--- In vantage@yahoogroups.com, "gyorkillinois" <gyork@...> wrote:
as well as for custom reporting. To get started just add a menu option
that uses one of the UD tables UI programs, e.g.
Epicor.Mfg.UI.UD01Entry.dll. Start developer mode and then open up
that menu option to customize the UI.
>this
> Has anyone used a UD table to store data that can be displayed and
> maintained from either a standard form or a custom sheet? The Epicor
> Tools User Guide has an excellent example of how to use UD tables as
> the source of a combo box control on a form. Of course, the data is
> maintained via the UD table maintenance screen from the menu. I would
> like to use a UD table to store data that the user can maintain
> directly from controls on a custom sheet. If this is possible, I need
> some help with the code. Certainly many of you could benefit from
> use of UD tables. Thank you in advance.I actually use UD tables to store several things we need for validation
> Gary York
