8.03.305H - App servers keep going down every 20 minutes
Is your server experiencing a higher than normal volume of processing
or network traffic?
Have you properly configured the number of App Servers according to
the users using the system?
--SF
--- In vantage@yahoogroups.com, melissa hietala <kevmel822@...> wrote:
> Any help on the following message would be great! Epicor support is
slow and not as knowledgeable as we need them to be.
> Thanks
> Error Detail
> 4GL STOP condition: as/activate.p activation procedure ended with an
STOP condition. (8026) (7241)
> Stack Trace
> at Progress.Open4GL.DynamicAPI.Session.runProcedure(String
requestID, String procedureName, ParameterSet parms, Boolean
persistent, Boolean internal_Renamed, Int64 procId, MetaSchema
localSchema)
> at Progress.Open4GL.DynamicAPI.Session.runPersistentProcedure(String
procedureName, ParameterSet parms)
> at Epicor.Mfg.Proxy.ReportMonitorImpl.GetRowsKeepIdleTime(String
whereClauseSysRptLst, Int32 pageSize, Int32 absolutePage, Boolean&
morePages)
> at
Epicor.Mfg.BO.ReportMonitor.Epicor.Mfg.IF.IReportMonitor.GetRowsKeepIdleTime(String
, Int32 , Int32 , Boolean& )
> at
Epicor.Mfg.UI.Adapters.ReportMonitorAdapter.GetRowsKeepIdleTime(SearchOptions
opts, Boolean& MorePages)
> Melissa Hietala
> UMC, Inc.
> melissah@...
____________________________________________________________________________________
> Never miss a thing. Make Yahoo your home page.
> http://www.yahoo.com/r/hs
Any help on the following message would be great! Epicor support is slow and not as knowledgeable as we need them to be.
Error Detail
4GL STOP condition: as/activate.p activation procedure ended with an STOP condition. (8026) (7241)
Stack Trace
at Progress.Open4GL.DynamicAPI.Session.runProcedure(String requestID, String procedureName, ParameterSet parms, Boolean persistent, Boolean internal_Renamed, Int64 procId, MetaSchema localSchema)
at Progress.Open4GL.DynamicAPI.Session.runPersistentProcedure(String procedureName, ParameterSet parms)
at Epicor.Mfg.Proxy.ReportMonitorImpl.GetRowsKeepIdleTime(String whereClauseSysRptLst, Int32 pageSize, Int32 absolutePage, Boolean& morePages)
at Epicor.Mfg.BO.ReportMonitor.Epicor.Mfg.IF.IReportMonitor.GetRowsKeepIdleTime(String , Int32 , Int32 , Boolean& )
at Epicor.Mfg.UI.Adapters.ReportMonitorAdapter.GetRowsKeepIdleTime(SearchOptions opts, Boolean& MorePages)
Melissa Hietala
UMC, Inc.
melissah@...
