I figured it out. I copied over some of the df files that I shouldn't have.
I reinstalled Vantage and it worked fine.
Jeremy Leonard
IT Manager
K-T Corporation
Sent: Tuesday, September 10, 2002 1:27 PM
Subject: Re: [Vantage] 5.2 Schema Change
Jeremy,
Try checking your Schema Change icon to see if it's pointing to the
correct database-servicename-hostname, etc.
Troy
Jeremy Leonard
IT Manager
K-T Corporation
Jeremy,
Troy
----- Original Message -----
To: 'vantage@yahoogroups.com'
Sent: Tuesday, September 10, 2002 8:04 AM
Subject: [Vantage] 5.2 Schema Change
Hello,
I'm installing 5.2 for the first time on our test server. The install
went
fine and the database started fine and without errors. I ran the Schema
Change program but it only took about 1 second to run and said it had
finished with 0 errors. Obviously it didnt really do anything to the
database schema. When I try to open vantage it tells me that the database
schema still need to be ran. I have checked the server even log as well
as
the database log. Everything looks fine.
Anyone have a guess as to where I might look next?
Jeremy Leonard
IT Manager
K-T Corporation
Yahoo! Groups Sponsor
ADVERTISEMENT
