Mike,
Thanks for the info, this worked.
Rick Hagy
Of Mike Anstey
Sent: Tuesday, March 08, 2011 4:18 PM
Subject: Re: [Vantage] Re: 9.05.603 Configurator
Delete your pcrules directory. It contains compiled code that doesn't
like it when the schema changes between versions. The code will recreate
itself the first time you configure an item.
Sent from my iPhone
On 2011-03-08, at 9:08 AM, "Rick Hagy" <rhagy@...
<mailto:rhagy%40openplan.com> > wrote:
Behalf
Rick Hagy
Of Mike Anstey
Sent from my iPhone
> Karl,what
> I ran the conversion program 11005 it doesn't do anything more then
> the 5905 conversion did.I
> I enter a part on a sales order, and then hit the configurator button.
> My screen pops up, and I hit save, at this time I do not have anything
> on this screen, all the information I need comes from the header. Once
> hit save I get a 4GL Code Error, and the program does not finishgoing
> running.
> I can unapproved the revision and the configuration, and then approve
> everything, and it will work just fine, but if Epicor thinks I am
> to do that for a couple of thousand parts they are crazy![mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On
> Rick Hagy
> -----Original Message-----
Behalf
> Of krweisel"Rick" <rhagy@...> wrote:
> Sent: Tuesday, March 08, 2011 8:40 AM
> Subject: [Vantage] Re: 9.05.603 Configurator
> Rick,
> I've been testing on 9.05.603 with configurators and have
> run into a few things. We skipped 602x entirely and after
> going to 603 our "layered" or template bom sub-configurators
> were not ever running, just the top parent config.
> - Running conversion program 11005 resolved that for us. We
> are running 603 with E9/Open Edge x32, on a x64 Win Svr 08
> with SQL 08 in x64 mode.
> - I'm now seeing that the firing off of the On Leave events
> appears to have changed. I believe that we now need an actual
> real user to exit (tab off) of an input to make the On Leave
> event fire. Previously I could get all controls on a page
> (and the page event itself) to pre-run their OnLeave
> events at the page load.
> ? have you seen anything similar, or found any way to get
> the events to fire properly ?
> - Karl Weisel.
> --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ,
> > Has any one using the Configurator upgraded to 9.05.603?
> > If so have you had any problems with the Configurators?
> > At this time I have run the Conversion program 5905, and my
> Configurators are not working properly.
> > Thanks,
> > Rick
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> have already linked your email address to a yahoo id to enable access.
> (1) To access the Files Section of our Yahoo!Group for Report Builder<http://groups.yahoo.com/group/vantage/files/>
> and Crystal Reports and other 'goodies', please goto:
> (2) To search through old msg's goto:[Non-text portions of this message have been removed]
> http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
