[6.1] Additional places old server references can hide.....?
Todd
Do the slow machines have built in NIC's. Might try replacing the
NIC on one for grins. Also try taking the settings off auto and set to
100 full duplex.
Cliff
Of Todd Caughey
Sent: Monday, December 03, 2007 8:56 AM
Subject: [Vantage] [6.1] Additional places old server references can
hide.....?
Still trying to track down issues related to our server upgrade a week
ago.
Bottom line is that 11 out of 40 PCs with Vantage installed are still
suffering from very slow (4 min.) login screen. There are also a few
oddities in the using Vantage too but mostly they are as fast as anyone
else. The other 29 get the login screen in 3-7 seconds.
On Friday I unshared the old Epicor and Epic52 folders on the old
server. Today I am seeing a lot of "unable to open convmap" errors. Some
are easily resolved by uninstalling and re-installing Progress &
Vantage. But this tells me there are still references on these machines
to the old server.
I have extremely thoroughly scanned the registry for anything related to
the old server, old mapped drive letters, Progress, Vantage, Mfgsys61,
Epic52, DLC, PSC and multiple combinations and other things. I have
checked all the .ini and .pf files and made sure they are using the
right drive letters and file names - aside form 3/4 of the people using
these files just fine. One common factor in the slow machines was failed
un-installs of Progress/Vantage in the original switch. I have run
unreg.ocx (for all drive letters) and instocx.exe with various combos of
reboots in between without result.
I am now down to thinking there is some other reference to the old
server directly on the affected machines. I have searched the C: drives
and made sure the HOSTS and SERVICES files are correct. I have checked
the environment variables. Also, there is no commonality between the
affected machines as far as brand, motherboard, NIC, network switch or
TCP/IP settings. Two identical machines setup the same day, on the same
switch and running only Vantage....one starts fast the other does not.
Any ideas for other places references to the old server (or mapped
drives) could be hiding?
One curious observation when starting the slow machines.....network
traffic (monitored on XP machines) settles in to a very steady and
reproducible rhythm that uses 1-2% of network bandwidth for 3-4 min.
Then drops to zero for a second and then jumps to 30% just as the login
screen appears. Any ideas as to what this low grade network traffic
could be? I installed a packet recorder on one PC and could see nothing
obvious...just traffic between the client and the new server...mostly a
lot of requests and acks back and forth. Prowin32.exe just sits in "Not
Responding" state but occasionally uses 2-3% of CPU during this
time...like it is waiting for something and checking every 10 seconds or
so.
Todd Caughey
Harvey Vogel Mfg. Co.
PS...thanks too to all those with suggestions a week ago, even though it
has not been resolved they have been very helpful.
Still trying to track down issues related to our server upgrade a week ago.
Bottom line is that 11 out of 40 PCs with Vantage installed are still suffering from very slow (4 min.) login screen. There are also a few oddities in the using Vantage too but mostly they are as fast as anyone else. The other 29 get the login screen in 3-7 seconds.
On Friday I unshared the old Epicor and Epic52 folders on the old server. Today I am seeing a lot of "unable to open convmap" errors. Some are easily resolved by uninstalling and re-installing Progress & Vantage. But this tells me there are still references on these machines to the old server.
I have extremely thoroughly scanned the registry for anything related to the old server, old mapped drive letters, Progress, Vantage, Mfgsys61, Epic52, DLC, PSC and multiple combinations and other things. I have checked all the .ini and .pf files and made sure they are using the right drive letters and file names - aside form 3/4 of the people using these files just fine. One common factor in the slow machines was failed un-installs of Progress/Vantage in the original switch. I have run unreg.ocx (for all drive letters) and instocx.exe with various combos of reboots in between without result.
I am now down to thinking there is some other reference to the old server directly on the affected machines. I have searched the C: drives and made sure the HOSTS and SERVICES files are correct. I have checked the environment variables. Also, there is no commonality between the affected machines as far as brand, motherboard, NIC, network switch or TCP/IP settings. Two identical machines setup the same day, on the same switch and running only Vantage....one starts fast the other does not.
Any ideas for other places references to the old server (or mapped drives) could be hiding?
One curious observation when starting the slow machines.....network traffic (monitored on XP machines) settles in to a very steady and reproducible rhythm that uses 1-2% of network bandwidth for 3-4 min. Then drops to zero for a second and then jumps to 30% just as the login screen appears. Any ideas as to what this low grade network traffic could be? I installed a packet recorder on one PC and could see nothing obvious...just traffic between the client and the new server...mostly a lot of requests and acks back and forth. Prowin32.exe just sits in "Not Responding" state but occasionally uses 2-3% of CPU during this time...like it is waiting for something and checking every 10 seconds or so.
Todd Caughey
PS...thanks too to all those with suggestions a week ago, even though it has not been resolved they have been very helpful.
Tough one. Did you try and flush the DNS entries on the servers and
stations (ipconfig /flushdns). Might also check the eventlog on the
PC's having the problems. Might give you a clue where to look.
Butch
Of Todd Caughey
hide.....?
ago.
to the old server.
so.
Todd Caughey
Nothing in eventlogs...but I will try flushdns in a few minutes on one client I need to re-install.
-Todd C.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Butch Menge
Sent: Monday, December 03, 2007 11:03 AM
Subject: RE: [Vantage] [6.1] Additional places old server references can hide.....?
Butch
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf
Of Todd Caughey
hide.....?
ago.
to the old server.
so.
Todd Caughey
Take one client and try a search for the old server name inside of
files??
another stab in the dark....
> Thanks,
> -Todd C.
> Butch
Behalf
> Of Todd Caughey
> hide.....?
week
> ago.
still
anyone
Some
machines
> to the old server.
related to
Mfgsys61,
using
failed
combos of
drives
checked
or
same
not.
login
nothing
server...mostly a
in "Not
seconds or
> so.
> Thanks,
> Todd Caughey
though it
Also try searching the registry for the old server name.
Of bw2868bond
Sent: Monday, December 03, 2007 10:13 AM
Subject: Re: [Vantage] [6.1] Additional places old server references can
hide.....?
files??
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , Todd
> Thanks,
> -Todd C.
> Butch
Behalf
> Of Todd Caughey
> hide.....?
week
> ago.
still
anyone
Some
machines
> to the old server.
related to
Mfgsys61,
using
failed
combos of
drives
checked
or
same
not.
login
nothing
server...mostly a
in "Not
seconds or
> so.
> Thanks,
> Todd Caughey
though it
This is only for 6.1
Search the registry for
\\oldservername\epicor <file:///\\oldservername\epicor>
The issue is that when you reinstall the client for the new server it
does not get rid of any references to the registered DLLs that were
registered under the old server name. You can painstakingly search and
replace using regedit, but there are free tools available that will make
this process much easier.
Usual registry disclaimer...anytime you modify the registry there are
chances you could damage your system and/or leave it
inoperable...blah..blah...blah...just use caution J.
Jason Claggett
Microsoft Small Business Specialist
MCP #3856159
2W Technologies, LLC
312.533.4033 x8039
jason@...
Of Ken Williams
Sent: Monday, December 03, 2007 11:16 AM
hide.....?
Behalf
Of bw2868bond
hide.....?
files??
> Thanks,
> -Todd C.
> Butch
Behalf
> Of Todd Caughey
> hide.....?
week
> ago.
still
anyone
Some
machines
> to the old server.
related to
Mfgsys61,
using
failed
combos of
drives
checked
or
same
not.
login
nothing
server...mostly a
in "Not
seconds or
> so.
> Thanks,
> Todd Caughey
though it
