5.1 - Part Tracker is very slow
You can download it here
http://www.download.com/3000-2094-881470.html
Gerard M Wadman
Sr. Network Systems Engineer
Scandius BioMedical Inc.
11A Beaver Brook Road
Littleton, MA 01460
978/486-4088 x 124
978/486-4108 (fax)
http://www.scandius.com/
Of Rick Gors
Sent: Monday, November 06, 2006 9:52 AM
Subject: RE: [Vantage] 5.1 - Part Tracker is very slow
Who has regclean? Epicor? Our own File Archives?
How does it work?
TIA
RG
Run regclean on the clients
Our Vantage server crashed and I had to move it to another server.
Everything is normal except logins take a really long time and so does
using Part Tracker. I've seen posts in the past that talk about things
that need cleaned up on the client when moving servers but I haven't
found them. Support has given me some things to check but they haven't
worked. I've checked host files for entries of the old server, made
sure AV is excluding the proper things, and ran some program that
installed OCX files locally. Anybody have any other suggestions?
Mark Caldwell
VMI Americas, Inc.
I know this sounds simple, but did you check to see if the new server
name is registering in DNS?
Of course if DNS is the problem, there is a likelihood that any task
would be slow.
Gerard M Wadman
Littleton, MA 01460
978/486-4088 x 124
978/486-4108 (fax)
Of Mark Caldwell
Sent: Monday, November 06, 2006 7:57 AM
Subject: [Vantage] 5.1 - Part Tracker is very slow
Mark Caldwell
VMI Americas, Inc.
Of Mark Caldwell
Sent: 06 November 2006 12:57
Mark Caldwell
VMI Americas, Inc.
Mark
If regclean does not work. Search the registry for any reference to
your old server name and carefully remove them
Gary Parfrey
Of Mark Caldwell
Mark Caldwell
VMI Americas, Inc.
This e-mail is for the use of the intended recipient(s) only. If you have received this e-mail in error, please notify the sender immediately and then delete it. If you are not the intended recipient, you must not use, disclose or distribute this e-mail without the author's prior permission. We have taken precautions to minimize the risk of transmitting software viruses, but we advise you to carry out your own virus checks on any attachment to this message. We cannot accept liability for any loss or damage caused by software viruses.
How does it work?
TIA
RG
I'm not familiar with regclean either, so I just started to search the
registry for our old server name and found lots of entries. Any entry
that dealt with Vantage I replace the old server name with the new
server name and everything is working normal now.
Mark
Of Rick Gors
How does it work?
TIA
RG
