5.0 promon?
We found that on 3.0 when someone gets the splash screen Vantage
reserves a license. If the person clicks on Vantage a second time and
logs on the second time, they get on, but they are still reserving a
second license. I assume it is still working that way in 5.0 and the
fact that the splash screen is going off before the login comes on is
causing people to try to log on again. Just after they get the second
splash screen the first login screen shows up. We just booted everybody
off promon that were showing two entries, even thought only one was
logged on.
Steve
Sent: Monday, April 30, 2001 7:56 AM
To: 'vantage@yahoogroups.com'
Subject: [Vantage] 5.0 promon??
We just converted over to 5.0 this weekend. We have 25 regular
licenses,
and 5 data collection. I looked in through eMfg, connected
users and there
are only 17 users, currently. However, we have people not able
to log in.
We do not get a message about the license not
available......only that the
second splash screen never displays and the do not get the login
prompt. We
have users working in it currently. (the 17 mentioned above)
Does anyone
have any insight into our problem?
How do you disconnect users in 5.0?
Joy Fekkes
Jaco, Inc
jfekkes@... <mailto:jfekkes@...>
To access the Files Section of our Yahoo!Group for Report
Builder and Crystal Reports and other 'goodies', please go to:
http://groups.yahoo.com/group/vantage/files/. Note: You must have
already linked your email address to a yahoo id to enable access.
Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
We just converted over to 5.0 this weekend. We have 25 regular licenses,
and 5 data collection. I looked in through eMfg, connected users and there
are only 17 users, currently. However, we have people not able to log in.
We do not get a message about the license not available......only that the
second splash screen never displays and the do not get the login prompt. We
have users working in it currently. (the 17 mentioned above) Does anyone
Joy Fekkes
Jaco, Inc
I think you need to increase you -n parameter in startup.pf
Joy Fekkes
Jaco, Inc
To access the Files Section of our Yahoo!Group for Report Builder and
http://groups.yahoo.com/group/vantage/files/. Note: You must have already
In Promon on 5.0 the user id is not displayed under 1. User Control 1.
Display all entries. I called this into Support and they said that they are
working on it. You can see who is connected by going to 8. Shut down data
base. 1. Disconnect a user. The only problem there is that the user id
field is blank but there is a connection listed under the TTY LIMBO column.
This is where I checked on our connections. You can disconnnect users from
here. I hope this helps.
Marc L. Durre
Durre Bros. Welding & Machine Shop, Inc.
309-432-2512
mdurre@...
Sent: Monday, April 30, 2001 6:56 AM
Joy Fekkes
Jaco, Inc
