[6.1] Help File Issues on Windows Vista
Thanks. That should do it. The ITSS part looks very familiar from our XP-Sp2 issue.
-Todd C.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Jim Mediger
Sent: Tuesday, September 09, 2008 4:01 PM
Subject: RE: [Vantage] [6.1] Help File Issues on Windows Vista
For Vantage help on Windows Vista we did not have to turn off any
security settings. But we did have to add some registry settings. You
can copy and paste the following text into a text file and name it
something like vant32hlp.reg. Then you can either double click on it to
install or add it to a script.
Vista 32 bit:
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\HTMLHelp\1.x\ItssRestrictions]
"UrlAllowList"="N:\\vantage\\HELP\\vnhelp_enu.chm;file://;"
Vista 64 bit:
[HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\HTMLHelp\1.x\ItssRest
rictions]
JimM
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf
Of Todd Caughey
Sent: Tuesday, September 09, 2008 1:26 PM
Subject: [Vantage] [6.1] Help File Issues on Windows Vista
Our first Vantage 6.1 on Windows Vista scenario has occured. Everything
works fine except for Help. Much like we experienced with XP-SP2 and had
to fix with registry tweaks to turn off some security settings. Anyone
know if the same registry settings apply to Vista? Anything else I need
to do to fix it?
Todd Caughey
Harvey Vogel Mfg. Co.
Our first Vantage 6.1 on Windows Vista scenario has occured. Everything works fine except for Help. Much like we experienced with XP-SP2 and had to fix with registry tweaks to turn off some security settings. Anyone know if the same registry settings apply to Vista? Anything else I need to do to fix it?
Todd Caughey
Vista 32 bit:
Vista 64 bit:
rictions]
JimM
Of Todd Caughey
to do to fix it?
Todd Caughey
