5.1 and Windows 95
I've notice that the Plant Floor.vtg takes QUITE a bit of time to come up even on our 450mhz machines - a lot longer than standard Vantage for sure.
Troy Funte
Liberty Electronics
----- Original Message -----
Sent: Thursday, December 13, 2001 3:22 PM
Subject: RE: [Vantage] 5.1 and Windows 95
Thanks for the posts. These files were in Read only, and correcting this did
allow the installs to go forward. It now takes a minute for the Plant Floor
screen to come up, but it's a five minute wait after you enter the employee
number, before it's ready to start an activity. Any other words of wisdom? I
might just have to setup terminal services for the Data Collections units
(133Mhz w/ 1 GB of Free Ram). - Les
> -----Original Message-----
> From: Ron Newell [SMTP:rnewell@...]
> Sent: Thursday, December 13, 2001 1:56 PM
> These are the files
> STDOLE.TLB
> OLEPRO32.DLL
> OLEAUT32.DLL
> ASYCFILT.DLL
> Ron Newell
> IT/MIS
> Neon Products
> 1695 Sargent Ave.
> Winnipeg, MB R3H 0C4
> http://www.neon-products.com/
> mailto:rnewell@...
> From: Moore, Jim (DRI) [mailto:jmoore@...-ots.com]
> Sent: Thursday, December 13, 2001 12:40 PM
> To: 'vantage@yahoogroups.com'
> I have had this before with 4.0, that is if the errors are saying the
> files
> are read only. After unchecking the read only, the install will proceed
> fine. You also could uninstall then reinstall.
> Jim Moore
> GD-OTS
> From: lptingley [mailto:ltingley@...]
> Sent: Thursday, December 13, 2001 12:32 PM
> Subject: [Vantage] 5.1 and Windows 95
> I've got a few Data Collections units running on 95. I just got
> failures on two units in a row, when trying to install 5.1. The
> failure seems to be at the point of copying dll and ocx files. Has
> anybody else seen this? These units are 133's with very small hard
> drives. I don't think I can even upgrade to 98.
> Thanks - Les
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> have
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
> have
> have already linked your email address to a yahoo id to enable access. )
Yahoo! Groups Sponsor
Thanks - Les
When I had this before (4.0) I had to stop the install and uncheck
read-only on the file it failed on. Then continue the install until I
found the next file. There were three in all - don't remember what they
were.
Juliet
Thanks - Les
I have had this before with 4.0, that is if the errors are saying the files
Jim Moore
GD-OTS
Thanks - Les
Some or all of the following:
msvcrt.dll
msvcrt40.dll
oleaut32.dll
olepro32.dll
stdole2.tlb
mfc42.dll
Malcolm Spann
MIS
Malmberg Engineering
malcolm@...
> From: Juliet Martin [mailto:jmartin@...]
> Sent: Thursday, December 13, 2001 10:41 AM
> remember what they
> were.
> Juliet
> Thanks - Les
These are the files
STDOLE.TLB
OLEPRO32.DLL
OLEAUT32.DLL
ASYCFILT.DLL
Ron Newell
IT/MIS
Neon Products
1695 Sargent Ave.
mailto:rnewell@...
Jim Moore
GD-OTS
Thanks - Les
> These are the files
> STDOLE.TLB
> OLEPRO32.DLL
> OLEAUT32.DLL
> ASYCFILT.DLL
> Ron Newell
> IT/MIS
> Neon Products
> 1695 Sargent Ave.
> mailto:rnewell@...
> files
> Jim Moore
> GD-OTS
> Thanks - Les
> have
> have
If you have not already, try installing the Win Socket 2 update for Win95
and see if that helps.
Jim Moore
GD-OTS
Sent: Thursday, December 13, 2001 2:22 PM
> These are the files
> STDOLE.TLB
> OLEPRO32.DLL
> OLEAUT32.DLL
> ASYCFILT.DLL
> Ron Newell
> IT/MIS
> Neon Products
> 1695 Sargent Ave.
> mailto:rnewell@...
> files
> Jim Moore
> GD-OTS
> Thanks - Les
> have
> have
