<div id="ygrps-yiv-920289454yiv2794576149ygrp-text">
<div>turn off your finite scheduling to see if it works without it on</div><div>also there are other log files which detail the scheduling process - you should be able to find them in the same file area as long as you have verborse mode on<br clear="none"></div><div class="ygrps-yiv-920289454yiv2794576149ygroups-quoted"><br clear="none"><br clear="none">---In vantage@yahoogroups.com, <msantillan@...> wrote:<br clear="none"><br clear="none"><div id="ygrps-yiv-920289454yiv2794576149ygrps-yiv-626467030">
We are multi plant.
We have a hard server failure now. Could be the issue.
Anyone know if the 905.600 image is somewhere?
Miguel A. Santillan
Compass Manufacturing Systems
510-661-6666 Office
On Behalf Of nhoyt111@...
Sent: Monday, October 14, 2013 11:31 AM
Subject: [Vantage] RE: 9.05.607A MRP Logs: What does this mean?
We used to have this alot in 904 but have been good so far in 905607B. I believe it is deadlocking on the jobs noted above. When ours happened it was due to subassembly parts with method in plant 2 but required on top level job in plant 1. Do you have
only one plant? Have you looked at the noted jobs? Could you have an impossible reference with your capabilities / resource group / resource setup fields? We were told to only have one of those fields complete to ensure scheduling can run.
Nancy
---In vantage@yahoogroups.com, <vantage@yahoogroups.com> wrote:
07:44:21 ------------------------------------------------------------
07:44:21 Starting sub-processes
07:44:55 Scheduling Jobs...
07:44:55 Building PartList Level: 0
07:45:35 Building PartList Level: 1
08:49:11 Process 3 not responding. Abandoned during process 'Scheduling~UF000000004317'
08:49:11 Process 4 not responding. Abandoned during process 'Scheduling~DUF00000001119'
08:50:11 Process 102 not responding. Abandoned during process 'Scheduling~DUF00000001229'
08:50:11 Building PartList Level: 2
The Abandoned during process.
Miguel A. Santillan
</div>
<div style="height:0px;color:rgb(255, 255, 255);"></div></div>
#ygrps-yiv-920289454 #ygrps-yiv-920289454yiv2794576149 #ygrps-yiv-920289454yiv2794576149 --
#ygrps-yiv-920289454yiv2794576149ygrp-mkp {
border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;}
#ygrps-yiv-920289454 #ygrps-yiv-920289454yiv2794576149 #ygrps-yiv-920289454yiv2794576149ygrp-mkp hr {
border:1px solid #d8d8d8;}
#ygrps-yiv-920289454 #ygrps-yiv-920289454yiv2794576149 #ygrps-yiv-920289454yiv2794576149ygrp-mkp #ygrps-yiv-920289454yiv2794576149hd {
color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;}
#ygrps-yiv-920289454 #ygrps-yiv-920289454yiv2794576149 #ygrps-yiv-920289454yiv2794576149ygrp-mkp #ygrps-yiv-920289454yiv2794576149ads {
margin-bottom:10px;}
#ygrps-yiv-920289454 #ygrps-yiv-920289454yiv2794576149 #ygrps-yiv-920289454yiv2794576149ygrp-mkp .ygrps-yiv-920289454yiv2794576149ad {
padding:0 0;}
#ygrps-yiv-920289454 #ygrps-yiv-920289454yiv2794576149 #ygrps-yiv-920289454yiv2794576149ygrp-mkp .ygrps-yiv-920289454yiv2794576149ad p {
margin:0;}
#ygrps-yiv-920289454 #ygrps-yiv-920289454yiv2794576149 #ygrps-yiv-920289454yiv2794576149ygrp-mkp .ygrps-yiv-920289454yiv2794576149ad a {
color:#0000ff;text-decoration:none;}
#ygrps-yiv-920289454 #ygrps-yiv-920289454yiv2794576149 #ygrps-yiv-920289454yiv2794576149ygrp-sponsor #ygrps-yiv-920289454yiv2794576149ygrp-lc {
font-family:Arial;}
#ygrps-yiv-920289454 #ygrps-yiv-920289454yiv2794576149 #ygrps-yiv-920289454yiv2794576149ygrp-sponsor #ygrps-yiv-920289454yiv2794576149ygrp-lc #ygrps-yiv-920289454yiv2794576149hd {
margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;}
#ygrps-yiv-920289454 #ygrps-yiv-920289454yiv2794576149 #ygrps-yiv-920289454yiv2794576149ygrp-sponsor #ygrps-yiv-920289454yiv2794576149ygrp-lc .ygrps-yiv-920289454yiv2794576149ad {
margin-bottom:10px;padding:0 0;}
#ygrps-yiv-920289454 #ygrps-yiv-920289454yiv2794576149 #ygrps-yiv-920289454yiv2794576149actions {
font-family:Verdana;font-size:11px;padding:10px 0;}
#ygrps-yiv-920289454 #ygrps-yiv-920289454yiv2794576149 #ygrps-yiv-920289454yiv2794576149activity {
background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}
#ygrps-yiv-920289454 #ygrps-yiv-920289454yiv2794576149 #ygrps-yiv-920289454yiv2794576149activity span {
font-weight:700;}
#ygrps-yiv-920289454 #ygrps-yiv-920289454yiv2794576149 #ygrps-yiv-920289454yiv2794576149activity span:first-child {
text-transform:uppercase;}
#ygrps-yiv-920289454 #ygrps-yiv-920289454yiv2794576149 #ygrps-yiv-920289454yiv2794576149activity span a {
color:#5085b6;text-decoration:none;}
#ygrps-yiv-920289454 #ygrps-yiv-920289454yiv2794576149 #ygrps-yiv-920289454yiv2794576149activity span span {
color:#ff7900;}
#ygrps-yiv-920289454 #ygrps-yiv-920289454yiv2794576149 #ygrps-yiv-920289454yiv2794576149activity span .ygrps-yiv-920289454yiv2794576149underline {
text-decoration:underline;}
#ygrps-yiv-920289454 #ygrps-yiv-920289454yiv2794576149 .ygrps-yiv-920289454yiv2794576149attach {
clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;}
#ygrps-yiv-920289454 #ygrps-yiv-920289454yiv2794576149 .ygrps-yiv-920289454yiv2794576149attach div a {
#ygrps-yiv-920289454 #ygrps-yiv-920289454yiv2794576149 .ygrps-yiv-920289454yiv2794576149attach img {
border:none;padding-right:5px;}
#ygrps-yiv-920289454 #ygrps-yiv-920289454yiv2794576149 .ygrps-yiv-920289454yiv2794576149attach label {
display:block;margin-bottom:5px;}
#ygrps-yiv-920289454 #ygrps-yiv-920289454yiv2794576149 .ygrps-yiv-920289454yiv2794576149attach label a {
#ygrps-yiv-920289454 #ygrps-yiv-920289454yiv2794576149 blockquote {
margin:0 0 0 4px;}
#ygrps-yiv-920289454 #ygrps-yiv-920289454yiv2794576149 .ygrps-yiv-920289454yiv2794576149bold {
font-family:Arial;font-size:13px;font-weight:700;}
#ygrps-yiv-920289454 #ygrps-yiv-920289454yiv2794576149 .ygrps-yiv-920289454yiv2794576149bold a {
#ygrps-yiv-920289454 #ygrps-yiv-920289454yiv2794576149 dd.ygrps-yiv-920289454yiv2794576149last p a {
font-family:Verdana;font-weight:700;}
#ygrps-yiv-920289454 #ygrps-yiv-920289454yiv2794576149 dd.ygrps-yiv-920289454yiv2794576149last p span {
margin-right:10px;font-family:Verdana;font-weight:700;}
#ygrps-yiv-920289454 #ygrps-yiv-920289454yiv2794576149 dd.ygrps-yiv-920289454yiv2794576149last p span.ygrps-yiv-920289454yiv2794576149yshortcuts {
margin-right:0;}
#ygrps-yiv-920289454 #ygrps-yiv-920289454yiv2794576149 div.ygrps-yiv-920289454yiv2794576149attach-table div div a {
#ygrps-yiv-920289454 #ygrps-yiv-920289454yiv2794576149 div.ygrps-yiv-920289454yiv2794576149attach-table {
width:400px;}
#ygrps-yiv-920289454 #ygrps-yiv-920289454yiv2794576149 div.ygrps-yiv-920289454yiv2794576149file-title a, #ygrps-yiv-920289454 #ygrps-yiv-920289454yiv2794576149 div.ygrps-yiv-920289454yiv2794576149file-title a:active, #ygrps-yiv-920289454 #ygrps-yiv-920289454yiv2794576149 div.ygrps-yiv-920289454yiv2794576149file-title a:hover, #ygrps-yiv-920289454 #ygrps-yiv-920289454yiv2794576149 div.ygrps-yiv-920289454yiv2794576149file-title a:visited {
#ygrps-yiv-920289454 #ygrps-yiv-920289454yiv2794576149 div.ygrps-yiv-920289454yiv2794576149photo-title a, #ygrps-yiv-920289454 #ygrps-yiv-920289454yiv2794576149 div.ygrps-yiv-920289454yiv2794576149photo-title a:active, #ygrps-yiv-920289454 #ygrps-yiv-920289454yiv2794576149 div.ygrps-yiv-920289454yiv2794576149photo-title a:hover, #ygrps-yiv-920289454 #ygrps-yiv-920289454yiv2794576149 div.ygrps-yiv-920289454yiv2794576149photo-title a:visited {
#ygrps-yiv-920289454 #ygrps-yiv-920289454yiv2794576149 div#ygrps-yiv-920289454yiv2794576149ygrp-mlmsg #ygrps-yiv-920289454yiv2794576149ygrp-msg p a span.ygrps-yiv-920289454yiv2794576149yshortcuts {
font-family:Verdana;font-size:10px;font-weight:normal;}
#ygrps-yiv-920289454 #ygrps-yiv-920289454yiv2794576149 .ygrps-yiv-920289454yiv2794576149green {
color:#628c2a;}
#ygrps-yiv-920289454 #ygrps-yiv-920289454yiv2794576149 .ygrps-yiv-920289454yiv2794576149MsoNormal {
margin:0 0 0 0;}
#ygrps-yiv-920289454 #ygrps-yiv-920289454yiv2794576149 o {
font-size:0;}
#ygrps-yiv-920289454 #ygrps-yiv-920289454yiv2794576149 #ygrps-yiv-920289454yiv2794576149photos div {
float:left;width:72px;}
#ygrps-yiv-920289454 #ygrps-yiv-920289454yiv2794576149 #ygrps-yiv-920289454yiv2794576149photos div div {
border:1px solid #666666;height:62px;overflow:hidden;width:62px;}
#ygrps-yiv-920289454 #ygrps-yiv-920289454yiv2794576149 #ygrps-yiv-920289454yiv2794576149photos div label {
color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}
#ygrps-yiv-920289454 #ygrps-yiv-920289454yiv2794576149 #ygrps-yiv-920289454yiv2794576149reco-category {
font-size:77%;}
#ygrps-yiv-920289454 #ygrps-yiv-920289454yiv2794576149 #ygrps-yiv-920289454yiv2794576149reco-desc {
font-size:77%;}
#ygrps-yiv-920289454 #ygrps-yiv-920289454yiv2794576149 .ygrps-yiv-920289454yiv2794576149replbq {
margin:4px;}
#ygrps-yiv-920289454 #ygrps-yiv-920289454yiv2794576149 #ygrps-yiv-920289454yiv2794576149ygrp-actbar div a:first-child {
margin-right:2px;padding-right:5px;}
#ygrps-yiv-920289454 #ygrps-yiv-920289454yiv2794576149 #ygrps-yiv-920289454yiv2794576149ygrp-mlmsg {
font-size:13px;font-family:Arial, helvetica, clean, sans-serif;}
#ygrps-yiv-920289454 #ygrps-yiv-920289454yiv2794576149 #ygrps-yiv-920289454yiv2794576149ygrp-mlmsg table {
font-size:inherit;font:100%;}
#ygrps-yiv-920289454 #ygrps-yiv-920289454yiv2794576149 #ygrps-yiv-920289454yiv2794576149ygrp-mlmsg select, #ygrps-yiv-920289454 #ygrps-yiv-920289454yiv2794576149 input, #ygrps-yiv-920289454 #ygrps-yiv-920289454yiv2794576149 textarea {
font:99% Arial, Helvetica, clean, sans-serif;}
#ygrps-yiv-920289454 #ygrps-yiv-920289454yiv2794576149 #ygrps-yiv-920289454yiv2794576149ygrp-mlmsg pre, #ygrps-yiv-920289454 #ygrps-yiv-920289454yiv2794576149 code {
font:115% monospace;}
#ygrps-yiv-920289454 #ygrps-yiv-920289454yiv2794576149 #ygrps-yiv-920289454yiv2794576149ygrp-mlmsg * {
line-height:1.22em;}
#ygrps-yiv-920289454 #ygrps-yiv-920289454yiv2794576149 #ygrps-yiv-920289454yiv2794576149ygrp-mlmsg #ygrps-yiv-920289454yiv2794576149logo {
padding-bottom:10px;}
#ygrps-yiv-920289454 #ygrps-yiv-920289454yiv2794576149 #ygrps-yiv-920289454yiv2794576149ygrp-msg p a {
font-family:Verdana;}
#ygrps-yiv-920289454 #ygrps-yiv-920289454yiv2794576149 #ygrps-yiv-920289454yiv2794576149ygrp-msg p#ygrps-yiv-920289454yiv2794576149attach-count span {
color:#1E66AE;font-weight:700;}
#ygrps-yiv-920289454 #ygrps-yiv-920289454yiv2794576149 #ygrps-yiv-920289454yiv2794576149ygrp-reco #ygrps-yiv-920289454yiv2794576149reco-head {
color:#ff7900;font-weight:700;}
#ygrps-yiv-920289454 #ygrps-yiv-920289454yiv2794576149 #ygrps-yiv-920289454yiv2794576149ygrp-reco {
margin-bottom:20px;padding:0px;}
#ygrps-yiv-920289454 #ygrps-yiv-920289454yiv2794576149 #ygrps-yiv-920289454yiv2794576149ygrp-sponsor #ygrps-yiv-920289454yiv2794576149ov li a {
font-size:130%;text-decoration:none;}
#ygrps-yiv-920289454 #ygrps-yiv-920289454yiv2794576149 #ygrps-yiv-920289454yiv2794576149ygrp-sponsor #ygrps-yiv-920289454yiv2794576149ov li {
font-size:77%;list-style-type:square;padding:6px 0;}
#ygrps-yiv-920289454 #ygrps-yiv-920289454yiv2794576149 #ygrps-yiv-920289454yiv2794576149ygrp-sponsor #ygrps-yiv-920289454yiv2794576149ov ul {
margin:0;padding:0 0 0 8px;}
#ygrps-yiv-920289454 #ygrps-yiv-920289454yiv2794576149 #ygrps-yiv-920289454yiv2794576149ygrp-text {
font-family:Georgia;}
#ygrps-yiv-920289454 #ygrps-yiv-920289454yiv2794576149 #ygrps-yiv-920289454yiv2794576149ygrp-text p {
margin:0 0 1em 0;}
#ygrps-yiv-920289454 #ygrps-yiv-920289454yiv2794576149 #ygrps-yiv-920289454yiv2794576149ygrp-text tt {
font-size:120%;}
#ygrps-yiv-920289454 #ygrps-yiv-920289454yiv2794576149 #ygrps-yiv-920289454yiv2794576149ygrp-vital ul li:last-child {
border-right:none !important;}
