8.03.403D Customization
Fons,
Thank you. That's basically what it says in the tools guide, but laid out
like this it works. The tools guide had me select the menu id (that did not
exist) and these instructions have you type it in. Thank you! This is the
last part of the puzzle that I have been unable to solve.
Aaron
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf Of
Fons van der Beek
Sent: Wednesday, December 19, 2007 3:30 PM
Subject: Re: [Vantage] 8.03.403D Customization
This should help
*CUST How to customize programs within the MES menu.*
CUST
PROBLEM DESCRIPTION:
I know how to customize the main MES menu screen, but how do I customize
programs within the MES menu? I want to customize Start Production
Activity or End Activity, for example.
PROBLEM RESOLUTION:
In version 8.00.805 a parameter was added so that you will get the layer
and translation screen when launching MES. This is the same screen you
get when you use Developer Mode in the the main 8.0 application. There
are a couple of different processes that you have to create.
1. Creating a MES Developer Icon:
* Make a copy of your MES icon and rename it to something like
MES Developer
* Then right click on it and choose Properties
* In the Target field locate where it shows -MES and change it
to -MESC.
2. Identify the Key and Calling App parameters and customizing the End
Activity Screen
* Launch the MES Developer icon
* On the Select Customization and Translation screen check Base
Only and click OK
* A second Select Customization and Translation screen will
appear for App.SysMonitorEntry.SysMonitorForm, check Base Only and click
OK
* You will note that most of the buttons are not active, you
need to clock an employee in to activate the buttons
* Now click on the program you want to customize (End Activity)
* Write down the Key and Calling App parameters, you will need
these later
Key: Epicor.Mfg.UI.EndActvityEntry.dll
Calling App: Epicor.Mfg.Menu.MES
* Click OK
* Check Base Only on the Select Customization and Translation
screen for App.EndActivityEntry.EndActForm and click OK
* Choose Tools >> Customization
* Customize the form as you see fit (this is just like
customizing the UI in the standard application)
* Save your customization and provide name/description
* Close out of MES
3. Create the Sub Process entry
Because MES program are not attached to the standard menu, you need to
create a "dummy" menu id
* Log into a standard 8.0 session
* Go to System Management >> Utilities >> Sub Process Maintenance
* Choose File >> New
* Enter a unique Process ID (These all need to start with UD,
i.e. UDENDACT)
* Enter a Name (i.e. Custom End Activity)
* Parent Process = PROCESS
* Give it a unique sequence number (i.e. 10, 20, 30, etc.)
* Make sure the Enable checkbox is checked
* Program Type = Non Menu Item
* Program = Epicor.Mfg.UI.EndActivityEntry.dll (Browse to it or
type it in)
* Customization = name of custom you previously named (should
be in the drop-down list)
* Click Save and exit out of Sub Process Maintenance
4. Create a Process Calling entry
* Go to System Management >> Utilities >> Process Calling
Maintenance
* Process Called Reference = Epicor.Mfg.UI.EndActivityEntry
(Key value from section #2)
* Called From = Epicor.Mfg.Menu.Mes (Calling App from section #2)
* Menu ID = UDENDACT (Menu ID create in section #3)
* Save and close Process Calling Maintenance
5. Test the customization
* Log in to the regular MES shortcut ( the one with -MES not -MESC)
* Clock in an employee to activate program buttons
* Click on the End Activity button
* You should see your customization (i.e. textbox, etc) or your
custom procedure code should run
Aaron Hoyt schreef:
> That got me the custom MES screen, but now I am looking to get a custom
> Start Production Activity screen.
> Epicor.Mfg.UI.StartProductionActivityEntry.dll is the program with the
> customization. Any idea how to make this the default screen when someone
> clicks the Start Production Activity button in MES?
> Thanks,
> Aaron
Of
> Scott Litzau
> Sent: Wednesday, December 19, 2007 11:47 AM
> Subject: RE: [Vantage] 8.03.403D Customization
> I only set up a Sub-Process, not a Process Calling.
> In Sub-Process make sure the Program area is setup like
> Program Type: Non Menu item
> Program: Epicor.Mfg.Menu.Mes.dll
> Customization: (Customization name)
> Then in the default.mfgsys file on the MES station put in the Process ID
> you
> assigned in the <MESCustomMenuID value="" />
> Scott
> Of
> Aaron Hoyt
> Sent: Wednesday, December 19, 2007 10:19 AM
> To: Vantage Group
> Subject: [Vantage] 8.03.403D Customization
> It's time for another shout out to the group for help connecting the
dots.
> I am trying to deploy a custom StartProductionActivity screen in MES. I
> managed to find the place to get a Custom MES Main screen, but now I am
> following the tools guide and there seems to be a gap in information. I
> have created "Sub Process" for my custom screen. Now as I try to set up
> the
> "Process Calling" I don't see anything to work with when I hit "Load
> Custom
> Processes".
> Can anyone offer some assistance in getting the MES screen to call my
> custom
> Thanks in advance,
> Aaron Hoyt
> Vantage Plastics
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
have
> (1) To access the Files Section of our Yahoo!Group for Report Builder
and
> Yahoo! Groups Links
> Yahoo! Groups Links
It's time for another shout out to the group for help connecting the dots.
have created "Sub Process" for my custom screen. Now as I try to set up the
"Process Calling" I don't see anything to work with when I hit "Load Custom
Processes".
Can anyone offer some assistance in getting the MES screen to call my custom
Thanks in advance,
Aaron Hoyt
Vantage Plastics
Then in the default.mfgsys file on the MES station put in the Process ID you
Scott
Aaron Hoyt
To: Vantage Group
Processes".
Thanks in advance,
Aaron Hoyt
Vantage Plastics
Yahoo! Groups Links
Aaron
Scott Litzau
you
Scott
Of
Aaron Hoyt
To: Vantage Group
the
Custom
Processes".
custom
Thanks in advance,
Aaron Hoyt
Vantage Plastics
Yahoo! Groups Links
This should help
CUST
PROBLEM RESOLUTION:
MES Developer
to -MESC.
Activity Screen
Only and click OK
appear for App.SysMonitorEntry.SysMonitorForm, check Base Only and click OK
these later
* Click OK
* Close out of MES
i.e. UDENDACT)
type it in)
Maintenance
> Thanks,
> Aaron
> Scott Litzau
> you
> Scott
> Of
> Aaron Hoyt
> To: Vantage Group
> the
> Custom
> Processes".
> custom
> Thanks in advance,
> Aaron Hoyt
> Vantage Plastics
> Yahoo! Groups Links
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have already linked your email address to a yahoo id to enable access. )
> (1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups.yahoo.com/group/vantage/files/.
> (2) To search through old msg's goto: http://groups.yahoo.com/group/vantage/messages
> (3) To view links to Vendors that provide Vantage services goto: http://groups.yahoo.com/group/vantage/links
> Yahoo! Groups Links
What we have done is, add a Menu Item under the
Production Management > Job Mangement > General Operations and gave
it a 'unique' menu ID UDJMGOSP with a name Start Production Activity.
The Program is: Epicor.Mfg.UI.StartProductionActivityEntry.dll
and reference your customization.
In the MESMenu Customization define a button:
Private WithEvents btnStartProductionActivity
In the Form Load Event, set the new button to 'mirror' the base
button:
btnStartProductionActivity = CType(csm.GetNativeControlReference
("6e0b1e1f-5c18-486b-9dd1-adca4a309737"), EpiButton)
btnStartProductionActivity.Enabled = True
Add a Sub to handle the Click event which will call the Menu Item
with the customization:
Private Sub btnStartProductionActivity_Click(ByVal Sender As Object,
ByVal args As EventArgs) Handles btnStartProductionActivity.Click
ProcessCaller.LaunchForm(MESMenu, "UDJMGOSP")
End Sub
That *should* do it
bw
custom
the
someone
> Thanks,
> Aaron
Behalf Of
> Scott Litzau
Process ID
> you
> Scott
Behalf
> Of
> Aaron Hoyt
> To: Vantage Group
the dots.
MES. I
now I am
information. I
set up
> the
hit "Load
> Custom
> Processes".
call my
> custom
> Thanks in advance,
> Aaron Hoyt
> Vantage Plastics
must have
access. )
Builder and
> Yahoo! Groups Links
