8.03.405 is out
Just to follow up...
The Order Entry screen slow to change between lines issue turned out to
be a "Base Extension" Customization (that I can't quite pin down where
it came from) called Order Tracker (not to be confused with the actual
Order Tracker Screen). I had to create a customization based on the
"Base" and then set that to be the active customization and the speed
issues went away (thank you Sharon).
The Customer Part number only allowing the first Customer part is a
confirmed bug by at least 5 companies and until now is slated for patch
in 8.03.406 due out Aug. 18 (at current).
Aaron
Aaron Hoyt wrote:
> Ok,
> Since we finally made the jump to 8.03.403D about a month ago, we
> decided to make the jump to 405 this past weekend (mostly because we are
> 24/7 now and the 4th was a good opportunity to upgrade as well as have
> tech support available). We were in hopes that this would solve a
> problem with Order entry (namely changing from one line to another in a
> multi line order takes in excess of 30 seconds where everything else in
> order entry happens within 2 to5. This problem was not solved. Is
> anyone else experiencing this or is it just us?
> Also, please note that if you have multiple customer part numbers for a
> single part number in your system (we have one part number for the
> material mix in our extrusion plant and a customer part number for each
> size we sell it as) when you input the part you are selling, it will
> pull the first customer part number. That was not an issue in the past
> because you could just select the correct number, but now in 405 no
> matter what customer part number you select you get the first record for
> that "our part number" returned. We are submitting this bug this morning.
> I will post other issues as they show up.
> Aaron Hoyt
> Vantage Plastics
> Greg Gillette wrote:
> > There is a one off for that issue with .405. We had a huge problem
> > with the Stock Status report on our Progress DB. It took approximately
> > 3 hours to run. We were sent the 404B Stock Status .r file which
> > completed in a few minutes. You probably won't have this problem on
> > SQL but anyone with Progress should be aware.
> > Greg
> > -----Original Message-----
> > From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> > [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> <mailto:vantage%40yahoogroups.com>] On
> > Behalf Of debbiehilopss
> > Sent: Wednesday, July 02, 2008 08:45
> > To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> > Subject: [Vantage] Re: 8.03.405 is out
> > Hi Bill,
> > Any more news on this ? We are about to install vantage (sql) on a
> > separate test server and i need to decide tomorrow whether to stick
> > with 404B or goto 405.
> > Does anyone know if this is a problem only with menu maint or does
> > it also affect process security ?
> > many thanks
> > debs
> > --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> <mailto:vantage%40yahoogroups.com>,
> > "hoomail4me" <hoomail4me@...> wrote:
> > > I have installed 405 in my test environment and found a problem
> > with
> > > menu security. All users and/or groups listed in the "Allow
> > > Access-Selected Groups/Users" list has reverted to the security ID,
> > > not the security description. Makes it very hard to determine who
> > has
> > > access.
> > > The maintenance also seems very flaky with various errors thrown
> > out
> > > when trying to save and the "Allow Access-Groups/Users" list is not
> > > displaying anything.
> > > I would not feel comfortable moving to this release until this
> > issue
> > > has been fixed.
> > > Note: Did open a call with Epicor and they were able to reproduce
> > in
> > > their environment but not word on a fix.
> > > Bill
> > "Mark Wonsil" <mark_wonsil@> wrote:
> > > > Our CAM sent us a note that the next Vantage/Vista Service Pack
> > has
> > > gone to
> > > > general availability and can be downloaded from Epicweb.
> > > > Mark W.
> > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> > have already linked your email address to a yahoo id to enable access. )
> > (1) To access the Files Section of our Yahoo!Group for Report Builder
> > and Crystal Reports and other 'goodies', please goto:
> > http://groups.yahoo.com/group/vantage/files/.
> <http://groups.yahoo.com/group/vantage/files/.>
> <http://groups.yahoo.com/group/vantage/files/.>>
> > http://groups.yahoo.com/group/vantage/messages
> <http://groups.yahoo.com/group/vantage/messages>
> <http://groups.yahoo.com/group/vantage/messages>>
> > (3) To view links to Vendors that provide Vantage services goto:
> > http://groups.yahoo.com/group/vantage/linksYahoo
> <http://groups.yahoo.com/group/vantage/linksYahoo>
> <http://groups.yahoo.com/group/vantage/linksYahoo>>! Groups Links
Our CAM sent us a note that the next Vantage/Vista Service Pack has gone to
Mark W.
Do you know what it fixes?
Kersten MacLennan
IT/ERP Analyst
Semrock, Inc.
3625 Buffalo Rd.,
Suite 6
Rochester, NY 14624
585-594-7009
585-594-7095 fax
kmaclennan@...
The Standard in Optical Filters for Biotech & Analytical Instrumentation
Hundreds of Thousands of Ion Beam Sputtered filters delivered -
extensive inventory now!
The information contained in this message and any attachments may be
privileged, confidential, and protected from disclosure. If the reader
of this message is not the intended recipient, or any agent responsible
for delivering this message to the intended recipient, you are hereby
notified that any dissemination, distribution, or copying of this
communication may be unlawful and therefore strictly prohibited. If you
received this message in error, please reply to the message and delete
it. Thank you
Of Mark Wonsil
Sent: Friday, June 13, 2008 7:00 AM
Subject: [Vantage] 8.03.405 is out
to
Mark W.
The Install guide / changelist is in PDF form on the site as well (35
pages worth)
--- In vantage@yahoogroups.com, "Kersten MacLennan" <kmaclennan@...>
> Kersten MacLennan
> IT/ERP Analyst
> Semrock, Inc.
> 3625 Buffalo Rd.,
> Suite 6
> Rochester, NY 14624
> 585-594-7009
> 585-594-7095 fax
> kmaclennan@...
Instrumentation
reader
responsible
hereby
you
delete
> it. Thank you
Behalf
> Of Mark Wonsil
gone
> to
> Mark W.
> pages worth)
Like Bernie says, the Install guides now include what's been changed/fixed.
It reads more like 404C than 405 but here's a few of the enhancements:
- There's a new Crystal Runtime (03_05_2008)
- The configurator can now use include files for on-leave expressions (cool)
- Various Performance improvements
More info here:
http://patches.epicor.com/manufacturing/mfg/8_03_400/ServicePackInstall_Chan
geList_803405.pdf
or
http://tinyurl.com/49jwe6
Mark W.
Has anybody rolled out to production? Call me gun shy, but I am gun shy.
----- Original Message ----
Sent: Friday, June 13, 2008 10:03:14 AM
Subject: RE: [Vantage] Re: 8.03.405 is out
> pages worth)
More info here:
http://patches. epicor.com/ manufacturing/ mfg/8_03_ 400/ServicePackI nstall_Chan
geList_803405. pdf
or
http://tinyurl. com/49jwe6
Mark W.
We installed the patch this weekend and so far so good. The only
problem I have heard so far is we have one report that is not
behaving. What we are anxious to see is if this fixes the MRP
scheduling problems.
Brian
--- In vantage@yahoogroups.com, Chad Christianson
gun shy.
> From: Mark Wonsil <mark_wonsil@...>
(35
> > pages worth)
changed/fixed.
enhancements:
expressions (cool)
> More info here:
> geList_803405. pdf
> or
> Mark W.
I'm with Chad. After the bug laden disaster 404B proved to be, I have zero confidence in Epicor's prelease testing and quality control.
Is any one out there USING 405A yet on their live system? If so, what are you finding (both good and bad)?
Rob Brown
--- On Wed, 6/25/08, Chad Christianson <chagansonthelake@...> wrote:
Subject: Re: [Vantage] Re: 8.03.405 is out
Date: Wednesday, June 25, 2008, 5:12 PM
To: vantage@yahoogroups .com
Sent: Friday, June 13, :03:14 AM
> pages worth)
More info here:
geList_. pdf
or
Mark W.
I have installed 405 in my test environment and found a problem with
not the security description. Makes it very hard to determine who has
access.
The maintenance also seems very flaky with various errors thrown out
I would not feel comfortable moving to this release until this issue
has been fixed.
Note: Did open a call with Epicor and they were able to reproduce in
Bill
gone to
> Mark W.
Hi Bill,
many thanks
debs
with
has
> access.
out
issue
> has been fixed.
in
> Bill
has
> gone to
> > Mark W.
We had this same issue when we upgraded to 404b. All the groups and users
were displayed as the ID and not the description. Support emailed me a
quick progress script to run and clean it up. It didn't seem like a big
deal, but it surprises me that they still have this same problem in 405.
Daniel Laidig
Laidig Systems, Inc.
(574) 256-0204 ext. 229
<mailto:daniellaidig@...> daniellaidig@...
_____
debbiehilopss
Sent: Wednesday, July 02, 2008 8:45 AM
Hi Bill,
many thanks
debs
--- In vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com,
with
has
> access.
out
issue
> has been fixed.
in
> Bill
> --- In vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com, "Mark
has
> gone to
> > Mark W.
There is a one off for that issue with .405. We had a huge problem with the Stock Status report on our Progress DB. It took approximately 3 hours to run. We were sent the 404B Stock Status .r file which completed in a few minutes. You probably won't have this problem on SQL but anyone with Progress should be aware.
Greg
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of debbiehilopss
Hi Bill,
many thanks
debs
with
has
> access.
out
issue
> has been fixed.
in
> Bill
has
> gone to
> > Mark W.
Ok,
Aaron Hoyt
Vantage Plastics
> Greg
> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>] On
> Hi Bill,
> many thanks
> debs
> --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>,
> with
> has
> > access.
> out
> issue
> > has been fixed.
> in
> > Bill
> has
> > gone to
> > > Mark W.
> <http://groups.yahoo.com/group/vantage/linksYahoo>! Groups Links
