I was using XP x64 when we first figured out how to install Vantage on a 64bit system. We successfully ran 4.2 and 5.x. I see no reason why 6.1 would not work the same.
JimM
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of shraderc
Sent: Friday, February 24, 2012 6:48 AM
Subject: [Vantage] Re: 64-Bit Workstation with 32-Bit Server and Vantage 6.1???
It would be exciting to get Vantage 6.1 working on an XP 64-Bit workstation - and this now seems possible according to this thread. Is there a minimum version of Progress that one must be running in order to do this? I'm reading that this can be done in Win7 64-Bit; can someone confirm they have run Vantage 6.1 in XP 64-Bit?
Chuck S.
Oak Ridge, TN
**Warning** Any technical data is or may be controlled under the U.S. International Traffic in Arms Regulations (ITAR) and may not be exported, released, or disclosed to foreign nationals without proper authorization by the U.S. Department of State." "CONFIDENTIALITY NOTICE: This electronic transmission, its contents and any attachments (hereinafter referred to collectively as "transmission") are confidential and are solely directed to, and intended for, the named addressee(s) only. Any use, reproduction or dissemination of this transmission by an unintended recipient is strictly prohibited. If you receive this transmission in error, please immediately notify the sender and delete this transmission in its entirety from your files. All intellectual property rights in this transmission are expressly reserved."
JimM
Chuck S.
Oak Ridge, TN
