Fax: 317/392-5006
Of Randy
Sent: Friday, November 20, 2009 11:25 AM
Subject: [Vantage] Re:A/R clearing out of balance
Help!
We found we have the same problem and have several thousand dollars left
in the account from January. All of the jobs appear to have been closed
on 1/30/09. It appears that the cause was someone doing a WIP capture
and Post on 2/2/09 but she put the Ending date of 1/30/09. Would this
cause these transactions to remain unposted? She says she changes the
date so that the costs are put into the prior period. Is this necessary?
Help - I have to explain to my boss several thousands of dollars of
losses that we had not known about until today.
thanks in advance
Randy Weber
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , "Jim
Frice" <Jim.Frice@...> wrote:
Behalf
address.
Stephanie Geary
Controller
sgeary@...
Fax: 317/392-5006
Of Randy
Help!
thanks in advance
Randy Weber
>these
> If you are on 6.1 try creating a report builder report to pick up
> transactions. We did this using the part tran table. You will see twoA
> date fields that you can use. One is the sysdate and one is transdate.
> quick simple filter using the >= and the <= can get you thetransactions
> that typically cause this. In 6.1 we used sysdate >= start date of new[mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On
> period and trandate <= end date of period closing.
> Jim
Behalf
> Of Lori Daviessee
> Sent: Friday, February 06, 2009 2:12 PM
> To: 'vantage@yahoogroups.com <mailto:%27vantage%40yahoogroups.com> '
> We have had this happen when a packing slip gets dated outside of the
> current WIP period. During the capture and post of WIP, there is no
> option to modify the date/period of these transactions. To check to
> if this is your issue try running a Inventory/WIP AccountReconciliation
> Report (from Job Management section). The earliest start date I canuse
> is 01/01/70 (we are on 6.10). For and end date, I usually select thenumber
> date of our last closed period. Specify your A/R clearing account
> and check the box to include offsetting accounts. Select Only Unpostedhave
> to G/L transactions. If your issue is a date issue, this report will
> provide you with the necessary information for a journal entry to
> correct the account. (Vantage support says that to fix the issue, you
> can open the period & rerun the capture and post process; however, if
> you have published financials, you need to journal entry it out of the
> period it posted to and journal it into the curre nt period, so we
> not bothered to reopen periods to post.) If checking closed dates doesList
> not produce anything, you may have to check future dates (the highest
> end date our system allows is 12/31/69).
> William Frick & Co's SmartMarkT RFID Named to 2008 Top Ten Products
>This message has been processed via your triumphgroup.com e-mail
address.
