Hi,
I want to add refresh/refresh all/clear buttons on to my Dashboard Tracker View, but I don't know whee to start.
I have read the emails below, but Im still unclear how you assign the code to a button on the tracker view.
I also want to add a refresh all and clear button - does anyone know how to do this?
Also I have a dashboard/tracker view and no matter what I try the data won't display when I click the standard vantage refresh button - it worked 2 days ago but doesn't work now.
I have tried all sort. The BAQ itself behing the dashboard retrieves the information with no problems.
I am running
CHRIS THOMPSON
Sent: Tuesday, 17 March, 2009 22:18:42
Subject: RE: [Vantage] 8.03X refresh code
Aaron,
Change to code as follows:
Dim DBTVP As Object =
DBTVP_078df35b_ 7288_41b6_ ab23_f1ce94913ee c
DBTVP.GetType( ).GetMethod( "RefreshDB" ,System.Reflecti on.BindingFlags. Ins
tance Or System.Reflection. BindingFlags. NonPublic) .Invoke(DBTVP, Nothing)
Change the GUID to be that of your dashboard and this
should work.
Regards,
Stephen
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf
Of Aaron Hoyt
Sent: 17 March 2009 21:09
To: vantage@yahoogroups .com
Subject: Re: [Vantage] 8.03X refresh code
I am using the second method and in Vantage 8.03.407A.
Progress at the latest patch for said Vantage level. Applied both just
over a week ago.
Aaron
Stephen Edginton wrote:
__
I am running
> > if it is in a Dashboard you do it as follows:Cheers,
> > Customize the tracker View Panel
> > In the Tree on the left, select the Top Node that looks
> > like a strange number (GUID) it will be something like
> > 078df35b-7288- 41b6-ab23- f1ce94913eec                                          {{{If I select it, nothing happens and cant edit it.}}}
> > Then Replace all of the "-" with "_"
> > And Add "DBTVP_" to the start as follows:
> > DBTVP_078df35b_ 7288_41b6_ ab23_f1ce94913ee c.RefreshDB( )
> > DBTVP (Stands for Dashboard Tracker View Panel)
> > ResfreshDB() is the method to refresh.
CHRIS THOMPSON
Aaron,
should work.
Regards,
Stephen
Of Aaron Hoyt
over a week ago.
Aaron
><mailto:vantage% 40yahoogroups. com>
> What version are you running
> From: vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com>
> [mailto:vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com><mailto:vantage% 40yahoogroups. com>] On
> Behalf<mailto:vantage% 40yahoogroups. com>
> Of Aaron Hoyt
> Sent: 17 March 2009 19:21
> To: vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com>
> Subject: Re: [Vantage] 8.03X refresh code<mailto:vantage% 40yahoogroups. com>
> Stephen or another talented programmer,
> I think I am almost there following instructions below, but what if I
> get an error message containing the following portion that seems
> relevant...
> "System.MissingMemb erException: Public member 'RefreshDB' on type
> 'DashboardTrackerVi ewPanel' not found."
> Any thoughts?
> Aaron
> > Aaron,
> > If it is within a Form and not a Dashboard then you
> > would use
> > oTrans.Refresh( )
> > Hope this helps
> > Regards,
> > Stephen
> > Behalf
> > Of Aaron Hoyt
> > Sent: 17 March 2009 15:01
> <mailto:vantage% 40yahoogroups. com>[Non-text portions of this message have been removed]
> > Subject: [Vantage] 8.03X refresh code
> > Can anyone fill me in on the appropriate code to add to a
> customization
> > that will execute a refresh (either just refresh or refresh all). I
> > want to create a refresh button on a dashboard, but I don't know
> VB.Net
> > well enough (or at all as the case may be). Any help would be
> > appreciated.
> > Thanks ahead of time,
> > Aaron Hoyt
> > Vantage Plastics
__
