6.1 Dashboard Query
Yes, I had checked that as well.
Stuart Noble
Thompson Meat Machinery
stuart@...
Ph: 61 7 3803 6643
Of Lee Hansen
Sent: Thursday, 12 October 2006 11:33 PM
Subject: [Vantage] Re: 6.1 Dashboard Query
I'm curious. In the User > Security settings, have you checked the
boxes for Personalization and Customization for the user ID?
Regards,
Lee Hansen
Director of IT
Netcom, Inc.
Office: 847-484-0190
Fax: 847-537-5143
Cell: 262-617-6696
www.netcominc.com <http://www.netcominc.com/ <http://www.netcominc.com/>
Hi there,
I have a dashboard query running from a BAQ. Everytime I open the
dashboard query, the column sizes are too wide. Saving settings after
resizing the columns does not work. Is there another way, or is there a
way to set the field width in the BAQ to force the columns to be the
correct width so they can be read?
Thanks in advance
Stuart Noble
stuart@...
Ph: 61 7 3803 6643
Stuart,
With the dashboard running, right click and select "Settings...." then
select "Customize".
Note: If you select "Personalize" you cannot adjust the column
widths.
In the "Customize Browse" select a field and adjust the width.
When finished, right click and select "Settings..." then select "Save
Settings".
Patrick Winter
Of Stuart Noble
Sent: Tuesday, October 10, 2006 5:31 PM
Subject: [Vantage] 6.1 Dashboard Query
Hi there,
Thanks in advance
Stuart Noble
stuart@... <mailto:stuart%40tmach.com.au>
Ph: 61 7 3803 6643
This e-mail and any attachments may contain confidential and
privileged information. If you are not the intended recipient,
please notify the sender immediately by return e-mail, delete this
e-mail and destroy any copies. Any dissemination or use of this
information by a person other than the intended recipient is
unauthorized and may be illegal.
Patrick, Those are the exact steps I have been taking, the column width
changes, but the new settings definitely will not save, even after I hit
save settings. They just revert back to the old settings the next time
you open the query. I am confused.
Stuart Noble
stuart@...
Ph: 61 7 3803 6643
Of Winter, Patrick
Sent: Wednesday, 11 October 2006 10:44 PM
Subject: RE: [Vantage] 6.1 Dashboard Query
Stuart,
select "Customize".
widths.
Settings".
Patrick Winter
Behalf
Of Stuart Noble
Hi there,
Thanks in advance
Stuart Noble
Ph: 61 7 3803 6643
Regards,
Lee Hansen
Director of IT
Netcom, Inc.
Fax: 847-537-5143
Cell: 262-617-6696
www.netcominc.com <http://www.netcominc.com/>
