61: Report Builder - What was run yesterday
Thanks. I will try it!
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf
Of pjw@...
Sent: Monday, June 20, 2005 7:32 AM
Subject: RE: [Vantage] 61: Report Builder - What was run yesterday.
Why the left outer joins?
LaborHead to LaborDtl using (Company, LaborHedSeq)
LaborDtl to JobOpr using (Company, JobNum, AssemblySeq, OprSeq
Filter your date on LaborHed.PayrollDate which is a index.
Build the report step by step previewing after each table added.
Add the table first as an inner join, then preview, change to outer join the
preview.
When it dies in performance you will know why.
Patrick Winter
sSc Specialty Screw Corporation
Vantage 6.10.514, Progress 9.1D08, Windows 2003 Server, Crystal 8.5.3.975
Juliet Martin
Sent: Thursday, June 16, 2005 5:18 PM
Subject: [Vantage] 61: Report Builder - What was run yesterday.
I am trying to write a report to see what was run in a certain department
the day before. I have tried the following two joins:
LaborHead - LaborDtl (innerjoin) Company, EmpNum LaborDtl - JobOper
(leftouter) Company, Maching JobNum, AsmSeq, OprSeq
LaborDtl - JobOper (leftouter) Company, Maching JobNum, AsmSeq, OprSeq
All of these are filtering on Company on the Master Table, Date Range, and
WC
This report runs for hours. Does anyone have a better solution or spot my
problem?
Thanks!
Juliet Martin
Information Manager
Rosenboom Machine & Tool, Inc.
Sheldon, IA 51201
712-324-4854 x1217
Yahoo! Groups Links
Yahoo! Groups Links
I am trying to write a report to see what was run in a certain department the day before. I have tried the following two joins:
All of these are filtering on Company on the Master Table, Date Range, and WC
This report runs for hours. Does anyone have a better solution or spot my problem?
Thanks!
Juliet Martin
Information Manager
Sheldon, IA 51201
712-324-4854 x1217
One thing I frequently do with Labor Reports is add an additional filter on the detail sequence number to be greater than the first one at some designated starting point (usually first one of the year). It means running one report filtered on date to find the "seed" sequence and then using this early in the filter - also means using all index fields related to that sequence number in the linking if possible.
Will speed the report many times over.
-Todd C.
Thanks!
Juliet Martin
Information Manager
Sheldon, IA 51201
712-324-4854 x1217
_____
Yahoo! Groups Links
vantage-unsubscribe@yahoogroups.com <mailto:vantage-unsubscribe@yahoogroups.com?subject=Unsubscribe>
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <http://docs.yahoo.com/info/terms/> .
Funny. I was searching through the archives looking for your previous message on the same thing. I am glad you resent this. I am doing that now.
Thanks!
JM
Of Todd Caughey
Sent: Friday, June 17, 2005 8:09 AM
-Todd C.
Thanks!
Juliet Martin
Information Manager
Sheldon, IA 51201
712-324-4854 x1217
As it happens I am working on benchmarks now for a presentation at the User-4-User conference in Chicago in August on data dictionay, table linking and report performance - mostly with RB but techniques should apply to Crystal too. One of the measures will be seeding the start point in large tables. So the technique was already in mind when I saw your post.
-Todd C.
Sent: Friday, June 17, 2005 9:21 AM
Thanks!
JM
Of Todd Caughey
-Todd C.
Thanks!
Juliet Martin
Information Manager
Sheldon, IA 51201
712-324-4854 x1217
_____
Yahoo! Groups Links
Todd-
I made a new report only using laborhed and then filtered on yesterday's date. All of the laborhedseq #'s are ????? Same with the LaborDtl. Am I choosing the wrong field?
JM
Of Todd Caughey
Sent: Friday, June 17, 2005 9:31 AM
-Todd C.
Thanks!
JM
Of Todd Caughey
-Todd C.
Thanks!
Hi Todd I cannot make this conference could you email the presentation to me
off line. I would really appreciate it.
Thanks, in advance
Frank Zeigafuse
Innovative Office Products
General Manager
Direct Phone: 610-559-6369
Email: fzeigafuse@...
Visit www.one.org to see how the world can be changed one person at a time.
Sent: Friday, June 17, 2005 10:31 AM
tables. So the technique was already in mind when I saw your post. -Todd C.
Thanks!
JM
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf Of
Todd Caughey
-Todd C.
WC
problem?
Thanks!
Juliet Martin
Information Manager
Sheldon, IA 51201
712-324-4854 x1217
_____
Yahoo! Groups Links
Yahoo! Groups Links
I'll need to coordinate that with Calvin since he's running "the show". I certainly don't have any problem with that but to be fair to attendees it would probably have to be after the conference some time. Another factor....I need to finish the benchmarking and the Powerpoint (in between all my regular job stuff) there is a lot of work left compiling the numbers because by my current methodology I try to make each "run" as even as possible (close RB, flush Mfgwk61, restart RB, etc....) - sort of a slow process.
-Todd C.
Sent: Friday, June 17, 2005 9:53 AM
Thanks, in advance
Frank Zeigafuse
General Manager
Thanks!
JM
Todd Caughey
-Todd C.
WC
problem?
Thanks!
Juliet Martin
Information Manager
Sheldon, IA 51201
712-324-4854 x1217
_____
Yahoo! Groups Links
< http://docs.yahoo.com/info/terms/> .
Yahoo! Groups Links
_____
Yahoo! Groups Links
preview.
Patrick Winter
Juliet Martin
WC
problem?
Thanks!
Juliet Martin
Information Manager
Sheldon, IA 51201
712-324-4854 x1217
Yahoo! Groups Links
