If I understand your question correctly when the pick list is printed out it
will show the bin to be picked from. With the parts selected as
non-quantity bearing you will only be able to purchase them as other. When
they are received in it will not tell them to put them in the bin that is
selected as default under the part master.
Steve
Sent: July 24, 2008 1:26 PM
To: vantage@yahoogroups.com; aaron.hoyt@...
Subject: RE: [Vantage] 8.03.405 Tooling / Fixturing
Thank you Steve & Aaron for the quick responses. We are going to test
this in the test database. One question, even though it is a
non-quantity bearing item, are default warehouses & bins maintained
giving us the ability to locate the tooling?
From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
[mailto:vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com] On
Behalf
Of vantage
Sent: Wednesday, July 23, 2008 2:43 PM
To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
We are doing this also and using MRP and no demand happens from the MRP
run,
but you will see the items in the issue screen. Mass issue will not do
anything with them leaving them in a required state on the issue screen.
They will also show up on the job pick list and the job traveler unless
you
modify the reports to hide them if you need to.
Steve
<mailto:aaron.hoyt%40vantageplastics.com> lastics.com
<mailto:aaron.hoyt%40vantageplastics.com> ]
Sent: July 23, 2008 2:22 PM
Subject: Re: [Vantage] 8.03.405 Tooling / Fixturing
Bruce,
With the exception of the non-quantity bearing part, this is how we
determined was best to handle our tooling. I have given some thought to
use resource instead but we can't figure it it would be any better than
what we are doing now.
We don't use MRP though.
Aaron Hoyt
Vantage Plastics
Butler, Bruce wrote:
Steve
Behalf
Of vantage
run,
you
Steve
Bruce,
Aaron Hoyt
Vantage Plastics
>have
> We have recently moved from Vantage 8.0 to 8.03.405. With 405, we have
> the ability to set a part as non-quantity bearing. We are considering
> the following theory for tracking our Tooling/Fixturing dilemma we
> lived with for so long;(not
> Note; when referencing tooling I am talking about machine fixturing
> expendable tools, yet).would
> I. Setup Warehouse (ie. Tooling) and create bin locations
> for Tooling inventory
> II. Setup Tooling parts (ie. T-xxxxx).
> a. Set Part class = Tooling
> b. Set as non-quantity bearing.
> c. Set default warehouse & bin = location where tooling is typically
> stored.
> III. Assign tooling to appropriate BOMs.
> We want to be absolutely sure no demand requirements are set which
> muddy MRP. Has anyone tried this method or use Vantage in another way<mailto:bbutler%40sawing.com>
> (ie. Resources) which works for them and is willing to share?
> Thank you,
> Bruce Butler
> Information Systems Manager
> Marvel Manufacturing Company, Inc.
> 3501 Marvel Drive
> Oshkosh, WI 54902
> p. 920.236.7200
> f.: 920.236.7209
> bbutler@sawing. <mailto:bbutler%40sawing.com> com
> <mailto:bbutler@sawing. <mailto:bbutler%40sawing.com> com<mailto:bbutler%40sawing.com>>
