905.700B External C# Application
No problem
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of John Kreger
Sent: 10 July 2013 15:22
Subject: Re: [Vantage] 905.700B External C# Application
Stephen,
Wow thanks. I, like an idiot, added a ds.ShipDtl.Rows[0].SetField("RowMod",
"U") instead of adding it on the ShipHead like it actually needed. Thanks for pointing it out.
Good to go!
John
On Wed, Jul 10, 2013 at 7:48 AM, Stephen Edginton
<stephene@...>wrote:
> Hi John,
> You need to do something like this before the call
> ds.ShipHead.Rows[0].RowMod = "U"; this will ensure the BO method has
> the temp table for shiphead available to it.
> Really it is a bug in the progress logic.
> Hope it helps
> Sent: 09 July 2013 22:58
> Subject: [Vantage] 905.700B External C# Application
> We've created an external application to make our traceability process
> a bit smoother. I've fully integrated the application in several
> different areas of the application and the code I'm showing below used
> to work without issue. The code is adding a pack lines from a gridview
> on the screen. It knows which order and release to ship against based
> on the RAN number in the grid. When I try running the code today, I'm
> getting the following error in the appserver logs:
> (Procedure: 'GetOrderRelInfo bo/CustShip/CustShip.p' Line:119868) **
> No ttShipHead record is available. (91)
> This is thrown when I get an exception at
> "shipment.GetOrderRelInfo(ds, 0, orderRelNum, true);" I've never
> received this error from any of the methods I've called so I'm not
> sure where to start troubleshooting. The method call before it
> (shipment.GetOrderLineInfo) executes without issue. I've tried this
> with various Packs and Orders. It pulls the order release information based on the RAN number field on order releases.
> My method is included below. Any help is greatly appreciated.
> John Kreger
> private void btnPack_Click(object sender, EventArgs e) {
> btnPack.Enabled = false; txtStatus.Visible = true; txtStatus.Text =
> "Processing..."; txtStatus.ForeColor = Color.Gold; Refresh(); string
> AppServerDC = ""; if (Properties.Settings.Default.GoLive == true) {
> AppServerDC = Properties.Settings.Default.LiveAppServerDC;
> else
> AppServerDC = Properties.Settings.Default.TestAppServerDC;
> using (Session epiSession = new
> Session(Properties.Settings.Default.UserName,
> Properties.Settings.Default.Password, AppServerDC,
> Session.LicenseType.Default))
> CustShip shipment = new CustShip(epiSession.ConnectionPool);
> CustShipDataSet ds = shipment.GetByID(curPackID);
> foreach (DataGridViewRow row in grdPalJobs.Rows) { bool proceed =
> true; int orderNum, orderLineNum, orderRelNum; decimal Qty; string RAN
> = row.Cells[0].Value.ToString(); string PartNum =
> row.Cells[1].Value.ToString(); string LotNum =
> row.Cells[2].Value.ToString(); string outCredMsg; Qty =
> Convert.ToDecimal(row.Cells[3].Value.ToString());
> BOReader orderReader = new
> BOReader(epiSession.ConnectionPool);
> DataSet orders = new DataSet();
> //Add code to catch if no order has this ran.
> orders = orderReader.GetList("OrderRelSearch", "(RAN = '" + RAN +
> "')", "OrderNum,OrderLine,OrderRelNum");
> foreach (DataRow orderRow in orders.Tables[0].Rows) { orderNum =
> Convert.ToInt32(orderRow[0]); orderLineNum =
> Convert.ToInt32(orderRow[1]); orderRelNum =
> Convert.ToInt32(orderRow[2]);
> //MessageBox.Show("Order: " + orderNum.ToString() + " Line: " +
> orderLineNum.ToString() + " Release: " + orderRelNum.ToString());
> try
> shipment.GetNewOrdrShipDtl(ds, curPackID, orderNum); } catch
> (BusinessObjectException) { MessageBox.Show("The Epicor pack you are
> trying to update is already shipped. Please reopen the pack or select
> a different pack."); proceed = false; } if (proceed == true) {
> shipment.GetOrderInfo(orderNum, out outCredMsg, ds);
> shipment.GetOrderLineInfo(ds, 0, orderLineNum, PartNum);
> shipment.GetOrderRelInfo(ds, 0, orderRelNum, true); //exception thrown
> here Epicor.Mfg.Common.BusinessObjectException - Unexpected error -
> see appserver logs.
> shipment.GetQtyInfo(ds, 0, Qty, 0m);
> string opRelMsg, opCompMsg, opShipMsg, opLotMsg, opInvMsg,
> opLockQtyMsg, opAllocMsg, opPartListMsg, opLotListMsg, shipCredMsg,
> msg, opPostUpdMsg; bool cError, compError, updComplete, chkCompError,
> chgStatusError; int p = ds.ShipDtl.Count - 1; if (proceed == true) {
> ds.ShipDtl[p].LotNum = LotNum; shipment.UpdateMaster(ds, false, false,
> true, false, false, false, false, curPackID, 2, out opRelMsg, out
> opCompMsg, out opShipMsg, out opLotMsg, out opInvMsg, out
> opLockQtyMsg, out opAllocMsg, out opPartListMsg, out opLotListMsg, out
> shipCredMsg, out cError, out compError, out msg, out opPostUpdMsg, out
> updComplete, out chkCompError, out chgStatusError); //For testing
> purposes.
> MessageBox.Show(opRelMsg + opCompMsg + opShipMsg + opLotMsg + opInvMsg
> + opLockQtyMsg + opAllocMsg + opPartListMsg
> + opLotListMsg + shipCredMsg + msg + opPostUpdMsg);
> grdTest.DataSource = ds.ShipDtl;
> if (proceed)
> txtStatus.Text = "Complete!";
> txtStatus.ForeColor = Color.LawnGreen; Refresh(); } else {
> txtStatus.Text = "Failed!"; txtStatus.ForeColor = Color.Red;
> Refresh(); }
We've created an external application to make our traceability process a
bit smoother. I've fully integrated the application in several different
areas of the application and the code I'm showing below used to work
without issue. The code is adding a pack lines from a gridview on the
screen. It knows which order and release to ship against based on the RAN
number in the grid. When I try running the code today, I'm getting the
(Procedure: 'GetOrderRelInfo bo/CustShip/CustShip.p' Line:119868) ** No
This is thrown when I get an exception at "shipment.GetOrderRelInfo(ds, 0,
orderRelNum, true);" I've never received this error from any of the methods
I've called so I'm not sure where to start troubleshooting. The method call
before it (shipment.GetOrderLineInfo) executes without issue. I've tried
this with various Packs and Orders. It pulls the order release information
John Kreger
txtStatus.Text = "Processing...";
Refresh();
string AppServerDC = "";
else
bool proceed = true;
decimal Qty;
string RAN = row.Cells[0].Value.ToString();
string PartNum = row.Cells[1].Value.ToString();
string LotNum = row.Cells[2].Value.ToString();
string outCredMsg;
Qty = Convert.ToDecimal(row.Cells[3].Value.ToString());
'" + RAN + "')", "OrderNum,OrderLine,OrderRelNum");
orderNum = Convert.ToInt32(orderRow[0]);
orderLineNum = Convert.ToInt32(orderRow[1]);
orderRelNum = Convert.ToInt32(orderRow[2]);
" Line: " + orderLineNum.ToString() + " Release: " +
try
orderNum);
catch (BusinessObjectException)
MessageBox.Show("The Epicor pack you are trying
to update is already shipped. Please reopen the pack or select a different
pack.");
proceed = false;
ds);
PartNum);
true); //exception thrown here Epicor.Mfg.Common.BusinessObjectException -
Unexpected error - see appserver logs.
opInvMsg, opLockQtyMsg, opAllocMsg, opPartListMsg, opLotListMsg,
shipCredMsg, msg, opPostUpdMsg;
chgStatusError;
shipment.UpdateMaster(ds, false, false, true,
false, false, false, false, curPackID, 2, out opRelMsg, out opCompMsg, out
opShipMsg, out opLotMsg, out opInvMsg, out opLockQtyMsg, out opAllocMsg,
out opPartListMsg, out opLotListMsg, out shipCredMsg, out cError, out
compError, out msg, out opPostUpdMsg, out updComplete, out chkCompError,
//For testing purposes.
opShipMsg + opLotMsg + opInvMsg + opLockQtyMsg + opAllocMsg + opPartListMsg
if (proceed)
Refresh();
else
Refresh();
Hi John,
this will ensure the BO method has the temp table for shiphead available to it.
Hope it helps
John Kreger
Refresh();
else
decimal Qty;
string outCredMsg;
try
orderNum);
pack.");
proceed = false;
ds);
PartNum);
chgStatusError;
if (proceed)
Refresh();
else
Refresh();
Stephen,
Good to go!
John
> Hi John,
> to it.
> Hope it helps
> Of John Kreger
> John Kreger
> Refresh();
> else
> decimal Qty;
> string outCredMsg;
> try
> orderNum);
> pack.");
> proceed = false;
> ds);
> PartNum);
> chgStatusError;
> if (proceed)
> Refresh();
> else
> Refresh();
