Thanks for the reply Chris.
Support gave the exact opposite advice. "Run the install for each database..."
database with all of the system code in it.
We're up and running on 808B and are now off to finish the Crystal XI R2
updates...
Mark W.
> You install the software once although each database would need possibleThat's exactly what we did. I wanted to double check with the gang since Tech
> schema changes and conversion.
> I'm not sure what you're asking "Is it possible to install the systemYou are correct about OpenEdge. I went back and saw that there's only a main
> software into each database?" Each major release of Progress and OpenEdge
> can only be stored once per computer. That is, you can install 9.1D and
> 10.0B on one computer but you wouldn't be able to have OpenEdge 10.0B SP3
> and SP5 coexist, nor 10.0A and 10.0B. The installation won't even let you do
> it as it looks for the presence of itself. There's also a separate Admin
> Service for each major release.
> Similarly, you can install Vantage 6.1 and 8.0 on one computerI think one would only do that to stress test the server. ;-)
updates...
Mark W.
