8.03.408 problem - configurator parts
Just the larger upgrades. The patches usually aren't a problem. We're
using the configurator for the same reason.
Blake Clemens
DMC
Of virginia.joseph74
Sent: Friday, June 05, 2009 8:51 AM
Subject: [Vantage] Re: 8.03.408 problem - configurator parts
Hi Blake: When you say that "Every time we perform an upgrade our
configurators break." Does your reference to upgrades mean patches like
407b to 407c or large jumps like 405 to 408? What about installing
service packs? Just trying to get a feel for how often you experience
this problem since we are looking at using the configurator to fine tune
our quoting process. I just want to be prepare for how much fixing I am
in for each time we upgrade.
Steven Gotschall <sgotschall@...> wrote:
> I wish it was that simple, but its not. I eventually got a couple of
them compiled, but I have a bunch of other ones that are still broken
and I can't figure out why. I am uploading our database to Epicor so
they can look at it.
> From: Blake Clemens <blake.clemens@...>
> Sent: Thursday, June 4, 2009 8:06:16 AM
> Subject: RE: [Vantage] 8.03.408 problem
> We've had a similar problem with our configurators whenever we
upgrade.
> Every time we perform an upgrade our configurators break. We usually
> end up deleting everything within the PC Rules folder. After that the
> configurators still work poorly but over the course of the day they
> progressively get better. Support could never give us a good answer
why.
> Thanks,
> Blake Clemens
> DMC
> ____________ _________ _________ __
> From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On
Behalf
> Of sgotschall
> Sent: Wednesday, June 03, 2009 9:18 AM
> To: vantage@yahoogroups .com
> Subject: [Vantage] 8.03.408 problem
> Vantage 8..03.408 Progress
> I upgraded our developement server from 8.03.407a to 408. When I did,
> all configured parts broke. When I go into the configurator and try to
> save the program or test rules, I get a "Compilation error in the
Rules.
> File 'c:\epicor\mfgsys80 3\Server\ pcrules\CLchairA 11.p' at line 1197
> column 99. Error 565."
> I open a case with Epicor on this, but I was wondering if anyone else
> has experienced this? Epicor said this is the first reported
> configurator problem with 408.
Vantage 8.03.408 Progress
I upgraded our developement server from 8.03.407a to 408. When I did, all configured parts broke. When I go into the configurator and try to save the program or test rules, I get a "Compilation error in the Rules. File 'c:\epicor\mfgsys803\Server\pcrules\CLchairA11.p' at line 1197 column 99. Error 565."
I open a case with Epicor on this, but I was wondering if anyone else has experienced this? Epicor said this is the first reported configurator problem with 408.
We've had a similar problem with our configurators whenever we upgrade.
progressively get better. Support could never give us a good answer why.
Blake Clemens
DMC
Of sgotschall
I wish it was that simple, but its not. I eventually got a couple of them compiled, but I have a bunch of other ones that are still broken and I can't figure out why. I am uploading our database to Epicor so they can look at it.
Blake Clemens
DMC
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf
Of sgotschall
Hi Blake: When you say that "Every time we perform an upgrade our configurators break." Does your reference to upgrades mean patches like 407b to 407c or large jumps like 405 to 408? What about installing service packs? Just trying to get a feel for how often you experience this problem since we are looking at using the configurator to fine tune our quoting process. I just want to be prepare for how much fixing I am in for each time we upgrade.
> Thanks,
> Blake Clemens
> DMC
> Of sgotschall
