This error code has been a problem for us for months. Symptoms are as
you describe. Epicor is aware of the problem. We see this error during
the day - appears to have to do with backflush running in the
background. Also occurs consistently when we do Costing rollup. Has
also been an occasional problem when running MRP. 8.09 does not fix it
for us and the only solution that is really effective is to basically
reboot the system - takes us a few minutes.
Joe La Bore
Microdynamics Corp
Joe La Bore
Microdynamics Corp
