Will do. Thanks!
--- In vantage@yahoogroups.com, "Clive" <clive.1972@...> wrote:
> The schema change generates log files as part of the process, which I think are somewhere under the 'clientserver\db' folder.
> Maybe take a look at these as a starting point and get Epicor to examine them ?.
> --- In vantage@yahoogroups.com, "dsecco@" <dsecco@> wrote:
> > It wouldn't of been the <database>.pf file would it? I had some real problems with that file. Shortcuts didn't work because the file was in the wrong folder.
> > --- In vantage@yahoogroups.com, "cooner_55421" <cooner_55421@> wrote:
> > > I had something similar happen around 8.03.305.
> > > The schema change process was hanging when sequencing through individual revision updates.
> > > I vaguely remember editing a file to remove a version(s) from the schema change process but I don't remember the file name.
> > > Schema change was trying to update a version it didn't need to and the whole process would fail (instead of moving to the next).
> > > > When the Schema Change gets to Phase 2, the process freezes up and the window states (Not responding) and after about 10 minutes, the Schema windows closes. I will start it again and the process starts all over.
> > > > I've tried reinstalling progress and Vantage 8.03.305, no luck.
> > > > --- In vantage@yahoogroups.com, Mark Wonsil <mark_wonsil@> wrote:
> > > > > So if you start SCHEMA CHANGE again, it tries to continue or does it say
> > > > > that no changes required? I remember some Schema Change runs end silently.
> > > > > On Fri, Nov 4, 2011 at 4:47 PM, dsecco@ <dsecco@> wrote:
> > > > > > Anyone have any ideas as to why the schema change would complete Phase 1
> > > > > > and then crap out on Phase 2? Progress just stops responding and after
> > > > > > about 10-15 minutes the schema change closes out without completing.
> > > > > > TIA
> > > > > [Non-text portions of this message have been removed]
