Thanks Todd,
My plan for #1 is to continue using mfgwk60 as my working folder and
modify the commands in the Vantage.mfg file to point there instead of
the mfgwk61 location.
#2 I had noticed a difference in the DB settings and made the print
screen copies. Haven't gotten around to making the changes yet, but
thanks for the advice.
#3 On the client I planned to alter the existing shortcut, like you
suggested a while back, thanks for that idea. A batch file would be
a neat idea, especially if what we need to do was a little more time
consuming, but I think it is simple enough I'm not going to worry
about it.
I'm more concerned about changes that the users might see, or
problems (bugs) that we might run into that I don't know about.
Brian Stenglein
Clow Stamping Co.
about it.
Brian Stenglein
Clow Stamping Co.
--- In vantage@yahoogroups.com, "Todd Caughey" <caugheyt@h...> wrote:
> A couple things I can recall....
> 1. Users working folder gets changed to mfgsys61 location so all
the Crystal reports using .dbf files need to be changed to point
there too. Delete the old working folders too (see #3 below as an
added tack in the batch file).
> 2. The installation sets all the DB parameters (like -n) too low.
Testing might not reveal this unless you have a couple dozen people
testing all at once. Copy your DB settings from 6.0 (screen prints
work well) and check them in the new 6.1 DB.
> 3. I sped the client process up considerably by re-installing just
the first one (the Progress part can be skipped) with the "save"
option then on each other client PC just changed the desktop shortcut
to point to the mfgsys61 folder (and new working folder too). If I
had been smarter I might also have copied the shortcut file to a
floppy along with a batch procedure (maybe called vGo.bat) to copy
the new shortcut to the desktop. Just insert floppy, command:
A:\vGo , then on to next PC. Would have saved a lot of typing to
change 60 to 61 in all those shortcuts.
> 4. We use a custom splash screen so that had to be moved to the
mfgsys61 area.
> I can't recall any changes that user really even noticed at all.
> -Todd C.
> -----Original Message-----
> From: Brian Stenglein [mailto:bstenglein@c...]
> Sent: Wednesday, December 01, 2004 3:29 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] 6.1 Upgrade
> Over Thanksgiving weekend I did a test install of 6.1 and the
upgrade
> went well. I plan on doing the live upgrade over New Years
weekend.
> I don't plan on doing much testing or letting users play with it
> ahead of time due to everything I've heard about little or no
changes
> from 6.0 to the core modules. Does anybody know of anything
> significant that has changed between 6.0 and 6.1 that I should look
> into more closely prior to going live?
> Thanks,
> Brian Stenglein
> Clow Stamping Co.
must have already linked your email address to a yahoo id to enable
access. )
Builder and Crystal Reports and other 'goodies', please goto:
> Yahoo! Groups Sponsor
> ADVERTISEMENT
<http://us.ard.yahoo.com/SIG=129nq9q3h/M=298184.5639630.6699735.300117
6/D=groups/S=1705007183:HM/EXP=1102022960/A=2434971/R=0/SIG=11eeoolb0/
*http://www.netflix.com/Default?mqso=60185400> click here
> <http://us.adserver.yahoo.com/l?
M=298184.5639630.6699735.3001176/D=groups/S=:HM/A=2434971/rand=7483776
16>
> _____
> Yahoo! Groups Links
> * To visit your group on the web, go to:
> * To unsubscribe from this group, send an email to:
> vantage-unsubscribe@yahoogroups.com <mailto:vantage-
unsubscribe@yahoogroups.com?subject=Unsubscribe>
> * Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service <http://docs.yahoo.com/info/terms/> .
