Well that's what you get for opening a call on Valentines Day. The
Epicor staff was so consumed by all the love, (or chocolate), they
forgot ever receiving the call.
Gerard M Wadman
Sr. Network Systems Engineer
Scandius BioMedical Inc.
11A Beaver Brook Road
Littleton, MA 01460
978/486-4088 x 124
978/486-4108 (fax)
http://www.scandius.com/
This e-mail is for the use of the intended recipient(s) only. If you
have received this e-mail in error, please notify the sender immediately
and then delete it. If you are not the intended recipient, you must not
use, disclose or distribute this e-mail without the author's prior
permission. We have taken precautions to minimize the risk of
transmitting software viruses, but we advise you to carry out your own
virus checks on any attachment to this message. We do not accept
liability for any loss or damage caused by software viruses
Of Janet Parker
Sent: Wednesday, May 23, 2007 9:15 AM
Subject: [Vantage] Re: 803: PO receipt error
This should be a "known issue" at Epicor support since I reported it on
2/14/07 and we just received a one-off fix for the problem from our Star
group representative. I was told that scr 44400 was opened with
development for this issue. We've been told that the fix will be part
of the G patch release.
We turned off the requirement to calculate landed cost since this is not
a function we need but still got this error on an "intermittent" basis.
It took a while to track down the "intermittent" errors but we
eventually found that we were only experiencing this error under the
following condition: receipt of an "inventory" line and an "other" line
on the same vendor packing slip. We were able to receive multiple
inventory lines or multiple other lines against the same vendor packing
slip with no error. Our workaround was to only receive like-type lines
on a vendor packing slip.
Hope this information helps.
Thank you.
Janet L. Parker
Senior Accountant
Granite Microsystems, Inc.
Confidentiality Notice. This email transmission (and any of the
documents
accompanying it) may contain confidential information belonging to the
sender. The information is intended only for the use of the individual
or
entity named above. If you are not the intended recipient, you are
hereby notified that any disclosure, copying, distribution or the taking
of
any action in reliance on the contents of this information is strictly
prohibited.
If you are not the intended recipient(s) and have received this
communication in error, please do not distribute it. Instead, please
notify
the sender at (262) 242-8800 and destroy all copies of this email and
any attachments. Thank you.
Gerard M Wadman
Littleton, MA 01460
978/486-4088 x 124
978/486-4108 (fax)
Of Janet Parker
Thank you.
Janet L. Parker
Senior Accountant
documents
or
of
prohibited.
notify
