Awesome! Glad to hear its working for you.
I had forgotten to mention that. If you're on SQL you do need to restart
the app servers after you setup new user codes.
On Sat, May 26, 2012 at 12:02 PM, Greg Payne <gpayne@...>wrote:
> I removed the field, rechecked the user codes. The full description was
> empty, so I made it match the description. Verified the User code. Stopped
> and started the app server. ( not sure if this is necessary, but I wanted
> to change the logging mode anyway ) Added the field back and all of the
> values came in. :) Crowd cheers
> Thanks
> Greg
> -----Original Message-----
> Of John Driggers
> Sent: Saturday, May 26, 2012 9:49 AM
> To: vantage@yahoogroups.com
> Subject: Re: [Vantage] 905.700A epicombo not active for user code
> Glad to hear someone is watching those videos =)
> Did you setup the User Code and the Extended Properties before you created
> EpiCombo? If not, remove the combo and then create a new one.
> If the User Code is setup properly, you should just need to bind the
> EpiCombo to ShortChar07 and the rest should work like magic.
> On Fri, May 25, 2012 at 5:20 PM, Greg Payne <gpayne@...
> >wrote:
> > I have a user code that is in an epicombo on job header into
> > JobHead.ShortChar07 and the field is intermittently not activate.
> > Shows the data properly, but can't be changed.
> > I have another epicombo in po detail and it is fine. I watched the
> > usdoingstuff video on Creating using User Codes and I noticed that
> > when I add a combo it doesn't auto populate with the DisplayName,
> EpiBOName, etc.
> > Should it?
> > I have tried extended properties in the form to make it active on load
> > still it is sometime not. It always seems to work fine if I open the
> > form in developer mode.
> > This was happening in 905.605, but I had hoped that 700 would make it
> > work consistently.
> > thanks for any suggestions.
> > Greg
> > ________________________________
> > CONFIDENTIALITY NOTICE
> > The information contained in this communication, including
> > attachments, is privileged and confidential. It is intended only for
> > the exclusive use of the addressee. If the reader of this message is
> > not the intended recipient, or the employee or agent responsible for
> > delivering it to the intended recipient, you are hereby notified that
> > any dissemination, distribution or copying of this communication is
> > strictly prohibited. If you have received this communication in error,
> > please notify us at (727) 578-6258 and immediately delete the
> communication.
> > "This (document/presentation) may contain technical data as defined in
> > the International Traffic In Arms Regulations (ITAR) 22 CFR 120.10.
> > Export of this material is restricted by the Arms Export Control Act
> > (22 U.S.C. 2751 et seq.) and may not be exported to foreign persons
> > without prior approval form the U.S. Department of State."
> *John Driggers*
> *High End Dev, System Design, Profit Drinking*
> **:: 904.404.9233*
> *:: waffqle@...*
> *:: NO FAXES*
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
> http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
> The information contained in this communication, including attachments, is
> privileged and confidential. It is intended only for the exclusive use of
> the addressee. If the reader of this message is not the intended recipient,
> or the employee or agent responsible for delivering it to the intended
> recipient, you are hereby notified that any dissemination, distribution or
> copying of this communication is strictly prohibited. If you have received
> this communication in error, please notify us at (727) 578-6258 and
> immediately delete the communication.
> "This (document/presentation) may contain technical data as defined in the
> International Traffic In Arms Regulations (ITAR) 22 CFR 120.10. Export of
> this material is restricted by the Arms Export Control Act (22 U.S.C. 2751
> et seq.) and may not be exported to foreign persons without prior approval
*John Driggers*
**:: 904.404.9233*
*:: waffqle@...*
*:: NO FAXES*
