8.03.4.09A Order entry error Record has been modified by another
Yes. 8.03.409B.
Sorry, couldn't resist.
jilllopez1245
Sent: Wednesday, June 09, 2010 2:29 PM
Subject: [Vantage] Re: 8.03.4.09A Order entry error Record has been modified
by another user
We just loaded 409A last night and have been having the same problem. Does
anyone know if there is a fix for this?
"pklein256" <pklein@...> wrote:
> Since we've gone up to 4.09A within order entry, we regualarly get the
following error message:
> Message: Record has been modified by another user and couldn't be updated.
Please press the Refresh button and re-enter your changes.
> Type: UpdateConflict
> Program: core/BizRuleEngine.p
> Method: Main-Block
> Table: OrderHed
> Row: 0x00000000026343af
> Field: TermsCode
> I know we normally get this message when someone else has updated the
record. NORMALLY you'd hit refresh, re-apply your changes, save the record
and move on.
> This is not the case.
> This can be a newly entered order, that no one has changed - we go back
into the order to make changes and get the error. the refresh button does
NOT work. I tried to update the record using DMT and still get the same
error message. It's like there's garbage data within the record, it thinks
it's been updated and can't update itself.
> Epicor says to do a dump and load. (which we did right before the 4.09A
upgrade... These orders are happening daily and we can't do a dump and
loload overnight.
> Has anyone else gotten this error message? Any ideas for solutions. Right
now our CSR's are having to delete the order and re-create it.
Since we've gone up to 4.09A within order entry, we regualarly get the following error message:
Message: Record has been modified by another user and couldn't be updated. Please press the Refresh button and re-enter your changes.
Method: Main-Block
Table: OrderHed
Field: TermsCode
I know we normally get this message when someone else has updated the record. NORMALLY you'd hit refresh, re-apply your changes, save the record and move on.
This can be a newly entered order, that no one has changed - we go back into the order to make changes and get the error. the refresh button does NOT work. I tried to update the record using DMT and still get the same error message. It's like there's garbage data within the record, it thinks it's been updated and can't update itself.
Epicor says to do a dump and load. (which we did right before the 4.09A upgrade... These orders are happening daily and we can't do a dump and loload overnight.
Has anyone else gotten this error message? Any ideas for solutions. Right now our CSR's are having to delete the order and re-create it.
> Method: Main-Block
> Table: OrderHed
> Field: TermsCode
Have any BPMs running against OrderHed?
Mark W.
Yes, we have BPM's.
> > Method: Main-Block
> > Table: OrderHed
> > Field: TermsCode
> Mark W.
We just loaded 409A last night and have been having the same problem. Does anyone know if there is a fix for this?
> Method: Main-Block
> Table: OrderHed
> Field: TermsCode
Epicor was able to re-create the problem.
I just got an e-mail from Support for a fix. We're going to apply it tonight to see if it works. Call support for the solution. My tech support person was Ricardo Valdes.
> > Method: Main-Block
> > Table: OrderHed
> > Field: TermsCode
We want to restrict access to Part Duplication, which is a sub session from Part -- Can anyone provide info on how to restrict user access to sub session. We are on Vantage 8.00.811b
Vishal
8.03.407A
Use Process Security in System Management|Security Management folder.
Select the bo.Part object and then add the Duplicate Part method. From
there set security in the usual manner.
Ross
Vishal Mehta
Sent: Thursday, June 10, 2010 4:27 PM
Subject: [Vantage] Restricting Access to Sub Session
Vishal
This has happened periodically to us since we went to Vantage 8. We
sometimes have success by refreshing and saving before trying to make
any changes to the order, quote or whatever.
Hth,
Linda
Of pklein256
Sent: Monday, June 07, 2010 3:02 PM
Subject: [Vantage] 8.03.4.09A Order entry error Record has been modified
by another user
Method: Main-Block
Table: OrderHed
Field: TermsCode
record and move on.
loload overnight.
